Almost forgot the log file ^^ here it is.
I 2016.12.30 01:58:54 - Session starting.
I 2016.12.30 01:58:55 - Checking authorization ...
! 2016.12.30 01:58:55 - Connecting to Alphirk (Netherlands, Alblasserdam)
. 2016.12.30 01:58:55 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2016.12.30 01:58:55 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.30 01:58:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.30 01:58:55 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.30 01:58:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 01:58:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 01:58:55 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.12.30 01:58:55 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.30 01:58:55 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.146:443
. 2016.12.30 01:58:55 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.146:443, sid=5cc7b138 f5eebba5
. 2016.12.30 01:58:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.12.30 01:58:55 - OpenVPN > Validating certificate key usage
. 2016.12.30 01:58:55 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.12.30 01:58:55 - OpenVPN > VERIFY KU OK
. 2016.12.30 01:58:55 - OpenVPN > Validating certificate extended key usage
. 2016.12.30 01:58:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.12.30 01:58:55 - OpenVPN > VERIFY EKU OK
. 2016.12.30 01:58:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.12.30 01:58:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.30 01:58:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 01:58:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.30 01:58:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 01:58:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.12.30 01:58:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.146:443
. 2016.12.30 01:58:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.12.30 01:58:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.65 255.255.0.0'
. 2016.12.30 01:58:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.12.30 01:58:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.12.30 01:58:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.12.30 01:58:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.12.30 01:58:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.12.30 01:58:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.12.30 01:58:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.12.30 01:58:58 - OpenVPN > open_tun, tt->ipv6=0
. 2016.12.30 01:58:58 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{E87C0A88-EE44-4992-B367-8C7423473C58}.tap
. 2016.12.30 01:58:58 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.12.30 01:58:58 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.6.65/255.255.0.0 [SUCCEEDED]
. 2016.12.30 01:58:58 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.6.65/255.255.0.0 on interface {E87C0A88-EE44-4992-B367-8C7423473C58} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.12.30 01:58:58 - OpenVPN > Successful ARP Flush on interface [14] {E87C0A88-EE44-4992-B367-8C7423473C58}
. 2016.12.30 01:59:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:03 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:08 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:09 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:10 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:11 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:13 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:14 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:15 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:15 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 01:59:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:16 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:16 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 01:59:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:17 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:17 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 203 ms
. 2016.12.30 01:59:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:18 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:18 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 01:59:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:19 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:20 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 01:59:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:21 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:21 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 187 ms
. 2016.12.30 01:59:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:22 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:22 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 203 ms
. 2016.12.30 01:59:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:23 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:23 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 203 ms
. 2016.12.30 01:59:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:25 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:25 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 01:59:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:26 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:26 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 01:59:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:27 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:27 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 01:59:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:28 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:28 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 01:59:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:29 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:30 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 01:59:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:31 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:31 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 391 ms
. 2016.12.30 01:59:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 01:59:32 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 01:59:32 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 547 ms
. 2016.12.30 01:59:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 01:59:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 109.202.107.146 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 01:59:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.12.30 01:59:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.12.30 01:59:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 10
