Not connected, Your IP: 3.141.24.134
Karpuxa123
Disconnecting after checking route - not sure how to fix on MacOs
Hi Guys!
I've got a problem. I can't connect to airvpn. It's disconnecting after checking route. I've tried many time and it's still disconnecting. I use MacOS. Kindly help me with it. Thanks
. 2017.01.06 11:39:51 - Management - Send 'signal SIGTERM'
. 2017.01.06 11:39:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.01.06 11:39:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 11:39:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.06 11:39:57 - OpenVPN > /sbin/route delete -net 184.75.221.42 192.168.1.1 255.255.255.255
. 2017.01.06 11:39:57 - OpenVPN > delete net 184.75.221.42: gateway 192.168.1.1
. 2017.01.06 11:39:57 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.01.06 11:39:57 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.01.06 11:39:57 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.01.06 11:39:57 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.01.06 11:39:57 - OpenVPN > Closing TUN/TAP interface
. 2017.01.06 11:39:57 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.06 11:39:57 - Connection terminated.
I 2017.01.06 11:39:57 - DNS of a network adapter restored to original settings (Ethernet)
I 2017.01.06 11:39:57 - DNS of a network adapter restored to original settings (FireWire)
I 2017.01.06 11:39:57 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2017.01.06 11:39:57 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2017.01.06 11:39:57 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2017.01.06 11:40:00 - Checking authorization ...
! 2017.01.06 11:40:01 - Connecting to Sualocin (Canada, Toronto, Ontario)
. 2017.01.06 11:40:01 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2017.01.06 11:40:01 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2017.01.06 11:40:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104
. 2017.01.06 11:40:01 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.01.06 11:40:01 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:40:01 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:40:01 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2017.01.06 11:40:01 - OpenVPN > UDPv4 link local: [undef]
. 2017.01.06 11:40:01 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.221.42:443
. 2017.01.06 11:40:01 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.42:443, sid=649e7efa 1160fde3
. 2017.01.06 11:40:01 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 11:40:01 - OpenVPN > Validating certificate key usage
. 2017.01.06 11:40:02 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 11:40:02 - OpenVPN > VERIFY KU OK
. 2017.01.06 11:40:02 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 11:40:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 11:40:02 - OpenVPN > VERIFY EKU OK
. 2017.01.06 11:40:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.01.06 11:40:05 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 11:40:05 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:40:05 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 11:40:05 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:40:05 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 11:40:05 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.42:443
. 2017.01.06 11:40:07 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 11:40:07 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.52.209 255.255.0.0'
. 2017.01.06 11:40:07 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 11:40:07 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.01.06 11:40:07 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.01.06 11:40:07 - OpenVPN > route: writing to routing socket: File exists
. 2017.01.06 11:40:07 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 11:40:07 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 11:40:07 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 11:40:07 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 11:40:07 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2017.01.06 11:40:07 - OpenVPN > Opened utun device utun2
. 2017.01.06 11:40:07 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 11:40:07 - OpenVPN > /sbin/ifconfig utun2 delete
. 2017.01.06 11:40:07 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.01.06 11:40:07 - OpenVPN > /sbin/ifconfig utun2 10.4.52.209 10.4.52.209 netmask 255.255.0.0 mtu 1500 up
. 2017.01.06 11:40:07 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.52.209 255.255.0.0
. 2017.01.06 11:40:07 - OpenVPN > add net 10.4.0.0: gateway 10.4.52.209: File exists
. 2017.01.06 11:40:07 - OpenVPN > /sbin/route add -net 184.75.221.42 192.168.1.1 255.255.255.255
. 2017.01.06 11:40:07 - OpenVPN > add net 184.75.221.42: gateway 192.168.1.1
. 2017.01.06 11:40:07 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.01.06 11:40:07 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.01.06 11:40:07 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.01.06 11:40:07 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.01.06 11:40:07 - Starting Management Interface
. 2017.01.06 11:40:07 - OpenVPN > Initialization Sequence Completed
I 2017.01.06 11:40:07 - DNS of a network adapter forced (Ethernet)
I 2017.01.06 11:40:07 - DNS of a network adapter forced (FireWire)
I 2017.01.06 11:40:08 - DNS of a network adapter forced (Wi-Fi)
I 2017.01.06 11:40:08 - DNS of a network adapter forced (Bluetooth PAN)
I 2017.01.06 11:40:08 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2017.01.06 11:40:08 - Flushing DNS
I 2017.01.06 11:40:08 - Checking route
W 2017.01.06 11:40:40 - Error: ConnectFailure (Network is unreachable)
! 2017.01.06 11:40:40 - Disconnecting
. 2017.01.06 11:40:40 - Management - Send 'signal SIGTERM'
. 2017.01.06 11:40:40 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.01.06 11:40:40 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 11:40:40 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.06 11:40:45 - OpenVPN > /sbin/route delete -net 184.75.221.42 192.168.1.1 255.255.255.255
. 2017.01.06 11:40:45 - OpenVPN > delete net 184.75.221.42: gateway 192.168.1.1
. 2017.01.06 11:40:45 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.01.06 11:40:45 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.01.06 11:40:45 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.01.06 11:40:45 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.01.06 11:40:45 - OpenVPN > Closing TUN/TAP interface
. 2017.01.06 11:40:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.06 11:40:45 - Connection terminated.
