Not connected, Your IP: 3.133.79.70
flood
Waiting for tap untap and replay?
Hi all I've been using airvpn for ages no issues, yesterday i start getting this issue, if anyone more technically minded than me could tell me whats going on that'd be great!
windows 10 64bit uptodate, lastest install of airvpn eddie and tunnel driver.
I 2017.02.17 07:34:12 - Eddie client version: 2.11.15 / windows_x64, System: Windows, Name: Microsoft Windows NT 10.0.14393.0, Mono/.Net Framework: v4.0.30319
. 2017.02.17 07:34:12 - Reading options from C:\Users\tobip\AppData\Local\AirVPN\AirVPN.xml
. 2017.02.17 07:34:12 - Data path: C:\Users\tobip\AppData\Local\AirVPN
. 2017.02.17 07:34:12 - Application path: C:\Program Files\AirVPN
. 2017.02.17 07:34:12 - Executable path: C:\Program Files\AirVPN\AirVPN.exe
. 2017.02.17 07:34:12 - Command line arguments (1): path="home"
. 2017.02.17 07:34:12 - Operating System: Microsoft Windows NT 10.0.14393.0
I 2017.02.17 07:34:12 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2017.02.17 07:34:12 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2017.02.17 07:34:12 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2017.02.17 07:34:12 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
! 2017.02.17 07:34:13 - Ready
. 2017.02.17 07:34:13 - Updating systems & servers data ...
. 2017.02.17 07:34:13 - Systems & servers data update completed
I 2017.02.17 07:35:07 - Session starting.
. 2017.02.17 07:35:07 - IPv6 disabled with packet filtering.
I 2017.02.17 07:35:07 - Checking authorization ...
! 2017.02.17 07:35:07 - Connecting to Alrai (Netherlands, Alblasserdam)
. 2017.02.17 07:35:07 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.02.17 07:35:07 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.02.17 07:35:07 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.02.17 07:35:07 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.02.17 07:35:07 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:35:07 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:35:07 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.78:443
. 2017.02.17 07:35:07 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.02.17 07:35:07 - OpenVPN > UDP link local: (not bound)
. 2017.02.17 07:35:07 - OpenVPN > UDP link remote: [AF_INET]213.152.162.78:443
. 2017.02.17 07:35:07 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.78:443, sid=a6b80e5a 19e8fc35
. 2017.02.17 07:35:07 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.02.17 07:35:07 - OpenVPN > Validating certificate key usage
. 2017.02.17 07:35:07 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.02.17 07:35:07 - OpenVPN > VERIFY KU OK
. 2017.02.17 07:35:07 - OpenVPN > Validating certificate extended key usage
. 2017.02.17 07:35:07 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.02.17 07:35:07 - OpenVPN > VERIFY EKU OK
. 2017.02.17 07:35:07 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.02.17 07:35:07 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.02.17 07:35:07 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.78:443
. 2017.02.17 07:35:09 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.02.17 07:35:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.147 255.255.0.0'
. 2017.02.17 07:35:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.02.17 07:35:09 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.02.17 07:35:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.02.17 07:35:09 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.02.17 07:35:09 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.02.17 07:35:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.02.17 07:35:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.02.17 07:35:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:35:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.02.17 07:35:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:35:09 - OpenVPN > interactive service msg_channel=0
. 2017.02.17 07:35:09 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 I=11 HWADDR=78:24:af:bc:12:1c
. 2017.02.17 07:35:09 - OpenVPN > open_tun
. 2017.02.17 07:35:09 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{1C4CB3E0-3566-407F-9645-173854CDBE1E}.tap
. 2017.02.17 07:35:09 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.02.17 07:35:09 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.6.147/255.255.0.0 [sUCCEEDED]
. 2017.02.17 07:35:09 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.6.147/255.255.0.0 on interface {1C4CB3E0-3566-407F-9645-173854CDBE1E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.02.17 07:35:09 - OpenVPN > Successful ARP Flush on interface [2] {1C4CB3E0-3566-407F-9645-173854CDBE1E}
. 2017.02.17 07:35:09 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.02.17 07:35:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:35:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:35:14 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:35:19 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.02.17 07:35:19 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.78 MASK 255.255.255.255 192.168.1.254
. 2017.02.17 07:35:19 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.02.17 07:35:19 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.02.17 07:35:19 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:35:19 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:35:19 - Starting Management Interface
. 2017.02.17 07:35:19 - OpenVPN > Initialization Sequence Completed
. 2017.02.17 07:35:19 - DNS leak protection with packet filtering enabled.