. 2016.12.30 01:59:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 01:59:33 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2016.12.30 01:59:33 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.12.30 01:59:33 - OpenVPN > Route addition fallback to route.exe
. 2016.12.30 01:59:33 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.12.30 01:59:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 01:59:33 - OpenVPN > SYSTEM ROUTING TABLE
. 2016.12.30 01:59:33 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=10 t=4 pr=3 a=120090 h=0 m=25/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 25.0.0.0 255.0.0.0 25.60.1.95 p=0 i=4 t=3 pr=2 a=32708 h=0 m=271/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 25.60.1.95 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32708 h=0 m=271/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 25.255.255.255 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32708 h=0 m=271/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 109.202.107.146 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 109.232.227.132 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=4056280 h=0 m=25/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196168 h=0 m=331/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196168 h=0 m=331/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196168 h=0 m=331/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.27.75 p=0 i=14 t=3 pr=2 a=32 h=0 m=291/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 169.254.27.75 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=32 h=0 m=291/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=32 h=0 m=291/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.101 p=0 i=10 t=3 pr=2 a=120090 h=0 m=281/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 192.168.0.101 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=120090 h=0 m=281/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=120090 h=0 m=281/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196168 h=0 m=331/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.101 p=0 i=10 t=3 pr=2 a=4196157 h=0 m=281/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 224.0.0.0 240.0.0.0 25.60.1.95 p=0 i=4 t=3 pr=2 a=32717 h=0 m=271/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.27.75 p=0 i=14 t=3 pr=2 a=43 h=0 m=291/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196168 h=0 m=331/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=4196157 h=0 m=281/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 255.255.255.255 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32717 h=0 m=271/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=43 h=0 m=291/0/0/0/0
. 2016.12.30 01:59:33 - OpenVPN > SYSTEM ADAPTER LIST
. 2016.12.30 01:59:33 - OpenVPN > Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30)
. 2016.12.30 01:59:33 - OpenVPN > Index = 10
. 2016.12.30 01:59:33 - OpenVPN > GUID = {C1766D18-32F5-4C39-BFAE-184F5422DDB3}
. 2016.12.30 01:59:33 - OpenVPN > IP = 192.168.0.101/255.255.255.0
. 2016.12.30 01:59:33 - OpenVPN > MAC = d0:50:99:77:c3:c0
. 2016.12.30 01:59:33 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255
. 2016.12.30 01:59:33 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255
. 2016.12.30 01:59:33 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 30 01:57:32 2016
. 2016.12.30 01:59:33 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 31 01:57:32 2016
. 2016.12.30 01:59:33 - OpenVPN > DNS SERV = 192.168.0.1/255.255.255.255
. 2016.12.30 01:59:33 - OpenVPN > TAP-Windows Adapter V9
. 2016.12.30 01:59:33 - OpenVPN > Index = 14
. 2016.12.30 01:59:33 - OpenVPN > GUID = {E87C0A88-EE44-4992-B367-8C7423473C58}
. 2016.12.30 01:59:33 - OpenVPN > IP = 169.254.27.75/255.255.0.0
. 2016.12.30 01:59:33 - OpenVPN > MAC = 00:ff:e8:7c:0a:88
. 2016.12.30 01:59:33 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255
. 2016.12.30 01:59:33 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 30 01:59:33 2016
. 2016.12.30 01:59:33 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 30 01:59:33 2016
. 2016.12.30 01:59:33 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255
. 2016.12.30 01:59:33 - OpenVPN > LogMeIn Hamachi Virtual Ethernet Adapter
. 2016.12.30 01:59:33 - OpenVPN > Index = 4
. 2016.12.30 01:59:33 - OpenVPN > GUID = {30A6C0C4-771A-45C4-B41C-ACD3D1514DF5}
. 2016.12.30 01:59:33 - OpenVPN > IP = 25.60.1.95/255.0.0.0
. 2016.12.30 01:59:33 - OpenVPN > MAC = 7a:79:19:3c:01:5f
. 2016.12.30 01:59:33 - OpenVPN > DHCP SERV = 25.0.0.1/255.255.255.255
. 2016.12.30 01:59:33 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 29 16:54:24 2016
. 2016.12.30 01:59:33 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 29 16:54:24 2017
. 2016.12.30 01:59:33 - Starting Management Interface
I 2016.12.30 01:59:33 - DNS of a network adapter forced (TAP-Windows Adapter V9)
! 2016.12.30 01:59:33 - Disconnecting
. 2016.12.30 01:59:33 - Management - Send 'signal SIGTERM'
. 2016.12.30 01:59:33 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2016.12.30 01:59:33 - DNS of a network adapter forced (Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30))
I 2016.12.30 01:59:33 - Flushing DNS
. 2016.12.30 01:59:34 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 344 ms
. 2016.12.30 01:59:34 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.12.30 01:59:34 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.12.30 01:59:34 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.30 01:59:38 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 109.202.107.146 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 01:59:38 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.12.30 01:59:38 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 01:59:38 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 01:59:38 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2016.12.30 01:59:38 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2016.12.30 01:59:38 - OpenVPN > Route deletion fallback to route.exe
. 2016.12.30 01:59:38 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.12.30 01:59:38 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 01:59:38 - OpenVPN > Closing TUN/TAP interface
. 2016.12.30 01:59:38 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.12.30 01:59:38 - Connection terminated.
I 2016.12.30 01:59:38 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.12.30 01:59:38 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30))
I 2016.12.30 01:59:38 - Cancel requested.
. 2016.12.30 01:59:39 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 360 ms
! 2016.12.30 01:59:39 - Session terminated.
I 2016.12.30 02:00:13 - Session starting.
. 2016.12.30 02:00:13 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 125 ms
I 2016.12.30 02:00:13 - Checking authorization ...
