motorboatmygoat 1 Posted ... Tried connecting to servers in Holland and Switzerland but getting issues with checking route then time out. . 2017.02.17 04:20:33 - Flushing DNSI 2017.02.17 04:20:33 - Checking routeE 2017.02.17 04:20:44 - The request timed out. 2017.02.17 04:20:44 - Checking route (2° try)E 2017.02.17 04:20:56 - The request timed out. 2017.02.17 04:20:56 - Checking route (3° try)! 2017.02.17 04:21:01 - Disconnecting Quote Share this post Link to post
motorboatmygoat 1 Posted ... Ok managed to get connected after waiting 5 minutes. Quote Share this post Link to post
Khariz 109 Posted ... Are you using the newwest version of Eddie? Also, you can disable route checking. Quote Share this post Link to post
Vertigo7 0 Posted ... I have exactly the same prob with Eddie (2.11.15). Only servers it will connect to are HK. Also have "Updating systems & servers data ..., 4° try failed (The request timed out)""Cannot retrieve systems & servers data. Please retry later or contact us for help. (The request timed out). Seems to be an AirVPN issue if I can connect to some servers but not the majority of others. Quote Share this post Link to post
3xi7OVL 0 Posted ... yes i have got the same problems, seems like the new eddie client has some issues..im using windows 10 and i have reinstalled the old client..everything seems fine now...i hope they look into it.. it took the new eddie 10 mins or more to connect...switching servers takes even more time the new eddie also hangs if you logout with windows 10, every time. Quote Share this post Link to post
wugamuga 3 Posted ... me also -- same problem, macos sierra and latest eddie 2.11.15 Quote Share this post Link to post
User8 0 Posted ... Me same problem, upgraded and cannot connect any more.Every tenth or so trial it will connect for a few seconds and then disconnect. Every other time it times out and restarts... Quote Share this post Link to post
