Anon1475963 2 Posted ... Hi; Just started using AirVPN couple of days a go and have been reading forums and googeling answers to my problems, but: My torrenting speed is very low. I started with 50Kb/s and by fixing all I could find I was able to get up to 200-600Kb/s to download. Upload is always little bit higher(?). If I close my torrent client, speed is back up to 20-30Mb/s. About normal what I get. I have tried with different clients (uTorrnet and qBittorrent) and no difference. No restrictons for download speed on client. So far I tried also to: - connecting to different servers and countries- using different protocols- Increase buffer size to 256k- I have forwarded port for the client I also tried to change systemsetup to obtain DNS server automaticly, but had to change it back after I found out my DNS was leaking and had to set it to fixed Comodo server. This how ever didn´t have any effect to torrenting speed. Relating to DNS leak problem, I have Network Lock on and I fixed the WebRTC detection problem on my Firefox problem but still DNS was leaking. This was the only way I was able to fix it as I didn´t understand the instructions on DNSleaktest.com Any advise what to try next? Could it still be that my ISP is slowing me down? I 2017.01.24 21:48:23 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64. 2017.01.24 21:48:23 - Reading options from C:\Users\Miika\AppData\Local\AirVPN\AirVPN.xml. 2017.01.24 21:48:24 - Data Path: C:\Users\Miika\AppData\Local\AirVPN. 2017.01.24 21:48:24 - App Path: C:\Program Files\AirVPN. 2017.01.24 21:48:24 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2017.01.24 21:48:24 - Command line arguments (1): path="home". 2017.01.24 21:48:24 - Operating System: Microsoft Windows NT 6.2.9200.0. 2017.01.24 21:48:24 - Updating systems & servers data .... 2017.01.24 21:48:25 - Systems & servers data update completedI 2017.01.24 21:48:28 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1I 2017.01.24 21:48:28 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)I 2017.01.24 21:48:28 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2017.01.24 21:48:28 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)! 2017.01.24 21:48:28 - Activation of Network Lock - Windows FirewallI 2017.01.24 21:48:59 - Session starting.I 2017.01.24 21:49:00 - IPv6 disabled.I 2017.01.24 21:49:08 - Checking authorization ...! 2017.01.24 21:49:09 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:10 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\c53c8f5d300f7e5ed6014ca529dbb51982e537724aeb307bfbdfe45d07fb1c93.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:10 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:10 - Disconnecting. 2017.01.24 21:49:10 - Connection terminated.I 2017.01.24 21:49:14 - Checking authorization ...! 2017.01.24 21:49:14 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:15 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\5c4e0c326a5b709ce02bed9aab85987fcd43d5a8412815b620330e119e675425.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:15 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:15 - Disconnecting. 2017.01.24 21:49:15 - Connection terminated.I 2017.01.24 21:49:18 - Checking authorization ...! 2017.01.24 21:49:18 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:19 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\06a1c8dfcddea2864dab68090f768a7207c03c0acaec4df48961d43f19757513.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:19 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:19 - Disconnecting. 2017.01.24 21:49:19 - Connection terminated.I 2017.01.24 21:49:22 - Checking authorization ...! 2017.01.24 21:49:23 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:23 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\6c434016324786373d9eedf9897e050d4ee3a672408092baf525cea003f076e0.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:23 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:24 - Disconnecting. 2017.01.24 21:49:24 - Connection terminated.I 2017.01.24 21:49:27 - Checking authorization ...! 2017.01.24 21:49:27 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:28 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\4c8c46ef2b03ffa6e8f2a1dab0d4ff63ec9cd01af347c01b40cc9e541e8baa47.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:28 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:28 - Disconnecting. 2017.01.24 21:49:28 - Connection terminated.I 2017.01.24 21:49:31 - Checking authorization ...! 2017.01.24 21:49:32 - Connecting to Alhena (Canada, Toronto, Ontario). 2017.01.24 21:49:32 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\193481eca8128e4d95b2b14df145ae24cbd83408df8125edd1b57c08db682efc.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:32 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:32 - Disconnecting. 2017.01.24 21:49:32 - Connection terminated.I 2017.01.24 21:49:36 - Checking authorization ...! 2017.01.24 21:49:36 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:37 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\9eeb33804b9b50aa25ae31fa7640a3211d164c5af61742956b09921dd33f6baa.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:37 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:37 - Disconnecting. 