underxposedbody 1 Posted ... Hi I have never been able to connect with the AirVPN client on OSX Sierra. It connects through the Windows client, Tunnelblick and OpenVPN but I would like to use the AirVPN client for more control. Can someone please suggest something. Here's my log: I 2016.12.08 01:57:36 - AirVPN client version: 2.10.3 / x86, System: OSX, Name: 10.12.1 / x64. 2016.12.08 01:57:36 - Reading options from /Users/XXX/.airvpn/AirVPN.xml. 2016.12.08 01:57:36 - Data Path: /Users/XXX/.airvpn. 2016.12.08 01:57:36 - App Path: /Applications/AirVPN.app/Contents/MacOS. 2016.12.08 01:57:36 - Executable Path: /Applications/AirVPN.app/Contents/MacOS/AirVPN. 2016.12.08 01:57:36 - Command line arguments (1): gui.osx.style="dark". 2016.12.08 01:57:36 - Updating systems & servers data .... 2016.12.08 01:57:36 - Operating System: Unix 16.1.0.0 - Darwin XXXXX.local 16.1.0 Darwin Kernel Version 16.1.0: Thu Oct 13 21:26:57 PDT 2016; root:xnu-3789.21.3~60/RELEASE_X86_64 x86_64I 2016.12.08 01:57:36 - OpenVPN Driver - ExpectedI 2016.12.08 01:57:36 - OpenVPN - Version: OpenVPN 2.3.8 (/Applications/AirVPN.app/Contents/MacOS/openvpn)I 2016.12.08 01:57:36 - SSH - Version: OpenSSH_7.2p2, LibreSSL 2.4.1 (/usr/bin/ssh)I 2016.12.08 01:57:36 - SSL - Version: stunnel 5.17 (/Applications/AirVPN.app/Contents/MacOS/stunnel)I 2016.12.08 01:57:36 - Session starting.. 2016.12.08 01:57:36 - Systems & servers data update completedI 2016.12.08 01:57:40 - Checking authorization ...! 2016.12.08 01:57:40 - Connecting to Alphard (Netherlands, Alblasserdam). 2016.12.08 01:57:40 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.08 01:57:40 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 01:57:40 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: nodename nor servname provided, or not known. 2016.12.08 01:57:40 - OpenVPN > Exiting due to fatal error! 2016.12.08 01:57:40 - Disconnecting. 2016.12.08 01:57:40 - Connection terminated.I 2016.12.08 01:57:43 - Checking authorization ...! 2016.12.08 01:57:44 - Connecting to Alphard (Netherlands, Alblasserdam). 2016.12.08 01:57:44 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.08 01:57:44 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 01:57:44 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: nodename nor servname provided, or not known. 2016.12.08 01:57:44 - OpenVPN > Exiting due to fatal error! 2016.12.08 01:57:44 - Disconnecting. 2016.12.08 01:57:44 - Connection terminated.I 2016.12.08 01:57:45 - Cancel requested.! 2016.12.08 01:57:45 - Session terminated.I 2016.12.08 02:00:07 - Session starting.I 2016.12.08 02:00:07 - Checking authorization ...! 2016.12.08 02:00:07 - Connecting to Alphard (Netherlands, Alblasserdam). 2016.12.08 02:00:07 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.08 02:00:08 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 02:00:08 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: nodename nor servname provided, or not known. 2016.12.08 02:00:08 - OpenVPN > Exiting due to fatal error! 2016.12.08 02:00:08 - Disconnecting. 2016.12.08 02:00:08 - Connection terminated.I 2016.12.08 02:00:11 - Checking authorization ...! 2016.12.08 02:00:11 - Connecting to Alphard (Netherlands, Alblasserdam). 2016.12.08 02:00:11 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.08 02:00:11 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 02:00:11 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: nodename nor servname provided, or not known. 2016.12.08 02:00:11 - OpenVPN > Exiting due to fatal error! 2016.12.08 02:00:11 - Disconnecting. 2016.12.08 02:00:11 - Connection terminated.I 2016.12.08 02:00:14 - Checking authorization ...! 2016.12.08 02:00:14 - Connecting to Alphard (Netherlands, Alblasserdam). 2016.12.08 02:00:14 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.08 02:00:14 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 02:00:14 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: nodename nor servname provided, or not known. 2016.12.08 02:00:14 - OpenVPN > Exiting due to fatal error! 2016.12.08 02:00:14 - Disconnecting. 