Not connected, Your IP: 3.139.238.76
chowhiyeon
Setting up DD-WRT with airvpn(Port Forwarding)
Hi all, I am trying to set up an airvpn using DD-WRT. I was able to connect to the server and successfully using OpenVPN function, however, I was not able to use port forwarding function. When I disabled airvpn on my DD-WRT and used app, I was able to check that the port was open. When I set up VPN on DD-WRT for some reason port forwarding does not work. In order to verify that vpn was indeed connected, I used overview on client area. I also check the port was open using forwarded ports. Does anyone have a suggestion how I might be able to open the port?
P.S When I first installed DD-WRT, I was not able to open a port using forwarded port(both router and app). I quickly realized that I also had to port forward on the router too.