2017.01.24 21:49:37 - Connection terminated.I 2017.01.24 21:49:40 - Checking authorization ...! 2017.01.24 21:49:40 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:41 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\31ae4a5022b421804de92919bec5fa60b22ff76f5583183ad7b89065625688cc.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:41 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:41 - Disconnecting. 2017.01.24 21:49:41 - Connection terminated.I 2017.01.24 21:49:44 - Checking authorization ...! 2017.01.24 21:49:45 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:46 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\eebf1beae19c616872f45cd1fbb5decdd118eec92f4afbd3e326361269b54398.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:46 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:46 - Disconnecting. 2017.01.24 21:49:46 - Connection terminated.I 2017.01.24 21:49:49 - Checking authorization ...! 2017.01.24 21:49:49 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:50 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\8e42b6a26a47dd43f06b0d0f335a3a4337ad35cd4948a3dedb66508c27017364.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:50 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:50 - Disconnecting. 2017.01.24 21:49:50 - Connection terminated.I 2017.01.24 21:49:53 - Checking authorization ...! 2017.01.24 21:49:54 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:54 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\1421af6e5135042f9610aba9883a944f7cc970bd3f69a3bebdec02dc829e0e59.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:54 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:55 - Disconnecting. 2017.01.24 21:49:55 - Connection terminated.I 2017.01.24 21:49:58 - Checking authorization ...! 2017.01.24 21:49:58 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:49:59 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\8c4cb9b1cf86ff940605a283628969f08d4e066d1e8154bcff40492f23ba5258.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:49:59 - OpenVPN > Use --help for more information.! 2017.01.24 21:49:59 - Disconnecting. 2017.01.24 21:49:59 - Connection terminated.I 2017.01.24 21:50:02 - Checking authorization ...! 2017.01.24 21:50:02 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:03 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\305f8ba0bd7724c6e20981d5a5a29d9aff1727010ff07ca7eb56cf903fe577a6.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:50:03 - OpenVPN > Use --help for more information.! 2017.01.24 21:50:03 - Disconnecting. 2017.01.24 21:50:03 - Connection terminated.I 2017.01.24 21:50:06 - Checking authorization ...! 2017.01.24 21:50:07 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:08 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\ffc7bd1f841bb10d16e2f8e8abe2be13df3d13074c6e43a162e3608f48d596f8.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:50:08 - OpenVPN > Use --help for more information.! 2017.01.24 21:50:08 - Disconnecting. 2017.01.24 21:50:08 - Connection terminated.I 2017.01.24 21:50:11 - Checking authorization ...! 2017.01.24 21:50:11 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:12 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\9de54e6f0c984ce7d022c1250202a5290200ae54382f4465a935ef1d06554b90.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:50:12 - OpenVPN > Use --help for more information.! 2017.01.24 21:50:12 - Disconnecting. 2017.01.24 21:50:12 - Connection terminated.I 2017.01.24 21:50:15 - Checking authorization ...! 2017.01.24 21:50:16 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:16 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\7522d1eb66c4334e23f51c349aa90ec7bccf39cf2041d7e5e6fd4107395d5413.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:50:16 - OpenVPN > Use --help for more information.! 2017.01.24 21:50:16 - Disconnecting. 2017.01.24 21:50:16 - Connection terminated.I 2017.01.24 21:50:20 - Checking authorization ...! 2017.01.24 21:50:20 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:21 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\e021ab4875bc73f7ebc961ea3ded20371fc98b6a65624f7b98a0b4a2ffce59cd.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:50:21 - OpenVPN > Use --help for more information.! 2017.01.24 21:50:21 - Disconnecting. 2017.01.24 21:50:21 - Connection terminated.I 2017.01.24 21:50:24 - Checking authorization ...! 2017.01.24 21:50:24 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:25 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\a2b8c23d7357b52a1be0095d08ad4b355dbebf29c07e8d153fd47712778ff471.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:50:25 - OpenVPN > Use --help for more information.! 2017.01.24 21:50:25 - Disconnecting. 2017.01.24 21:50:25 - Connection terminated.I 2017.01.24 21:50:29 - Checking authorization ...! 2017.01.24 21:50:29 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:30 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\835ce04336aa8542e5fff0192b125bcb750e68417f2ba9cd72c5c772ee152351.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:50:30 - OpenVPN > Use --help for more information.! 2017.01.24 21:50:30 - Disconnecting. 2017.01.24 21:50:30 - Connection terminated.I 2017.01.24 21:50:33 - Checking authorization ...! 