Not connected, Your IP: 18.116.239.195
BeanieMan
Eddie 2.11.15 Network Lock DNS issue
HI I recently upgraded to Eddie 2.11.15 and have noticed that after disconnecting from the VPN , the network lock feature does not work correctly .
Although the network lock blocks access to the internet it fails to prevent DNS requests leaving the local adapter (i.e 192.168.1.*)
The old Eddie client's network lock prevented this by maintaining the Airvpn DNS  config on the local adapter.
I realize that one of the "features of the new client is that it no longer uses windows firewall, don't know if this is the reason for the DNS problem but looks as though
I will have to use some kind of script in the "session end" external shell to correct the DNS issue .
Unless I have missed something.
I am using DNSEye to monitor the DNS requests I am seeing after the vpn session ends.