! 2016.12.30 02:00:13 - Connecting to Alphirk (Netherlands, Alblasserdam)
. 2016.12.30 02:00:13 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2016.12.30 02:00:13 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.30 02:00:13 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.30 02:00:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.30 02:00:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:00:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:00:14 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.12.30 02:00:14 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.30 02:00:14 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.146:443
. 2016.12.30 02:00:14 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.146:443, sid=eb70728a 4ffca26c
. 2016.12.30 02:00:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.12.30 02:00:14 - OpenVPN > Validating certificate key usage
. 2016.12.30 02:00:14 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.12.30 02:00:14 - OpenVPN > VERIFY KU OK
. 2016.12.30 02:00:14 - OpenVPN > Validating certificate extended key usage
. 2016.12.30 02:00:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.12.30 02:00:14 - OpenVPN > VERIFY EKU OK
. 2016.12.30 02:00:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.12.30 02:00:14 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.30 02:00:14 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:00:14 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.30 02:00:14 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:00:14 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.12.30 02:00:14 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.146:443
. 2016.12.30 02:00:16 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.12.30 02:00:16 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.65 255.255.0.0'
. 2016.12.30 02:00:16 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.12.30 02:00:16 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.12.30 02:00:16 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.12.30 02:00:16 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.12.30 02:00:16 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.12.30 02:00:16 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.12.30 02:00:16 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.12.30 02:00:16 - OpenVPN > open_tun, tt->ipv6=0
. 2016.12.30 02:00:16 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{E87C0A88-EE44-4992-B367-8C7423473C58}.tap
. 2016.12.30 02:00:16 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.12.30 02:00:16 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.6.65/255.255.0.0 [SUCCEEDED]
. 2016.12.30 02:00:16 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.6.65/255.255.0.0 on interface {E87C0A88-EE44-4992-B367-8C7423473C58} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.12.30 02:00:16 - OpenVPN > Successful ARP Flush on interface [14] {E87C0A88-EE44-4992-B367-8C7423473C58}
. 2016.12.30 02:00:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:22 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:22 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 219 ms
. 2016.12.30 02:00:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:26 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:26 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 187 ms
. 2016.12.30 02:00:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:27 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:27 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:00:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:28 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:28 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 02:00:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:29 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:30 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 782 ms
. 2016.12.30 02:00:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:30 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:31 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 1079 ms
. 2016.12.30 02:00:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:31 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:32 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 422 ms
. 2016.12.30 02:00:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:32 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:34 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 1218 ms
. 2016.12.30 02:00:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:34 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:35 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 1343 ms
. 2016.12.30 02:00:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:36 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:37 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 1079 ms
. 2016.12.30 02:00:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:37 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:37 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 703 ms
. 2016.12.30 02:00:38 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:38 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 781 ms
. 2016.12.30 02:00:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:39 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 985 ms
. 2016.12.30 02:00:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:40 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:40 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 531 ms
. 2016.12.30 02:00:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:41 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 218 ms
. 2016.12.30 02:00:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:42 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:42 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 02:00:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:43 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:43 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:00:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:44 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:44 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 203 ms
. 2016.12.30 02:00:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:45 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:45 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 203 ms
. 2016.12.30 02:00:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:46 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:46 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:00:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:47 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:47 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 02:00:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:48 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:48 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 02:00:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:00:49 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:00:50 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 02:00:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:00:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 109.202.107.146 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 02:00:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.12.30 02:00:51 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.12.30 02:00:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 10