2016.12.08 02:00:14 - Connection terminated.I 2016.12.08 02:00:17 - Checking authorization ...! 2016.12.08 02:00:18 - Connecting to Alphard (Netherlands, Alblasserdam). 2016.12.08 02:00:18 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015. 2016.12.08 02:00:18 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 02:00:18 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: nodename nor servname provided, or not known. 2016.12.08 02:00:18 - OpenVPN > Exiting due to fatal error! 2016.12.08 02:00:18 - Disconnecting. 2016.12.08 02:00:18 - Connection terminated.I 2016.12.08 02:00:19 - Cancel requested.! 2016.12.08 02:00:19 - Session terminated. Quote Share this post Link to post
Keksjdjdke 35 Posted ... Try updating to the latest beta of the Eddie client. Quote Share this post Link to post
Khariz 109 Posted ... underxposedbody, You are having a DNS issue with Eddie. The DNS lookup for the servers is failing. Check the DNS settings on the adapter. But yeah, if you upgrade to the 2.11.9 experimental build, Eddie works okay in Siiera. You get some odd errors, but it pushes through, and everything works properly. 1 underxposedbody reacted to this Quote Share this post Link to post
underxposedbody 1 Posted ... Thanks for the tips. I tried the experimental version but still nothing. Then checked my adapter settings and I had set the DNS to Google's 8.8.8.8 instead of leaving it as my ISP default. Deleting this made the client work. Quote Share this post Link to post
Shamerock 1 Posted ... Not sure if I should start a new thread, but thought maybe you guys could help out if you had similar issues. So I pretty recently introduced OSx into my life. Still making adjustments, came from win where at a time I hadn't yet started to place as much on priv, anon, and security. Used to torrent a lot, god knows how much a/v i had on my now bricked hp, after, you guessed it, upgrading to Windows10. May revisit it down the line and run linux, some such. Sorry, I digress. SO, I am not sure what I'm doing wrong, and I've really been trying to beef up on reading in the forums, LZ's how to guides etc. Yet to no avail do I find myself able to connect using the air over TOR protocol successfully. I've really been trying not to ask questions since I joined the community and defer to the forums for when I do incur trouble, and as much I hate to admit it, I do need a little hand holding here. Not sure if anyone else had problems when adjusting or if I'm that much of a fucktard. Guessing its the latter. Any help much appreciated Quote Share this post Link to post
LZ1 662 Posted ... Not sure if I should start a new thread, but thought maybe you guys could help out if you had similar issues. So I pretty recently introduced OSx into my life. Still making adjustments, came from win where at a time I hadn't yet started to place as much on priv, anon, and security. Used to torrent a lot, god knows how much a/v i had on my now bricked hp, after, you guessed it, upgrading to Windows10. May revisit it down the line and run linux, some such. Sorry, I digress. SO, I am not sure what I'm doing wrong, and I've really been trying to beef up on reading in the forums, LZ's how to guides etc. Yet to no avail do I find myself able to connect using the air over TOR protocol successfully. I've really been trying not to ask questions since I joined the community and defer to the forums for when I do incur trouble, and as much I hate to admit it, I do need a little hand holding here. Not sure if anyone else had problems when adjusting or if I'm that much of a fucktard. Guessing its the latter. Any help much appreciatedHello! Presuming you're using the Eddie 2.10 client, you go to the Protocols section, click Tor, save and then open the Tor browser. Then back to the client and click the "test" button in the same area. Or does this not work? Do you get any error messages or such? No need to be so hard on yourself my friend. It can be confusing going to a different system . Since you've tried to find the information you needed without luck, you already earned the right to ask for help, for sure ^^. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Staff 9750 Posted ... . 2016.12.08 01:57:40 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: nodename nor servname provided, or not known Hello! The problem is showed in the quoted log entry: your system can't resolve "localhost". Somehow your system hosts file has been wrongly modified, or corrupted. Please make sure that in your hosts file the first hosts block line is:127.0.0.1 localhost How to edit hosts file in various Mac systems:https://www.tekrevue.com/tip/edit-hosts-file-mac-os-x/ Kind regards Quote Share this post Link to post
Shamerock 1 Posted ... Not sure if I should start a new thread, but thought maybe you guys could help out if you had similar issues. So I pretty recently introduced OSx into my life. Still making adjustments, came from win where at a time I hadn't yet started to place as much on priv, anon, and security. Used to torrent a lot, god knows how much a/v i had on my now bricked hp, after, you guessed it, upgrading to Windows10. May revisit it down the line and run linux, some such. Sorry, I digress. SO, I am not sure what I'm doing wrong, and I've really been trying to beef up on reading in the forums, LZ's how to guides etc. Yet to no avail do I find myself able to connect using the air over TOR protocol successfully. I've really been trying not to ask questions since I joined the community and defer to the forums for when I do incur trouble, and as much I hate to admit it, I do need a little hand holding here. Not sure if anyone else had problems when adjusting or if I'm that much of a fucktard. Guessing its the latter. Any help much appreciatedHello! Presuming you're using the Eddie 2.10 client, you go to the Protocols section, click Tor, save and then open the Tor browser. Then back to the client and click the "test" button in the same area. Or does this not work? Do you get any error messages or such? No need to be so hard on yourself my friend. It can be confusing going to a different system . Since you've tried to find the information you needed without luck, you already earned the right to ask for help, for sure ^^. Hello my good man,I much appreciate teh response, and I would have gotten back sooner but I've taken ill over the past several weeks. Right around the time I made the post, and it has been a roller coaster since. But the strange southwest weather and people can't kill me. Anyway so following those steps, it reads in the initial start up status window: establishing an encrypted directory connection. Please wait while we establish a connection to the Tor network, this may take several minutes. browser logs - logs1/13/17, 12:34:11.300 [NOTICE] Bootstrapped 5%: Connecting to directory server1/13/17, 12:34:11.300 [NOTICE] Bootstrapped 10%: Finishing handshake with directory server1/13/17, 12:36:11.700 [NOTICE] Tried for 120 seconds to get a connection to [scrubbed]:443. Giving up. (waiting for circuit)1/13/17, 12:36:11.700 [WARN] Proxy Client: unable to connect to 171.25.193.77:443 ("TTL expired")1/13/17, 12:36:12.700 [NOTICE] Tried for 120 seconds to get a connection to [scrubbed]:443. Giving up. (waiting for circuit)1/13/17, 12:36:12.700 [WARN] Proxy Client: unable to connect to 46.28.110.244:443 ("TTL expired")1/13/17, 12:36:16.700 [NOTICE] Tried for 120 seconds to get a connection to [scrubbed]:443. Giving up. (waiting for circuit)1/13/17, 12:36:16.700 [WARN] Proxy Client: unable to connect to 195.154.79.128:443 ("TTL expired")1/13/17, 12:36:23.100 [NOTICE] Closing no-longer-configured Socks listener on 127.0.0.1:91501/13/17, 12:36:23.100 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.1/13/17, 12:36:23.100 [NOTICE] Closing old Socks listener on 127.0.0.1:91501/13/17, 12:36:23.100 [WARN] Tor cannot connect to the Internet if ReachableAddresses, ReachableORAddresses, or ReachableDirAddresses reject all addresses. Please accept some addresses in these options.1/13/17, 12:36:23.700 [NOTICE] Delaying directory fetches: DisableNetwork is set. Quote Share this post Link to post