2017.01.24 21:50:33 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:34 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\583556f13302d6e12256189ae4fc4edfd323e47458803c3e4158a85612806959.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:50:34 - OpenVPN > Use --help for more information.! 2017.01.24 21:50:34 - Disconnecting. 2017.01.24 21:50:34 - Connection terminated.I 2017.01.24 21:50:37 - Checking authorization ...! 2017.01.24 21:50:38 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:39 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\83b1d4d40efb120b4667b829eadf62bb38a289ef21db69e08a33b21272d06a83.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:50:39 - OpenVPN > Use --help for more information.! 2017.01.24 21:50:39 - Disconnecting. 2017.01.24 21:50:39 - Connection terminated.I 2017.01.24 21:50:42 - Checking authorization ...! 2017.01.24 21:50:42 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:43 - OpenVPN > Options error: Unrecognized option or missing parameter(s) in C:\Users\Miika\AppData\Local\AirVPN\2d5808b311172f2ac5e217f8991f680766876c0b259e0c56bbee5a2d1718ccce.tmp.ovpn:23: block-outside-dns (2.3.8). 2017.01.24 21:50:43 - OpenVPN > Use --help for more information.! 2017.01.24 21:50:43 - Disconnecting. 2017.01.24 21:50:43 - Connection terminated.I 2017.01.24 21:50:46 - Checking authorization ...! 2017.01.24 21:50:47 - Connecting to Alula (Sweden, Uppsala). 2017.01.24 21:50:48 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2017.01.24 21:50:48 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.01.24 21:50:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101. 2017.01.24 21:50:48 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.24 21:50:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.24 21:50:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.24 21:50:48 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2017.01.24 21:50:48 - OpenVPN > UDPv4 link local: [undef]. 2017.01.24 21:50:48 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.151:443. 2017.01.24 21:50:48 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.151:443, sid=a2f90b89 932d9238. 2017.01.24 21:50:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.24 21:50:48 - OpenVPN > Validating certificate key usage. 2017.01.24 21:50:48 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.24 21:50:48 - OpenVPN > VERIFY KU OK. 2017.01.24 21:50:48 - OpenVPN > Validating certificate extended key usage. 2017.01.24 21:50:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.24 21:50:48 - OpenVPN > VERIFY EKU OK. 2017.01.24 21:50:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.24 21:50:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.24 21:50:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.24 21:50:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.24 21:50:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.24 21:50:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.01.24 21:50:57 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.151:443. 2017.01.24 21:50:59 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.24 21:50:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.46.248 255.255.0.0'. 2017.01.24 21:50:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.24 21:50:59 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.24 21:50:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.24 21:50:59 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.24 21:50:59 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.24 21:50:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.24 21:50:59 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.24 21:50:59 - OpenVPN > open_tun, tt->ipv6=0. 2017.01.24 21:51:00 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{CC7B8FFA-714D-4876-B656-EB1EFC423371}.tap. 2017.01.24 21:51:00 - OpenVPN > TAP-Windows Driver Version 9.21. 2017.01.24 21:51:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.46.248/255.255.0.0 [sUCCEEDED]. 2017.01.24 21:51:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.46.248/255.255.0.0 on interface {CC7B8FFA-714D-4876-B656-EB1EFC423371} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2017.01.24 21:51:00 - OpenVPN > Successful ARP Flush on interface [18] {CC7B8FFA-714D-4876-B656-EB1EFC423371}. 2017.01.24 21:51:04 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2017.01.24 21:51:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 62.102.148.151 MASK 255.255.255.255 192.168.43.1. 2017.01.24 21:51:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2017.01.24 21:51:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.01.24 21:51:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.43.1 MASK 255.255.255.255 192.168.43.1 IF 4. 2017.01.24 21:51:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2017.01.24 21:51:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.01.24 21:51:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.01.24 21:51:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.01.24 21:51:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.01.24 21:51:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.01.24 21:51:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.01.24 21:51:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.01.24 21:51:04 - Starting Management Interface. 