. 2016.12.30 02:00:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:00:51 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2016.12.30 02:00:51 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.12.30 02:00:51 - OpenVPN > Route addition fallback to route.exe
. 2016.12.30 02:00:51 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.12.30 02:00:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:00:51 - OpenVPN > SYSTEM ROUTING TABLE
. 2016.12.30 02:00:51 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=10 t=4 pr=3 a=120167 h=0 m=25/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 25.0.0.0 255.0.0.0 25.60.1.95 p=0 i=4 t=3 pr=2 a=32785 h=0 m=271/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 25.60.1.95 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32785 h=0 m=271/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 25.255.255.255 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32785 h=0 m=271/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 109.202.107.146 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 109.232.227.132 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=4056357 h=0 m=25/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196245 h=0 m=331/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196245 h=0 m=331/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196245 h=0 m=331/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.27.75 p=0 i=14 t=3 pr=2 a=109 h=0 m=291/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 169.254.27.75 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=109 h=0 m=291/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=109 h=0 m=291/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.101 p=0 i=10 t=3 pr=2 a=120167 h=0 m=281/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 192.168.0.101 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=120167 h=0 m=281/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=120167 h=0 m=281/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196245 h=0 m=331/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.101 p=0 i=10 t=3 pr=2 a=4196234 h=0 m=281/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 224.0.0.0 240.0.0.0 25.60.1.95 p=0 i=4 t=3 pr=2 a=32794 h=0 m=271/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.27.75 p=0 i=14 t=3 pr=2 a=120 h=0 m=291/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196245 h=0 m=331/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=4196234 h=0 m=281/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 255.255.255.255 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32794 h=0 m=271/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=120 h=0 m=291/0/0/0/0
. 2016.12.30 02:00:51 - OpenVPN > SYSTEM ADAPTER LIST
. 2016.12.30 02:00:51 - OpenVPN > Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30)
. 2016.12.30 02:00:51 - OpenVPN > Index = 10
. 2016.12.30 02:00:51 - OpenVPN > GUID = {C1766D18-32F5-4C39-BFAE-184F5422DDB3}
. 2016.12.30 02:00:51 - OpenVPN > IP = 192.168.0.101/255.255.255.0
. 2016.12.30 02:00:51 - OpenVPN > MAC = d0:50:99:77:c3:c0
. 2016.12.30 02:00:51 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255
. 2016.12.30 02:00:51 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255
. 2016.12.30 02:00:51 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 30 01:59:38 2016
. 2016.12.30 02:00:51 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 31 01:59:38 2016
. 2016.12.30 02:00:51 - OpenVPN > DNS SERV = 192.168.0.1/255.255.255.255
. 2016.12.30 02:00:51 - OpenVPN > TAP-Windows Adapter V9
. 2016.12.30 02:00:51 - OpenVPN > Index = 14
. 2016.12.30 02:00:51 - OpenVPN > GUID = {E87C0A88-EE44-4992-B367-8C7423473C58}
. 2016.12.30 02:00:51 - OpenVPN > IP = 169.254.27.75/255.255.0.0
. 2016.12.30 02:00:51 - OpenVPN > MAC = 00:ff:e8:7c:0a:88
. 2016.12.30 02:00:51 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255
. 2016.12.30 02:00:51 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 30 02:00:51 2016
. 2016.12.30 02:00:51 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 30 02:00:51 2016
. 2016.12.30 02:00:51 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255
. 2016.12.30 02:00:51 - OpenVPN > LogMeIn Hamachi Virtual Ethernet Adapter
. 2016.12.30 02:00:51 - OpenVPN > Index = 4
. 2016.12.30 02:00:51 - OpenVPN > GUID = {30A6C0C4-771A-45C4-B41C-ACD3D1514DF5}
. 2016.12.30 02:00:51 - OpenVPN > IP = 25.60.1.95/255.0.0.0
. 2016.12.30 02:00:51 - OpenVPN > MAC = 7a:79:19:3c:01:5f
. 2016.12.30 02:00:51 - OpenVPN > DHCP SERV = 25.0.0.1/255.255.255.255
. 2016.12.30 02:00:51 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 29 16:54:24 2016
. 2016.12.30 02:00:51 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 29 16:54:24 2017
. 2016.12.30 02:00:51 - Starting Management Interface
I 2016.12.30 02:00:51 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.12.30 02:00:51 - DNS of a network adapter forced (Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30))
! 2016.12.30 02:00:51 - Disconnecting
. 2016.12.30 02:00:51 - Management - Send 'signal SIGTERM'
. 2016.12.30 02:00:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2016.12.30 02:00:51 - Flushing DNS
. 2016.12.30 02:00:51 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 78 ms
. 2016.12.30 02:00:51 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.12.30 02:00:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.12.30 02:00:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.30 02:00:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 109.202.107.146 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 02:00:56 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.12.30 02:00:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 02:00:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:00:56 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2016.12.30 02:00:56 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2016.12.30 02:00:56 - OpenVPN > Route deletion fallback to route.exe
. 2016.12.30 02:00:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.12.30 02:00:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:00:56 - OpenVPN > Closing TUN/TAP interface
. 2016.12.30 02:00:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.12.30 02:00:56 - Connection terminated.
I 2016.12.30 02:00:56 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.12.30 02:00:56 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30))
I 2016.12.30 02:00:59 - Checking authorization ...
