Not connected, Your IP: 3.139.97.157
airvpn_go
Eddite 2.11 not work on win10, but 2.10 work well
Today, i downloaded and installed Eddite 2.11 for windows , but it not work,  2.10 work well. And then,  Eddite 2.11 for macOS, work well .
I submit the log of Eddite 2.11 for windows as attach.
Would you help me out this problem?
Eddie_20161209_130900.txt
Windows WFP, Add rule failed: Interface ID '' unknown or disabled for the layer.:<rule name="Dns - Allow port 53 on TAP - IPv4" layer="ale_auth_recv_accept_v4" action="permit" weight="auto"><if field="ip_remote_port" match="equal" port="53" /><if field="ip_local_interface" match="equal" interface="" /></rule>
Is the only suspicious thing I could find. It could look like Eddie can't find your interface ID or can't understand it. Perhaps you can try going to Eddie>Preferences>Advanced  and disabling WFP (if it's checked).
Have you tried using a different protocol? What version of Eddie 2.11.x is this?
W 2016.12.09 13:08:34 - Windows WFP, Add rule failed: Interface ID '' unknown or disabled for the layer.:<rule name="Dns - Allow port 53 on TAP - IPv4" layer="ale_auth_recv_accept_v4" action="permit" weight="auto"><if field="ip_remote_port" match="equal" port="53" /><if field="ip_local_interface" match="equal" interface="" /></rule>
Yep, this line. You could try a few things:
  • Make sure you are using the most recent version of .NET framework for your Windows version.
  • Try using Network Lock with Windows Firewall (can be set in Preferences > Network Lock > Mode: Windows Firewall)
Thank LZ1 and giganerd, Eddite 2.11 is able to work after i disabled WFP.
Thank you very much !
To LZ1:
I use Eddite 2.11.9,  Protocol: SSL 443
Yup the experimental release is not working for me on WIN 10 either.  It keeps flashing 'object not set to instance of an object' or something then locks up.  I've tried installing it twice, to no avail.
EDIT - Just tried reinstalling it - I don't think I was using the experimental release the last time. It seems to be working now