2017.01.24 21:51:04 - OpenVPN > Initialization Sequence CompletedI 2017.01.24 21:51:04 - DNS of a network adapter forced (Ralink RT3290 802.11bgn Wi-Fi Adapter)I 2017.01.24 21:51:04 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2017.01.24 21:51:05 - Flushing DNSI 2017.01.24 21:51:06 - Checking routeI 2017.01.24 21:51:09 - Checking DNS! 2017.01.24 21:51:10 - Connected.. 2017.01.24 21:51:10 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3101. 2017.01.24 21:51:10 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info! 2017.01.24 21:51:24 - Disconnecting. 2017.01.24 21:51:24 - Management - Send 'signal SIGTERM'. 2017.01.24 21:51:24 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.01.24 21:51:24 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.01.24 21:51:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 62.102.148.151 MASK 255.255.255.255 192.168.43.1. 2017.01.24 21:51:29 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.01.24 21:51:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.43.1 MASK 255.255.255.255 192.168.43.1. 2017.01.24 21:51:29 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.01.24 21:51:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.01.24 21:51:29 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.01.24 21:51:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.01.24 21:51:29 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.01.24 21:51:29 - OpenVPN > Closing TUN/TAP interface. 2017.01.24 21:51:29 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.01.24 21:51:29 - Connection terminated.I 2017.01.24 21:51:29 - DNS of a network adapter restored to original settings (Ralink RT3290 802.11bgn Wi-Fi Adapter)I 2017.01.24 21:51:29 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2017.01.24 21:51:32 - Checking authorization ...! 2017.01.24 21:51:33 - Connecting to Rukbat (Netherlands, Alblasserdam). 2017.01.24 21:51:34 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2017.01.24 21:51:34 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2017.01.24 21:51:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101. 2017.01.24 21:51:34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2017.01.24 21:51:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.24 21:51:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.24 21:51:34 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2017.01.24 21:51:34 - OpenVPN > UDPv4 link local: [undef]. 2017.01.24 21:51:34 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.83:443. 2017.01.24 21:51:34 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.83:443, sid=62bb13d2 24b46cc9. 2017.01.24 21:51:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.24 21:51:35 - OpenVPN > Validating certificate key usage. 2017.01.24 21:51:35 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.24 21:51:35 - OpenVPN > VERIFY KU OK. 2017.01.24 21:51:35 - OpenVPN > Validating certificate extended key usage. 2017.01.24 21:51:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.24 21:51:35 - OpenVPN > VERIFY EKU OK. 2017.01.24 21:51:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.24 21:51:35 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.24 21:51:35 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.24 21:51:35 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.24 21:51:35 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.24 21:51:35 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.01.24 21:51:35 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.83:443. 2017.01.24 21:51:38 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.01.24 21:51:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.102.222 255.255.0.0'. 2017.01.24 21:51:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.24 21:51:38 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2017.01.24 21:51:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.24 21:51:38 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.24 21:51:38 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.24 21:51:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.24 21:51:38 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2017.01.24 21:51:38 - OpenVPN > open_tun, tt->ipv6=0. 2017.01.24 21:51:38 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{CC7B8FFA-714D-4876-B656-EB1EFC423371}.tap. 2017.01.24 21:51:38 - OpenVPN > TAP-Windows Driver Version 9.21. 2017.01.24 21:51:38 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.102.222/255.255.0.0 [sUCCEEDED]. 2017.01.24 21:51:38 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.102.222/255.255.0.0 on interface {CC7B8FFA-714D-4876-B656-EB1EFC423371} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2017.01.24 21:51:38 - OpenVPN > Successful ARP Flush on interface [18] {CC7B8FFA-714D-4876-B656-EB1EFC423371}. 2017.01.24 21:51:43 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2017.01.24 21:51:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.83 MASK 255.255.255.255 192.168.43.1. 2017.01.24 21:51:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2017.01.24 21:51:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.01.24 21:51:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.43.1 MASK 255.255.255.255 192.168.43.1 IF 4. 