! 2016.12.30 02:01:00 - Connecting to Alphirk (Netherlands, Alblasserdam)
. 2016.12.30 02:01:00 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2016.12.30 02:01:00 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.30 02:01:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.30 02:01:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.30 02:01:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:01:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:01:00 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.12.30 02:01:00 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.30 02:01:00 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.146:443
. 2016.12.30 02:01:00 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.146:443, sid=30c906ff 17800250
. 2016.12.30 02:01:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.12.30 02:01:01 - OpenVPN > Validating certificate key usage
. 2016.12.30 02:01:01 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.12.30 02:01:01 - OpenVPN > VERIFY KU OK
. 2016.12.30 02:01:01 - OpenVPN > Validating certificate extended key usage
. 2016.12.30 02:01:01 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.12.30 02:01:01 - OpenVPN > VERIFY EKU OK
. 2016.12.30 02:01:01 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.12.30 02:01:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.30 02:01:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:01:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.30 02:01:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:01:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.12.30 02:01:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.146:443
. 2016.12.30 02:01:03 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.12.30 02:01:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.65 255.255.0.0'
. 2016.12.30 02:01:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.12.30 02:01:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.12.30 02:01:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.12.30 02:01:03 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.12.30 02:01:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.12.30 02:01:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.12.30 02:01:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.12.30 02:01:03 - OpenVPN > open_tun, tt->ipv6=0
. 2016.12.30 02:01:03 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{E87C0A88-EE44-4992-B367-8C7423473C58}.tap
. 2016.12.30 02:01:03 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.12.30 02:01:03 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.6.65/255.255.0.0 [SUCCEEDED]
. 2016.12.30 02:01:03 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.6.65/255.255.0.0 on interface {E87C0A88-EE44-4992-B367-8C7423473C58} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.12.30 02:01:03 - OpenVPN > Successful ARP Flush on interface [14] {E87C0A88-EE44-4992-B367-8C7423473C58}
. 2016.12.30 02:01:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:08 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:09 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 187 ms
. 2016.12.30 02:01:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:13 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:13 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:01:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:14 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:14 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:01:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:15 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:15 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:01:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:16 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:16 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:01:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:17 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:17 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 203 ms
. 2016.12.30 02:01:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:18 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:18 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 157 ms
. 2016.12.30 02:01:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:19 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:19 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 282 ms
. 2016.12.30 02:01:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:20 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:21 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 375 ms
. 2016.12.30 02:01:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:21 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:22 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 406 ms
. 2016.12.30 02:01:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:22 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:23 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 406 ms
. 2016.12.30 02:01:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:23 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:24 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 375 ms
. 2016.12.30 02:01:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:24 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:25 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 375 ms
. 2016.12.30 02:01:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:25 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:26 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 390 ms
. 2016.12.30 02:01:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:26 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:27 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 390 ms
. 2016.12.30 02:01:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:27 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:28 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 438 ms
. 2016.12.30 02:01:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:28 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:28 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 187 ms
. 2016.12.30 02:01:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:29 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:29 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 203 ms
. 2016.12.30 02:01:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:30 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:30 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 171 ms