I 2017.01.06 11:40:45 - DNS of a network adapter restored to original settings (Ethernet)
I 2017.01.06 11:40:45 - DNS of a network adapter restored to original settings (FireWire)
I 2017.01.06 11:40:45 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2017.01.06 11:40:45 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2017.01.06 11:40:45 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2017.01.06 11:40:45 - Cancel requested.
I 2017.01.06 11:40:45 - IPv6 restored on network adapter (Ethernet)
I 2017.01.06 11:40:45 - IPv6 restored on network adapter (FireWire)
I 2017.01.06 11:40:45 - IPv6 restored on network adapter (Wi-Fi)
I 2017.01.06 11:40:45 - IPv6 restored on network adapter (Bluetooth PAN)
I 2017.01.06 11:40:46 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2017.01.06 11:40:46 - Session terminated.
. 2017.01.06 11:44:21 - Systems & servers data update completed
I 2017.01.06 11:45:10 - Session starting.
I 2017.01.06 11:45:10 - IPv6 disabled on network adapter (Ethernet)
I 2017.01.06 11:45:10 - IPv6 disabled on network adapter (FireWire)
I 2017.01.06 11:45:10 - IPv6 disabled on network adapter (Wi-Fi)
I 2017.01.06 11:45:10 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2017.01.06 11:45:10 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2017.01.06 11:45:10 - Checking authorization ...
! 2017.01.06 11:45:11 - Connecting to Sualocin (Canada, Toronto, Ontario)
. 2017.01.06 11:45:11 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2017.01.06 11:45:11 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2017.01.06 11:45:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104
. 2017.01.06 11:45:11 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.01.06 11:45:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:45:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:45:11 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2017.01.06 11:45:11 - OpenVPN > UDPv4 link local: [undef]
. 2017.01.06 11:45:11 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.221.42:443
. 2017.01.06 11:45:11 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.42:443, sid=85e2653d 2f4d5a4e
. 2017.01.06 11:45:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 11:45:12 - OpenVPN > Validating certificate key usage
. 2017.01.06 11:45:12 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 11:45:12 - OpenVPN > VERIFY KU OK
. 2017.01.06 11:45:12 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 11:45:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 11:45:12 - OpenVPN > VERIFY EKU OK
. 2017.01.06 11:45:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.01.06 11:45:15 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 11:45:15 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:45:15 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 11:45:15 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:45:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 11:45:15 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.42:443
. 2017.01.06 11:45:17 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 11:45:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.52.209 255.255.0.0'
. 2017.01.06 11:45:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 11:45:18 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.01.06 11:45:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 11:45:18 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 11:45:18 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 11:45:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 11:45:18 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2017.01.06 11:45:18 - OpenVPN > Opened utun device utun2
. 2017.01.06 11:45:18 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 11:45:18 - OpenVPN > /sbin/ifconfig utun2 delete
. 2017.01.06 11:45:18 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.01.06 11:45:18 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.01.06 11:45:18 - OpenVPN > /sbin/ifconfig utun2 10.4.52.209 10.4.52.209 netmask 255.255.0.0 mtu 1500 up
. 2017.01.06 11:45:18 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.52.209 255.255.0.0
. 2017.01.06 11:45:18 - OpenVPN > route: writing to routing socket: File exists
. 2017.01.06 11:45:18 - OpenVPN > add net 10.4.0.0: gateway 10.4.52.209: File exists
. 2017.01.06 11:45:18 - OpenVPN > /sbin/route add -net 184.75.221.42 192.168.1.1 255.255.255.255
. 2017.01.06 11:45:18 - OpenVPN > add net 184.75.221.42: gateway 192.168.1.1
. 2017.01.06 11:45:18 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.01.06 11:45:18 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.01.06 11:45:18 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.01.06 11:45:18 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.01.06 11:45:18 - Starting Management Interface
. 2017.01.06 11:45:18 - OpenVPN > Initialization Sequence Completed
I 2017.01.06 11:45:18 - DNS of a network adapter forced (Ethernet)
I 2017.01.06 11:45:18 - DNS of a network adapter forced (FireWire)
I 2017.01.06 11:45:18 - DNS of a network adapter forced (Wi-Fi)
I 2017.01.06 11:45:18 - DNS of a network adapter forced (Bluetooth PAN)
I 2017.01.06 11:45:19 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2017.01.06 11:45:19 - Flushing DNS
I 2017.01.06 11:45:19 - Checking route
W 2017.01.06 11:45:49 - Error: ConnectFailure (Network is unreachable)
! 2017.01.06 11:45:49 - Disconnecting
. 2017.01.06 11:45:49 - Management - Send 'signal SIGTERM'
. 2017.01.06 11:45:49 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.01.06 11:45:49 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 11:45:49 - OpenVPN > SIGTERM received, sending exit notification to peer
Then uncheck "checking route" in the Eddie advanced settings. Maybe also disable IPv6. But you didn't past the logs from line one .
Are you unable to connect to WiFi or something? Try a wired connection please.