. 2017.02.17 07:35:19 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.02.17 07:35:19 - Flushing DNS
I 2017.02.17 07:35:22 - Checking route
I 2017.02.17 07:35:22 - Checking DNS
! 2017.02.17 07:35:34 - Connected.
. 2017.02.17 07:35:34 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.02.17 07:35:34 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.02.17 07:36:31 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #8010 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.02.17 07:40:31 - Above log line repeated 3577 times more
. 2017.02.17 07:40:31 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2017.02.17 07:40:31 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2017.02.17 07:40:31 - OpenVPN > Restart pause, 5 second(s)
! 2017.02.17 07:40:31 - Disconnecting
. 2017.02.17 07:40:31 - Management - Send 'signal SIGTERM'
. 2017.02.17 07:40:31 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.02.17 07:40:31 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.78 MASK 255.255.255.255 192.168.1.254
. 2017.02.17 07:40:31 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.02.17 07:40:31 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:40:31 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:40:31 - OpenVPN > Closing TUN/TAP interface
. 2017.02.17 07:40:31 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2017.02.17 07:40:31 - Connection terminated.
. 2017.02.17 07:40:31 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.02.17 07:40:31 - DNS leak protection with packet filtering disabled.
I 2017.02.17 07:40:34 - Checking authorization ...
! 2017.02.17 07:40:34 - Connecting to Pleione (Netherlands, Alblasserdam)
. 2017.02.17 07:40:34 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.02.17 07:40:34 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.02.17 07:40:34 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.02.17 07:40:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.02.17 07:40:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:40:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:40:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.148:443
. 2017.02.17 07:40:34 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.02.17 07:40:34 - OpenVPN > UDP link local: (not bound)
. 2017.02.17 07:40:34 - OpenVPN > UDP link remote: [AF_INET]213.152.162.148:443
. 2017.02.17 07:40:34 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.148:443, sid=2062349a 7afaf710
. 2017.02.17 07:40:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.02.17 07:40:34 - OpenVPN > Validating certificate key usage
. 2017.02.17 07:40:34 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.02.17 07:40:34 - OpenVPN > VERIFY KU OK
. 2017.02.17 07:40:34 - OpenVPN > Validating certificate extended key usage
. 2017.02.17 07:40:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.02.17 07:40:34 - OpenVPN > VERIFY EKU OK
. 2017.02.17 07:40:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.02.17 07:40:35 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.02.17 07:40:35 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.148:443
. 2017.02.17 07:40:36 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.02.17 07:40:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.88.239 255.255.0.0'
. 2017.02.17 07:40:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.02.17 07:40:36 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.02.17 07:40:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.02.17 07:40:36 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.02.17 07:40:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.02.17 07:40:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.02.17 07:40:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.02.17 07:40:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:40:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.02.17 07:40:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:40:36 - OpenVPN > interactive service msg_channel=0
. 2017.02.17 07:40:36 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 I=11 HWADDR=78:24:af:bc:12:1c
. 2017.02.17 07:40:36 - OpenVPN > open_tun
. 2017.02.17 07:40:36 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{1C4CB3E0-3566-407F-9645-173854CDBE1E}.tap
. 2017.02.17 07:40:36 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.02.17 07:40:36 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.88.239/255.255.0.0 [sUCCEEDED]
. 2017.02.17 07:40:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.88.239/255.255.0.0 on interface {1C4CB3E0-3566-407F-9645-173854CDBE1E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.02.17 07:40:36 - OpenVPN > Successful ARP Flush on interface [2] {1C4CB3E0-3566-407F-9645-173854CDBE1E}
. 2017.02.17 07:40:36 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.02.17 07:40:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:41 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:46 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:47 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:48 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:50 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:51 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:52 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:53 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:55 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:56 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:57 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:58 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:40:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:40:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:40:59 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:00 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:01 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:02 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:03 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:04 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:05 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:06 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:07 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:07 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:07 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:08 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:09 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:10 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.148 MASK 255.255.255.255 192.168.1.254