. 2016.12.30 02:01:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:31 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:31 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:01:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:32 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:32 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:01:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:33 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:33 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:01:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:35 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:35 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:01:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:36 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:36 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:01:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:37 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:37 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:01:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 109.202.107.146 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 02:01:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.12.30 02:01:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.12.30 02:01:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 10
. 2016.12.30 02:01:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:01:38 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2016.12.30 02:01:38 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.12.30 02:01:38 - OpenVPN > Route addition fallback to route.exe
. 2016.12.30 02:01:38 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.12.30 02:01:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:01:38 - OpenVPN > SYSTEM ROUTING TABLE
. 2016.12.30 02:01:38 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=10 t=4 pr=3 a=120215 h=0 m=25/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 25.0.0.0 255.0.0.0 25.60.1.95 p=0 i=4 t=3 pr=2 a=32833 h=0 m=271/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 25.60.1.95 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32833 h=0 m=271/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 25.255.255.255 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32833 h=0 m=271/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 109.202.107.146 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 109.232.227.132 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=4056405 h=0 m=25/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196293 h=0 m=331/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196293 h=0 m=331/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196293 h=0 m=331/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.27.75 p=0 i=14 t=3 pr=2 a=157 h=0 m=291/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 169.254.27.75 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=157 h=0 m=291/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=157 h=0 m=291/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.101 p=0 i=10 t=3 pr=2 a=120215 h=0 m=281/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 192.168.0.101 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=120215 h=0 m=281/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=120215 h=0 m=281/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196293 h=0 m=331/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.101 p=0 i=10 t=3 pr=2 a=4196282 h=0 m=281/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 224.0.0.0 240.0.0.0 25.60.1.95 p=0 i=4 t=3 pr=2 a=32842 h=0 m=271/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.27.75 p=0 i=14 t=3 pr=2 a=168 h=0 m=291/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196293 h=0 m=331/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=4196282 h=0 m=281/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 255.255.255.255 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32842 h=0 m=271/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=168 h=0 m=291/0/0/0/0
. 2016.12.30 02:01:38 - OpenVPN > SYSTEM ADAPTER LIST
. 2016.12.30 02:01:38 - OpenVPN > Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30)
. 2016.12.30 02:01:38 - OpenVPN > Index = 10
. 2016.12.30 02:01:38 - OpenVPN > GUID = {C1766D18-32F5-4C39-BFAE-184F5422DDB3}
. 2016.12.30 02:01:38 - OpenVPN > IP = 192.168.0.101/255.255.255.0
. 2016.12.30 02:01:38 - OpenVPN > MAC = d0:50:99:77:c3:c0
. 2016.12.30 02:01:38 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255
. 2016.12.30 02:01:38 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255
. 2016.12.30 02:01:38 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 30 02:00:56 2016
. 2016.12.30 02:01:38 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 31 02:00:56 2016
. 2016.12.30 02:01:38 - OpenVPN > DNS SERV = 192.168.0.1/255.255.255.255
. 2016.12.30 02:01:38 - OpenVPN > TAP-Windows Adapter V9
. 2016.12.30 02:01:38 - OpenVPN > Index = 14
. 2016.12.30 02:01:38 - OpenVPN > GUID = {E87C0A88-EE44-4992-B367-8C7423473C58}
. 2016.12.30 02:01:38 - OpenVPN > IP = 169.254.27.75/255.255.0.0
. 2016.12.30 02:01:38 - OpenVPN > MAC = 00:ff:e8:7c:0a:88
. 2016.12.30 02:01:38 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255
. 2016.12.30 02:01:38 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 30 02:01:38 2016
. 2016.12.30 02:01:38 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 30 02:01:38 2016
. 2016.12.30 02:01:38 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255
. 2016.12.30 02:01:38 - OpenVPN > LogMeIn Hamachi Virtual Ethernet Adapter
. 2016.12.30 02:01:38 - OpenVPN > Index = 4
. 2016.12.30 02:01:38 - OpenVPN > GUID = {30A6C0C4-771A-45C4-B41C-ACD3D1514DF5}
. 2016.12.30 02:01:38 - OpenVPN > IP = 25.60.1.95/255.0.0.0
. 2016.12.30 02:01:38 - OpenVPN > MAC = 7a:79:19:3c:01:5f
. 2016.12.30 02:01:38 - OpenVPN > DHCP SERV = 25.0.0.1/255.255.255.255
. 2016.12.30 02:01:38 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 29 16:54:24 2016
. 2016.12.30 02:01:38 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 29 16:54:24 2017
. 2016.12.30 02:01:38 - Starting Management Interface
I 2016.12.30 02:01:38 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.12.30 02:01:38 - DNS of a network adapter forced (Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30))
! 2016.12.30 02:01:38 - Disconnecting
. 2016.12.30 02:01:38 - Management - Send 'signal SIGTERM'
. 2016.12.30 02:01:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2016.12.30 02:01:38 - Flushing DNS
. 2016.12.30 02:01:38 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 78 ms
. 2016.12.30 02:01:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.12.30 02:01:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.12.30 02:01:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.30 02:01:43 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 109.202.107.146 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 02:01:43 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.12.30 02:01:43 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 02:01:43 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:01:43 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2016.12.30 02:01:43 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2016.12.30 02:01:43 - OpenVPN > Route deletion fallback to route.exe
. 2016.12.30 02:01:43 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.12.30 02:01:43 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:01:43 - OpenVPN > Closing TUN/TAP interface
. 2016.12.30 02:01:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.12.30 02:01:43 - Connection terminated.
I 2016.12.30 02:01:43 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.12.30 02:01:43 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30))
I 2016.12.30 02:01:46 - Checking authorization ...
