Not connected, Your IP: 52.14.224.197
okcomputer
ANSWERED Another question regarding speed
Using tunnelblick on macOS sierra.  I'm hardwired into a gigabit fiber connection and just can't get more than 90mb/s.  Is there anything I can do to increase speed, or am I pushing the limitations of the network?  Can I connect to 3 servers simultaneously in order to get more throughput?  Any advice is appreciated.
The client with the 256k buffers boosts speeds to about 170Mb/s.  Definitely a better result.  Are there any other optimizations I can try in order to get closer to my actual line speed?