. 2017.02.17 07:41:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.02.17 07:41:11 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.02.17 07:41:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:41:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:41:11 - OpenVPN > SYSTEM ROUTING TABLE
. 2017.02.17 07:41:11 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.254 p=0 i=11 t=4 pr=3 a=686 h=0 m=35/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=2 t=4 pr=3 a=0 h=0 m=35/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.6.147 p=0 i=2 t=3 pr=2 a=356 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 10.4.6.147 255.255.255.255 10.4.6.147 p=0 i=2 t=3 pr=2 a=356 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.6.147 p=0 i=2 t=3 pr=2 a=356 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=692 h=0 m=331/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=692 h=0 m=331/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=692 h=0 m=331/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=2 t=4 pr=3 a=0 h=0 m=35/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.142 p=0 i=11 t=3 pr=2 a=686 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 192.168.1.142 255.255.255.255 192.168.1.142 p=0 i=11 t=3 pr=2 a=686 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.142 p=0 i=11 t=3 pr=2 a=686 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 213.152.162.148 255.255.255.255 192.168.1.254 p=0 i=11 t=4 pr=3 a=0 h=0 m=35/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=692 h=0 m=331/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.142 p=0 i=11 t=3 pr=2 a=690 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.6.147 p=0 i=2 t=3 pr=2 a=457 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=692 h=0 m=331/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.142 p=0 i=11 t=3 pr=2 a=690 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.6.147 p=0 i=2 t=3 pr=2 a=457 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:11 - OpenVPN > SYSTEM ADAPTER LIST
. 2017.02.17 07:41:11 - OpenVPN > Intel® Ethernet Connection (2) I218-V
. 2017.02.17 07:41:11 - OpenVPN >   Index = 11
. 2017.02.17 07:41:11 - OpenVPN >   GUID = {B9D243D5-BF4B-47A6-94F3-44BE157D79B2}
. 2017.02.17 07:41:11 - OpenVPN >   IP = 192.168.1.142/255.255.255.0
. 2017.02.17 07:41:11 - OpenVPN >   MAC = 78:24:af:bc:12:1c
. 2017.02.17 07:41:11 - OpenVPN >   GATEWAY = 192.168.1.254/255.255.255.255
. 2017.02.17 07:41:11 - OpenVPN >   DHCP SERV = 192.168.1.254/255.255.255.255
. 2017.02.17 07:41:11 - OpenVPN >   DHCP LEASE OBTAINED = Fri Feb 17 07:29:45 2017
. 2017.02.17 07:41:11 - OpenVPN >   DHCP LEASE EXPIRES  = Sat Feb 18 07:29:45 2017
. 2017.02.17 07:41:11 - OpenVPN >   DNS SERV = 192.168.1.254/255.255.255.255
. 2017.02.17 07:41:11 - OpenVPN > TAP-Windows Adapter V9
. 2017.02.17 07:41:11 - OpenVPN >   Index = 2
. 2017.02.17 07:41:11 - OpenVPN >   GUID = {1C4CB3E0-3566-407F-9645-173854CDBE1E}
. 2017.02.17 07:41:11 - OpenVPN >   IP = 10.4.6.147/255.255.0.0
. 2017.02.17 07:41:11 - OpenVPN >   MAC = 00:ff:1c:4c:b3:e0
. 2017.02.17 07:41:11 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2017.02.17 07:41:11 - OpenVPN >   DHCP SERV = 10.4.255.254/255.255.255.255
. 2017.02.17 07:41:11 - OpenVPN >   DHCP LEASE OBTAINED = Fri Feb 17 07:35:19 2017
. 2017.02.17 07:41:11 - OpenVPN >   DHCP LEASE EXPIRES  = Sat Feb 17 07:35:19 2018
. 2017.02.17 07:41:11 - OpenVPN >   DNS SERV = 10.4.0.1/255.255.255.255
. 2017.02.17 07:41:11 - Starting Management Interface
. 2017.02.17 07:41:11 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
. 2017.02.17 07:41:11 - DNS leak protection with packet filtering enabled.
. 2017.02.17 07:41:11 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
! 2017.02.17 07:41:11 - Disconnecting
. 2017.02.17 07:41:11 - Management - Send 'signal SIGTERM'
. 2017.02.17 07:41:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.02.17 07:41:11 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2017.02.17 07:41:11 - Flushing DNS
. 2017.02.17 07:41:14 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.02.17 07:41:14 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.02.17 07:41:14 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.02.17 07:41:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.148 MASK 255.255.255.255 192.168.1.254
. 2017.02.17 07:41:16 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.02.17 07:41:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:41:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:41:16 - OpenVPN > Closing TUN/TAP interface
. 2017.02.17 07:41:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.02.17 07:41:16 - Connection terminated.
. 2017.02.17 07:41:19 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.02.17 07:41:19 - DNS leak protection with packet filtering disabled.
I 2017.02.17 07:41:22 - Checking authorization ...
