Not connected, Your IP: 3.144.244.44
piston.gandon
is it possible to use skype over airvpn?
hello. the question stated in the subject. if its possible can u plz say witch setting i have to use? or even better make tutorial and put it the site
thnk u
thnk u
Yes, of course. We don't discriminate against any protocol or application. You don't need any particular configuration, just launch Skype after you have connected to an Air server.
well, i tried but it ddnt work. theres a site http://skype-ip-finder.tk/ and when i entered my skype login and insert captcha it showed my real ip address. so i winder how to hide my ip address now
We can't reproduce the behavior. That test is fine and shows the exit-IP address of the VPN server a client is connected to and the IP address in the virtual private network.
Please check for leaks and malware on your system. According to your OS, you might also want to read this thread:
https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=1713&Itemid=142
