Smith2342 0 Posted ... Hello everybody, so i am thinking about gettint AirVPN, but I have one question, It is possible for me to get connections over AirVPN without open the ports on my router. I don't use a router, i'm using a stick this is just a sample. I was using another VPN Service, but now they closed the possibility to do this. I use this usually to use a Computer as a Gameserverhost for some games. I updated my DNS by no-ip. Since some days it shows after my IP at the client (Router/NAT). Before this it showed LAN and everything worked. Quote Share this post Link to post
Staff 9691 Posted ... Hello everybody,so i am thinking about gettint AirVPN, but I have one question,It is possible for me to get connections over AirVPN without open the ports on my router.Hello!Yes, of course.I don't use a router, i'm using a stick this is just a sample.I was using another VPN Service, but now they closed the possibility to do this.I use this usually to use a Computer as a Gameserverhost for some games.In this case you will need to forward ports on our servers (please see Remote Port Forwarding on the FAQ) but not on your router.Kind regards Quote Share this post Link to post
