Not connected, Your IP: 18.218.61.16
boondangle
ANSWERED Eddie does not start in Fedora 24
When running in Fedora 24 the program doesn't start and I get the following message on the console.
This happens with both stable and unstable and portable versions
Unhandled Exception:
System.IO.IOException: Invalid handle to path "/home/anthony/Downloads/[unknown]"
  at System.IO.FileStream.ReadData (System.Runtime.InteropServices.SafeHandle safeHandle, System.Byte[] buf, Int32 offset, Int32 count) <0x40ae2b50 + 0x000a3> in <filename unknown>:0
  at System.IO.FileStream.ReadInternal (System.Byte[] dest, Int32 offset, Int32 count) <0x40ae23a0 + 0x0007b> in <filename unknown>:0
  at System.IO.FileStream.Read (System.Byte[] array, Int32 offset, Int32 count) <0x40ae20d0 + 0x000ef> in <filename unknown>:0
  at System.IO.StreamReader.ReadBuffer () <0x40ae8230 + 0x00363> in <filename unknown>:0
  at System.IO.StreamReader.Read () <0x40b3e860 + 0x00063> in <filename unknown>:0
  at System.TermInfoDriver.GetCursorPosition () <0x40b92fd0 + 0x000a0> in <filename unknown>:0
  at System.TermInfoDriver.Init () <0x40b91620 + 0x008db> in <filename unknown>:0
  at System.ConsoleDriver.Init () <0x40b915c0 + 0x00023> in <filename unknown>:0
  at System.Console.add_CancelKeyPress (System.ConsoleCancelEventHandler value) <0x40b91450 + 0x0001f> in <filename unknown>:0
  at Eddie.Core.Engine.Initialization (Boolean cli) <0x40b818d0 + 0x00223> in <filename unknown>:0
  at Eddie.UI.Linux.Program.Main () <0x40acbe90 + 0x00187> in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.IO.IOException: Invalid handle to path "/home/anthony/Downloads/[unknown]"
Any ideas as to how to fix this?
Are you using the Experimental Eddie client?
Ah wayland. It has caused problems for others too. You can check the Eddie beta thread about that, if you want to post it.
Anytime my friend.