2017.01.24 21:51:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2017.01.24 21:51:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.01.24 21:51:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.01.24 21:51:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.01.24 21:51:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.01.24 21:51:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.01.24 21:51:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.01.24 21:51:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.01.24 21:51:43 - Starting Management Interface. 2017.01.24 21:51:43 - OpenVPN > Initialization Sequence CompletedI 2017.01.24 21:51:43 - DNS of a network adapter forced (Ralink RT3290 802.11bgn Wi-Fi Adapter)I 2017.01.24 21:51:43 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2017.01.24 21:51:43 - Flushing DNSI 2017.01.24 21:51:45 - Checking routeI 2017.01.24 21:51:46 - Checking DNS! 2017.01.24 21:51:46 - Connected.. 2017.01.24 21:51:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.01.24 21:51:46 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3101. 2017.01.24 22:19:14 - Updating systems & servers data .... 2017.01.24 22:19:14 - Systems & servers data update completed. 2017.01.24 22:49:24 - Updating systems & servers data .... 2017.01.24 22:49:25 - Systems & servers data update completed. 2017.01.24 22:51:35 - OpenVPN > TLS: soft reset sec=0 bytes=4440401552/0 pkts=4998023/0. 2017.01.24 22:51:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.24 22:51:35 - OpenVPN > Validating certificate key usage. 2017.01.24 22:51:35 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.24 22:51:35 - OpenVPN > VERIFY KU OK. 2017.01.24 22:51:35 - OpenVPN > Validating certificate extended key usage. 2017.01.24 22:51:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.24 22:51:35 - OpenVPN > VERIFY EKU OK. 2017.01.24 22:51:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.01.24 22:51:37 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.24 22:51:37 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.24 22:51:37 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.24 22:51:37 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.24 22:51:37 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA Quote Share this post Link to post
lizze 0 Posted ... Got the same problem, I have really low torrent speed around started at 20-30 kb and eventually up to 450kb mark. I am using utorrent too. Without VPN I usually have 2-8mb download speed I've tried servers in Netherlands and Sweden, same result. These servers were on 9-17% so not max capacity Joined AirVpn today for a 3 days test run but if I can't torrent then I wont renew. Quote Share this post Link to post
LZ1 662 Posted ... Hello! You could both check my new user guide and find guides to torrenting in it. OP your issue is related to the TAP driver, if memory serves. So download the Beta client please. 1 Daishi reacted to this Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
rustintimberlake 13 Posted ... If you use Windows 7, try this method too... Increase bandwidth by disabling QoS in Windows 7 Quote Share this post Link to post
~Daniel~ 11 Posted ... I recently switched from another VPN service. While I was trialing a few different VPN's, I noticed many were downloading more slowly than what I had been accustomed too. However I noticed some things:I was having some upload/tracker issues that were finally resolved by switching to Tixati as my bt client (had used Deluge for quite a while, but tried out Transmission, and ultimately settled on Tixati)... speeds are going to suck if your uploads are disabledTixati also worked well with my Air VPN Port Forward, which also helped my uploadingThe majority of my high downloading rates were coming from one (or a few) really good peers... what guarantees are there that one of these amazing peers will be allocated to you in the bt client? I'm no tracker/peer expert... but I think it's a bit of a lottery sometimes... and my download speed fluctuates with the peers that are either assigned to me (or that I am able to handshake with at the moment)I can't see how AirVPN would control this, but there may be some settings in the bt client that could help... but I'm not expert enough to know for sureOne thing I played with was a BlockList... it dropped lots of peers and even entire trackers... certainly must have played a role in my connections/peers/bandwidthDo you cap your download speed in the bt client at all? I recall learning that too much upload can saturate the connection and severely hamper your downloading (Google upload saturation)... I typically cap my upload to 50Kb/s... it may be able to handle more, but I want to ensure downloading is priority.In short, I suspect the randomness of peers assigned to me by the trackers (multiple configurations can impact these) to explain my downloading experience form one torrent to another... can someone prove this thought incorrect?I suspect my thoughts to be true because even if I've lost the lottery and my bt download is 300-1000Kb/s... I can still fire up Ookla SpeedTest on my desktop and confirm I can still see successful 20-30Mb speedtests within the same AirVPN connection.EDIT: I did a little test...I queued up a D/L (using a