! 2016.12.30 02:01:47 - Connecting to Alphirk (Netherlands, Alblasserdam)
. 2016.12.30 02:01:47 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2016.12.30 02:01:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.30 02:01:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.30 02:01:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.30 02:01:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:01:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:01:47 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.12.30 02:01:47 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.30 02:01:47 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.146:443
. 2016.12.30 02:01:47 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.146:443, sid=640e41e7 860fd499
. 2016.12.30 02:01:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.12.30 02:01:47 - OpenVPN > Validating certificate key usage
. 2016.12.30 02:01:47 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.12.30 02:01:47 - OpenVPN > VERIFY KU OK
. 2016.12.30 02:01:47 - OpenVPN > Validating certificate extended key usage
. 2016.12.30 02:01:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.12.30 02:01:47 - OpenVPN > VERIFY EKU OK
. 2016.12.30 02:01:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.12.30 02:01:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.30 02:01:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:01:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.30 02:01:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.30 02:01:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.12.30 02:01:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.146:443
. 2016.12.30 02:01:50 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.12.30 02:01:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.65 255.255.0.0'
. 2016.12.30 02:01:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.12.30 02:01:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.12.30 02:01:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.12.30 02:01:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.12.30 02:01:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.12.30 02:01:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.12.30 02:01:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.12.30 02:01:50 - OpenVPN > open_tun, tt->ipv6=0
. 2016.12.30 02:01:50 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{E87C0A88-EE44-4992-B367-8C7423473C58}.tap
. 2016.12.30 02:01:50 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.12.30 02:01:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.6.65/255.255.0.0 [SUCCEEDED]
. 2016.12.30 02:01:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.6.65/255.255.0.0 on interface {E87C0A88-EE44-4992-B367-8C7423473C58} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.12.30 02:01:50 - OpenVPN > Successful ARP Flush on interface [14] {E87C0A88-EE44-4992-B367-8C7423473C58}
. 2016.12.30 02:01:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:01:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:01:55 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:01:56 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 391 ms
. 2016.12.30 02:02:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:00 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:00 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 02:02:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:01 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:01 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 188 ms
. 2016.12.30 02:02:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:02 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:02 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:02:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:03 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:03 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:02:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:04 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:05 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:02:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:05 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:06 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:02:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:07 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:07 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:02:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:08 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:08 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 204 ms
. 2016.12.30 02:02:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:09 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:09 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:02:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:10 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:10 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 219 ms
. 2016.12.30 02:02:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:11 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:11 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 219 ms
. 2016.12.30 02:02:12 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:12 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:12 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:12 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 171 ms
. 2016.12.30 02:02:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:13 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:14 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:02:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:15 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:15 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:02:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:16 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:16 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 172 ms
. 2016.12.30 02:02:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:17 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:18 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 500 ms
. 2016.12.30 02:02:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:18 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:19 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 453 ms
. 2016.12.30 02:02:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:19 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:20 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 406 ms
. 2016.12.30 02:02:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:20 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:20 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 407 ms
. 2016.12.30 02:02:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:21 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:22 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 438 ms
. 2016.12.30 02:02:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:22 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:23 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 437 ms
. 2016.12.30 02:02:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.12.30 02:02:23 - AirVPN Windows Interface Hack executed (Ethernet 2)