! 2017.02.17 07:41:22 - Connecting to Ancha (Netherlands, Alblasserdam)
. 2017.02.17 07:41:22 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.02.17 07:41:22 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.02.17 07:41:22 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.02.17 07:41:22 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.02.17 07:41:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:41:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:41:22 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.164:443
. 2017.02.17 07:41:22 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.02.17 07:41:22 - OpenVPN > UDP link local: (not bound)
. 2017.02.17 07:41:22 - OpenVPN > UDP link remote: [AF_INET]213.152.162.164:443
. 2017.02.17 07:41:22 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.164:443, sid=1bbda861 895cdc28
. 2017.02.17 07:41:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.02.17 07:41:22 - OpenVPN > Validating certificate key usage
. 2017.02.17 07:41:22 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.02.17 07:41:22 - OpenVPN > VERIFY KU OK
. 2017.02.17 07:41:22 - OpenVPN > Validating certificate extended key usage
. 2017.02.17 07:41:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.02.17 07:41:22 - OpenVPN > VERIFY EKU OK
. 2017.02.17 07:41:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.02.17 07:41:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.02.17 07:41:23 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.164:443
. 2017.02.17 07:41:24 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.02.17 07:41:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.10.98 255.255.0.0'
. 2017.02.17 07:41:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.02.17 07:41:24 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.02.17 07:41:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.02.17 07:41:24 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.02.17 07:41:24 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.02.17 07:41:24 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.02.17 07:41:24 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.02.17 07:41:24 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:41:24 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.02.17 07:41:24 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:41:24 - OpenVPN > interactive service msg_channel=0
. 2017.02.17 07:41:24 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 I=11 HWADDR=78:24:af:bc:12:1c
. 2017.02.17 07:41:24 - OpenVPN > open_tun
. 2017.02.17 07:41:24 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{1C4CB3E0-3566-407F-9645-173854CDBE1E}.tap
. 2017.02.17 07:41:24 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.02.17 07:41:24 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.10.98/255.255.0.0 [sUCCEEDED]
. 2017.02.17 07:41:24 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.10.98/255.255.0.0 on interface {1C4CB3E0-3566-407F-9645-173854CDBE1E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.02.17 07:41:24 - OpenVPN > Successful ARP Flush on interface [2] {1C4CB3E0-3566-407F-9645-173854CDBE1E}
. 2017.02.17 07:41:24 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.02.17 07:41:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:29 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:35 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:36 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:37 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:38 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:39 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:41 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:42 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:43 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:44 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:45 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:46 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:48 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:49 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:50 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:51 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:53 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:54 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:55 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:56 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:57 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.02.17 07:41:58 - Eddie Windows Interface Hack executed (Ethernet 3)
. 2017.02.17 07:41:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.02.17 07:41:59 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.164 MASK 255.255.255.255 192.168.1.254
. 2017.02.17 07:41:59 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2017.02.17 07:41:59 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.02.17 07:41:59 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:41:59 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:41:59 - OpenVPN > SYSTEM ROUTING TABLE
