kharit1 3 Posted ... Hi, I have just download Qbittorrent download engine. I will be using this a lot to download different files. can somebody help me is to what's the best settings that i can set my QBittorent on so I don't get my information leaked. I have read some people saying even when using airvpn for downloading they still received letter from there service provider about illegal downloading. Quote Share this post Link to post
nick75 25 Posted ... Hi! You can bind qBittorrent to the tun0 interface or activate the network lock using Eddie.Either way, you won't get any letter. 2 Cyterstp and Soupcan Sam Hootkins reacted to this Quote Share this post Link to post
LZ1 662 Posted ... Hello! You can check my new user guide. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
OpenSourcerer 1359 Posted ... best settings that i can set my QBittorent on so I don't get my information leaked. You can bind qBittorrent to the tun0 interface This. Available in the advanced settings. Unless you use Windows because for me this never worked on Windows. Use Network Lock instead.All other settings are your personal preference. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
serenacat 83 Posted ... I believe the default Options/Connection/Listening Port should be set to the Port Forward assigned by Air for proper interaction with trackers and peers due to the "firewall effect" of the VPN. Not a security issue (hopefully?), but an efficiency/performance setting, and may require extra interaction with antivirus or windows firewall.Just a mention in a "starter thread". Probably covered in LZ guide, have not read up for a while. Todo. Quote Share this post Link to post
uatavpn 6 Posted ... I believe the default Options/Connection/Listening Port should be set to the Port Forward assigned by Air for proper interaction with trackers and peers due to the "firewall effect" of the VPN. i was told it wasn't necessary and, in fact, a bad idea to forward ports for torrenting - i run qBT with no forwarded ports or any other special settings and i get a 'green' light (uploading works) - the only thing i do since i don't use Eddie is to bind qBT to tun0 Quote Share this post Link to post
Staff 9751 Posted ... i was told it wasn't necessary and, in fact, a bad idea to forward ports for torrenting Quite the opposite, it's a good idea. Without remote port forwarding your torrent software can't be contacted. It can only actively initiate connections toward some client which allows incoming connections, therefore performance is impaired and initial seeding is impossible. If all peers in a swarm did not accept incoming connections torrenting would not work at all in that swarm. Kind regards Quote Share this post Link to post
uatavpn 6 Posted ... yes, Air staff is correct regarding port forwarding - my mistake to others who find this topic... AirVPN - go to your control panel and forward a port for both UDP and TCP - leave the fields blank and it will auto-pick a port make sure the port you use is NOT forwarded in your router there is no need to forward this port anywhere else (firewall, router, etc.) other than in the AirVPN control panel qBittorrent > tools > options > connectionslistening port - plug in the same port you forwarded on Airuncheck UPnPuncheck use different port on each start qBittorrent > tools > options > connections > connection limitsglobal max = 100connections per torrent = 50(settings above suggested by Air staff) qBittorrent > tools > options > bittorrent > privacyenable DHTenable PeX qBittorrent > tools > options > advancednetwork interface = tun0 (on Linux anyway) - you may have to be connected to the VPN before the tun0 option is available if you change VPN servers, you may have to repeat the above step if you are unable to download also see: Do you allow p2p? How can I optimize performance of eMule and BitTorrent with AirVPN? - Sales - AirVPN (https://airvpn.org/faq/p2p/) 3 LastGas, katohideyosi and BlackMartin reacted to this Quote Share this post Link to post
bluesjunior 39 Posted ... Here's a handy link which gives some more insight.http://www.techsupportalert.com/optimizing-qbittorrent-speed Quote Share this post Link to post
Soupcan Sam Hootkins 13 Posted ... Hi! You can bind qBittorrent to the tun0 interface or activate the network lock using Eddie.Either way, you won't get any letter. This is a great suggestion and solution. I just set qBittorrent to only use the TAP network adapter, and tested whether the connection was lost when I disconnected from my VPN and reinstated when I was connected to the VPN. Several tests show that the downloads stop as soon as I disconnect from the VPN, and continue once I reconnect the VPN. Quote Share this post Link to post