magnetic link) from source A, in two hours it had downloaded less than 200KB... horrific! sub 5KB/sI decided to queue the same D/L from source B (again using a magnetic link) and it downloaded 200KB in under 10 minutes. I was getting 600+KB/s average and witnessed fluctuations from 200KB/s -1.4MB/sWhile I can say that my second download was sporadic/inconsistent speed-wise... it was amazing compared to the first download source on the same VPN connection! The core difference between the files was the difference in trackers used, which no doubt brought with it different lists of peers that I was able to make better connections with.Maybe it's possible other folks out there are using BlockLists which might filter us off based on the tracker that introduced us... I have turned off my BlockList in my bt client because I chose to have more connections/sources.Maybe it is also possible that some of Air's exit IP's have made in on the BlockLists too... but there's no Eddie configuration for that.Even though I think this test proves there is more to d/l speed than your VPN settings/provider... what still confuses me is that each D/L had 20-30 D/L connections established... but 2/3 (or more) were idle, 2-3 connections were offering the bulk of the speed, and the rest were all under 100B/s... basically useless. Not sure why 30 connections boiled down to 2-3 good connections. maybe the lottery is deeper than I thought? Quote Share this post Link to post
OpenSourcerer 1352 Posted ... The majority of my high downloading rates were coming from one (or a few) really good peers... what guarantees are there that one of these amazing peers will be allocated to you in the bt client? I'm no tracker/peer expert... but I think it's a bit of a lottery sometimes... and my download speed fluctuates with the peers that are either assigned to me (or that I am able to handshake with at the moment) To answer this question, you'd need to read up yourself on how distributed file sharing works, especially how the BitTorrent protocol works. No, there are no allocations. Some clients are behind a mobile connection, some are fully-featured seedboxes with download/upload speeds over 100 Mb. Some algorithms behind BitTorrent might find a peer to be "good" and decide to prioritize it. By doing so other peers' priority will of course be lowered. In short, I suspect the randomness of peers assigned to me by the trackers (multiple configurations can impact these) to explain my downloading experience form one torrent to another... can someone prove this thought incorrect? Also read up on what trackers are for. They don't assign shit. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
~Daniel~ 11 Posted ... Also read up on what trackers are for. They don't assign shit. I think I found some useful details on Wikipedia...A BitTorrent tracker is a special type of server, one that assists in the communication between peers using the BitTorrent protocol. In peer-to-peer file sharing, a software client on an end-user PC requests a file, and portions of the requested file residing on peer machines are sent to the client, and then reassembled into a full copy of the requested file. The "tracker" server keeps track of where file copies reside on peer machines, which ones are available at time of the client request, and helps coordinate efficient transmission and reassembly of the copied file. Clients that have already begun downloading a file communicate with the tracker periodically to negotiate faster file transfer with new peers, and provide network performance statistics; however, after the initial peer-to-peer file download is started, peer-to-peer communication can continue without the connection to a tracker. Since the creation of the distributed hash table (DHT) method for "Trackerless" torrents, BitTorrent trackers have largely become redundant, however, they are still often included with torrents to improve the speed of peer discovery. I did try an experiment where I removed the trackers from a newly queued torrent (magnetic link) in my d/l client. I did successfully establish links with peers and started downloading without the trackers, but not as many peers were found as I was used to seeing. I let it go for a bit, then stopped to restore the trackers... end result, many more peer links were established with the trackers. However, this was only one test, but tells me trackers do mean something still today; although assigning was the wrong description. Facilitate, perhaps? Quote Share this post Link to post
OpenSourcerer 1352 Posted ... Facilitate sounds more accurate. Trackers help with peer discovery by transmitting active peer lists and gather statistics about speeds and parts, that's why some trackers are able to calculate a ratio. DHT (the trackerless thing) works with algorithms to discover neighbors who know neighbors who know neighbors and so on, so that you have a list of peers in the end with which your client can work. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
ociredef 0 Posted ... hi guyssorry for my eng.... i've try tu do all. but my connetion in torrent DL id 30 k max -UL i yhink it's ok whay please? p.s. ci fosse qualcuno che parla italiano sarebbe perfetto magari Quote Share this post Link to post
