Not connected, Your IP: 52.14.126.74
I just bought a subscription to airvpn but unfortunately I can't connect to internet
I am on Ubuntu 16.04.1. My attempts :
- I tried with the terminal. here is the log :
pc@computer:~/DL$ openvpn AirVPN_BE-Brussels_Diadema_UDP-443.ovpn
Fri Dec 30 23:50:51 2016 OpenVPN 2.3.10 i686-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Feb  2 2016
Fri Dec 30 23:50:51 2016 library versions: OpenSSL 1.0.2g  1 Mar 2016, LZO 2.08
Fri Dec 30 23:50:51 2016 Control Channel Authentication: tls-auth using INLINE static key file
Fri Dec 30 23:50:51 2016 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Dec 30 23:50:51 2016 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Dec 30 23:50:51 2016 Socket Buffers: R=[163840->163840] S=[163840->163840]
Fri Dec 30 23:50:51 2016 UDPv4 link local: [undef]
Fri Dec 30 23:50:51 2016 UDPv4 link remote: [AF_INET]194.187.251.162:443
Fri Dec 30 23:50:51 2016 TLS: Initial packet from [AF_INET]194.187.251.162:443, sid=f969fb38 f697c7be
Fri Dec 30 23:50:51 2016 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Fri Dec 30 23:50:51 2016 Validating certificate key usage
Fri Dec 30 23:50:51 2016 ++ Certificate has key usage  00a0, expects 00a0
Fri Dec 30 23:50:51 2016 VERIFY KU OK
Fri Dec 30 23:50:51 2016 Validating certificate extended key usage
Fri Dec 30 23:50:51 2016 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Fri Dec 30 23:50:51 2016 VERIFY EKU OK
Fri Dec 30 23:50:51 2016 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Fri Dec 30 23:50:52 2016 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri Dec 30 23:50:52 2016 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Dec 30 23:50:52 2016 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri Dec 30 23:50:52 2016 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Dec 30 23:50:52 2016 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Fri Dec 30 23:50:52 2016 [server] Peer Connection Initiated with [AF_INET]194.187.251.162:443
Fri Dec 30 23:50:54 2016 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Fri Dec 30 23:50:54 2016 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.8.248 255.255.0.0'
Fri Dec 30 23:50:54 2016 OPTIONS IMPORT: timers and/or timeouts modified
Fri Dec 30 23:50:54 2016 OPTIONS IMPORT: LZO parms modified
Fri Dec 30 23:50:54 2016 OPTIONS IMPORT: --ifconfig/up options modified
Fri Dec 30 23:50:54 2016 OPTIONS IMPORT: route options modified
Fri Dec 30 23:50:54 2016 OPTIONS IMPORT: route-related options modified
Fri Dec 30 23:50:54 2016 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Fri Dec 30 23:50:54 2016 ROUTE_GATEWAY 192.168.1.254/255.255.255.0 IFACE=wlp6s0 HWADDR=xx:xx:xx:xx:xx:xx
Fri Dec 30 23:50:54 2016 ERROR: Cannot ioctl TUNSETIFF tun: Operation not permitted (errno=1)
Fri Dec 30 23:50:54 2016 Exiting due to fatal error
- I tried with the client. The .ded (stable AND experimental) didn't want to install on the system.
- I tried with portable client (stable AND experimental) but when I launch "airvpn" nothing happens.
- I tried with the network-manager. Importing the config file was a success and I passed to connect to the VPN  ..... Yes, but all websites are unreachable (DNS issue because I can ping a specific IP) :
   # I wrote in the settings in the networkmanager the dns server (10.4.0.1). Same issue : DNS does not work.
   # I changed the nameserver in the resolv.conf .... but same thing the DNS doe not do the job.
So i need help. What can I do now ?
A new member a bit confused
Download the experimental version (click on "Other versions" + "Experimental" before downloading your version -32 or 64 bits-). Then right click on the deb file and open it with the installer, type your password and done. Don't forget to activate network lock before connecting to some server.
Do you have an installer program such as gdebi available? If not, do download it. Although it should've come with your distro.
Have you tried launching AirVPN from the terminal, so that you'll perhaps see any error messages? When you tried to install the .deb experimental, did you get any notifications?
That last line is also interesting. Are you running as root?
I can't remember if Eddie has problems with the network manager; I seem to remember something regarding that.
The problem is that, trying to execute it from the terminal without sudo, but doing it graphically as I said is easier in Ubuntu (I did it in the same operative system), the installer will appear with the program to install and clicking to install will ask for your password.
First, thank you guys
Before your answers I had modified my /etc/network/interfaces
now, it is like this :
[main]
plugins=ifupdown,keyfile,ofono
#dns=dnsmasq
[ifupdown]
managed=true
All my tests on airvpn were unsuccessful. BUT I passed to connect to another vpn (a little free vpn that I occasionally use) which had the same issue and was unable to connect to internet.
To fix that, you need to run it as root.
I launched my openvpnconfig into the terminal as root ... and it worked !
It is a good thing even if I find that through the terminal is not very useful (lack of visibility connection/disconnection)
Next attempt :
 launched the portable client from the terminal and thanks to the error message, I noticed that I downloaded the wrong file (32/64 bits) ... ewww my bad
Now the portable client (stable version) works !
In progress :
So, now, only the connection through the network-manager does not work but of course it is my favourite method.
If you any idea for the network-manager, thank you, if not, at least I can use my connection by different ways.
Thank you all
I recommend you to use Eddie with network lock always. But if you want to use the network manager (I read in some other place it's not safe) then check if you added lzo compression or not (but use it disabled).
yeah what pr1v said
i've been around linux a few days
and i still can't handle network-mangler
that's the first thing i do on any distro
i remove that app before it sends me into
a rehab or mental institution
cheerz