. 2016.12.30 02:02:24 - Shell of 'cmd.exe','/c netsh interface set interface "Ethernet 2" ENABLED' done sync in 375 ms
. 2016.12.30 02:02:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.12.30 02:02:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 109.202.107.146 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 02:02:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.12.30 02:02:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.12.30 02:02:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 10
. 2016.12.30 02:02:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:02:25 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2016.12.30 02:02:25 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.12.30 02:02:25 - OpenVPN > Route addition fallback to route.exe
. 2016.12.30 02:02:25 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.12.30 02:02:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:02:25 - OpenVPN > SYSTEM ROUTING TABLE
. 2016.12.30 02:02:25 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=10 t=4 pr=3 a=120261 h=0 m=25/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 25.0.0.0 255.0.0.0 25.60.1.95 p=0 i=4 t=3 pr=2 a=32879 h=0 m=271/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 25.60.1.95 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32879 h=0 m=271/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 25.255.255.255 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32879 h=0 m=271/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 109.202.107.146 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 109.232.227.132 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=4056451 h=0 m=25/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196339 h=0 m=331/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196339 h=0 m=331/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196339 h=0 m=331/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.27.75 p=0 i=14 t=3 pr=2 a=203 h=0 m=291/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 169.254.27.75 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=203 h=0 m=291/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=203 h=0 m=291/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.101 p=0 i=10 t=3 pr=2 a=120261 h=0 m=281/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 192.168.0.101 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=120261 h=0 m=281/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=120261 h=0 m=281/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196339 h=0 m=331/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.101 p=0 i=10 t=3 pr=2 a=4196328 h=0 m=281/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 224.0.0.0 240.0.0.0 25.60.1.95 p=0 i=4 t=3 pr=2 a=32888 h=0 m=271/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.27.75 p=0 i=14 t=3 pr=2 a=214 h=0 m=291/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4196339 h=0 m=331/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.101 p=0 i=10 t=3 pr=2 a=4196328 h=0 m=281/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 255.255.255.255 255.255.255.255 25.60.1.95 p=0 i=4 t=3 pr=2 a=32888 h=0 m=271/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.27.75 p=0 i=14 t=3 pr=2 a=214 h=0 m=291/0/0/0/0
. 2016.12.30 02:02:25 - OpenVPN > SYSTEM ADAPTER LIST
. 2016.12.30 02:02:25 - OpenVPN > Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30)
. 2016.12.30 02:02:25 - OpenVPN > Index = 10
. 2016.12.30 02:02:25 - OpenVPN > GUID = {C1766D18-32F5-4C39-BFAE-184F5422DDB3}
. 2016.12.30 02:02:25 - OpenVPN > IP = 192.168.0.101/255.255.255.0
. 2016.12.30 02:02:25 - OpenVPN > MAC = d0:50:99:77:c3:c0
. 2016.12.30 02:02:25 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255
. 2016.12.30 02:02:25 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255
. 2016.12.30 02:02:25 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 30 02:01:43 2016
. 2016.12.30 02:02:25 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 31 02:01:43 2016
. 2016.12.30 02:02:25 - OpenVPN > DNS SERV = 192.168.0.1/255.255.255.255
. 2016.12.30 02:02:25 - OpenVPN > TAP-Windows Adapter V9
. 2016.12.30 02:02:25 - OpenVPN > Index = 14
. 2016.12.30 02:02:25 - OpenVPN > GUID = {E87C0A88-EE44-4992-B367-8C7423473C58}
. 2016.12.30 02:02:25 - OpenVPN > IP = 169.254.27.75/255.255.0.0
. 2016.12.30 02:02:25 - OpenVPN > MAC = 00:ff:e8:7c:0a:88
. 2016.12.30 02:02:25 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255
. 2016.12.30 02:02:25 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 30 02:02:25 2016
. 2016.12.30 02:02:25 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 30 02:02:25 2016
. 2016.12.30 02:02:25 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255
. 2016.12.30 02:02:25 - OpenVPN > LogMeIn Hamachi Virtual Ethernet Adapter
. 2016.12.30 02:02:25 - OpenVPN > Index = 4
. 2016.12.30 02:02:25 - OpenVPN > GUID = {30A6C0C4-771A-45C4-B41C-ACD3D1514DF5}
. 2016.12.30 02:02:25 - OpenVPN > IP = 25.60.1.95/255.0.0.0
. 2016.12.30 02:02:25 - OpenVPN > MAC = 7a:79:19:3c:01:5f
. 2016.12.30 02:02:25 - OpenVPN > DHCP SERV = 25.0.0.1/255.255.255.255
. 2016.12.30 02:02:25 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 29 16:54:24 2016
. 2016.12.30 02:02:25 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 29 16:54:24 2017
. 2016.12.30 02:02:25 - Starting Management Interface
! 2016.12.30 02:02:25 - Disconnecting
. 2016.12.30 02:02:25 - Management - Send 'signal SIGTERM'
. 2016.12.30 02:02:25 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2016.12.30 02:02:25 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.12.30 02:02:25 - DNS of a network adapter forced (Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30))
I 2016.12.30 02:02:25 - Flushing DNS
. 2016.12.30 02:02:26 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 344 ms
. 2016.12.30 02:02:26 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.12.30 02:02:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.12.30 02:02:26 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.30 02:02:30 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 109.202.107.146 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 02:02:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.12.30 02:02:30 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.12.30 02:02:30 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:02:30 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2016.12.30 02:02:30 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2016.12.30 02:02:30 - OpenVPN > Route deletion fallback to route.exe
. 2016.12.30 02:02:30 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.12.30 02:02:30 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.30 02:02:30 - OpenVPN > Closing TUN/TAP interface
. 2016.12.30 02:02:30 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.12.30 02:02:30 - Connection terminated.
I 2016.12.30 02:02:30 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.12.30 02:02:30 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30))
I 2016.12.30 02:02:30 - Cancel requested.
. 2016.12.30 02:02:30 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 78 ms
! 2016.12.30 02:02:30 - Session terminated.