. 2017.02.17 07:41:59 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.254 p=0 i=11 t=4 pr=3 a=734 h=0 m=35/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=2 t=4 pr=3 a=0 h=0 m=35/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.6.147 p=0 i=2 t=3 pr=2 a=404 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 10.4.6.147 255.255.255.255 10.4.6.147 p=0 i=2 t=3 pr=2 a=404 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.6.147 p=0 i=2 t=3 pr=2 a=404 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=740 h=0 m=331/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=740 h=0 m=331/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=740 h=0 m=331/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=2 t=4 pr=3 a=0 h=0 m=35/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.142 p=0 i=11 t=3 pr=2 a=734 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 192.168.1.142 255.255.255.255 192.168.1.142 p=0 i=11 t=3 pr=2 a=734 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.142 p=0 i=11 t=3 pr=2 a=734 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 213.152.162.164 255.255.255.255 192.168.1.254 p=0 i=11 t=4 pr=3 a=0 h=0 m=35/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=740 h=0 m=331/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.142 p=0 i=11 t=3 pr=2 a=738 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.6.147 p=0 i=2 t=3 pr=2 a=505 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=740 h=0 m=331/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.142 p=0 i=11 t=3 pr=2 a=738 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.6.147 p=0 i=2 t=3 pr=2 a=505 h=0 m=291/0/0/0/0
. 2017.02.17 07:41:59 - OpenVPN > SYSTEM ADAPTER LIST
. 2017.02.17 07:41:59 - OpenVPN > Intel® Ethernet Connection (2) I218-V
. 2017.02.17 07:41:59 - OpenVPN >   Index = 11
. 2017.02.17 07:41:59 - OpenVPN >   GUID = {B9D243D5-BF4B-47A6-94F3-44BE157D79B2}
. 2017.02.17 07:41:59 - OpenVPN >   IP = 192.168.1.142/255.255.255.0
. 2017.02.17 07:41:59 - OpenVPN >   MAC = 78:24:af:bc:12:1c
. 2017.02.17 07:41:59 - OpenVPN >   GATEWAY = 192.168.1.254/255.255.255.255
. 2017.02.17 07:41:59 - OpenVPN >   DHCP SERV = 192.168.1.254/255.255.255.255
. 2017.02.17 07:41:59 - OpenVPN >   DHCP LEASE OBTAINED = Fri Feb 17 07:29:45 2017
. 2017.02.17 07:41:59 - OpenVPN >   DHCP LEASE EXPIRES  = Sat Feb 18 07:29:45 2017
. 2017.02.17 07:41:59 - OpenVPN >   DNS SERV = 192.168.1.254/255.255.255.255
. 2017.02.17 07:41:59 - OpenVPN > TAP-Windows Adapter V9
. 2017.02.17 07:41:59 - OpenVPN >   Index = 2
. 2017.02.17 07:41:59 - OpenVPN >   GUID = {1C4CB3E0-3566-407F-9645-173854CDBE1E}
. 2017.02.17 07:41:59 - OpenVPN >   IP = 10.4.6.147/255.255.0.0
. 2017.02.17 07:41:59 - OpenVPN >   MAC = 00:ff:1c:4c:b3:e0
. 2017.02.17 07:41:59 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2017.02.17 07:41:59 - OpenVPN >   DHCP SERV = 10.4.255.254/255.255.255.255
. 2017.02.17 07:41:59 - OpenVPN >   DHCP LEASE OBTAINED = Fri Feb 17 07:35:19 2017
. 2017.02.17 07:41:59 - OpenVPN >   DHCP LEASE EXPIRES  = Sat Feb 17 07:35:19 2018
. 2017.02.17 07:41:59 - OpenVPN >   DNS SERV = 10.4.0.1/255.255.255.255
. 2017.02.17 07:41:59 - Starting Management Interface
. 2017.02.17 07:41:59 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
. 2017.02.17 07:41:59 - DNS leak protection with packet filtering enabled.
. 2017.02.17 07:41:59 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
! 2017.02.17 07:41:59 - Disconnecting
. 2017.02.17 07:41:59 - Management - Send 'signal SIGTERM'
. 2017.02.17 07:41:59 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.02.17 07:41:59 - Flushing DNS
. 2017.02.17 07:42:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.02.17 07:42:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.02.17 07:42:02 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.02.17 07:42:04 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.164 MASK 255.255.255.255 192.168.1.254
. 2017.02.17 07:42:04 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.02.17 07:42:04 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:42:04 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.02.17 07:42:04 - OpenVPN > Closing TUN/TAP interface
. 2017.02.17 07:42:04 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.02.17 07:42:04 - Connection terminated.
. 2017.02.17 07:42:06 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.02.17 07:42:06 - DNS leak protection with packet filtering disabled.
I 2017.02.17 07:42:09 - Checking authorization ...
! 2017.02.17 07:42:09 - Connecting to Gienah (Netherlands, Alblasserdam)
. 2017.02.17 07:42:09 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.02.17 07:42:09 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.02.17 07:42:09 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.02.17 07:42:09 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.02.17 07:42:09 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:42:09 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.17 07:42:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.93:443
. 2017.02.17 07:42:09 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.02.17 07:42:09 - OpenVPN > UDP link local: (not bound)
. 2017.02.17 07:42:09 - OpenVPN > UDP link remote: [AF_INET]213.152.162.93:443
. 2017.02.17 07:42:09 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.93:443, sid=fa7e235c 1319b6fe
. 2017.02.17 07:42:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.02.17 07:42:09 - OpenVPN > Validating certificate key usage
. 2017.02.17 07:42:09 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.02.17 07:42:09 - OpenVPN > VERIFY KU OK
. 2017.02.17 07:42:09 - OpenVPN > Validating certificate extended key usage
. 2017.02.17 07:42:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.02.17 07:42:09 - OpenVPN > VERIFY EKU OK
. 2017.02.17 07:42:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.02.17 07:42:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.02.17 07:42:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.93:443
! 2017.02.17 07:42:10 - Disconnecting
. 2017.02.17 07:42:10 - Connection terminated.
. 2017.02.17 07:42:10 - IPv6 restored with packet filtering.
. 2017.02.17 07:42:10 - Flushing DNS
! 2017.02.17 07:42:14 - Session terminated.
. 2017.02.17 07:44:15 - Updating systems & servers data ...
. 2017.02.17 07:44:16 - Systems & servers data update completed
Give your computer a restart and see if it keeps happening.  I know that sounds dumb, but I've now found 4 different TAP bugs that I can't reset or fix that if my computer restarts, it fixes the problem.
