I am on the new Eddie beta and i cannot connect via Tor when it is using a obfs bridge. The error reads that it cannot identify the first node in the established circuit. Is this a bug or does AirVPN only work over non obfuscated tor? Log is bellow
I 2016.11.20 16:16:06 - Eddie client version: 2.11.7 / windows_x64, System: Windows, Name: Microsoft Windows NT 10.0.14393.0
. 2016.11.20 16:16:06 - Reading options from C:\Users\M3CHWARRI0R935\AppData\Local\AirVPN\AirVPN.xml
. 2016.11.20 16:16:06 - Data Path: C:\Users\M3CHWARRI0R935\AppData\Local\AirVPN
. 2016.11.20 16:16:06 - App Path: C:\Program Files\AirVPN
. 2016.11.20 16:16:06 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.11.20 16:16:06 - Command line arguments (1): path="home"
. 2016.11.20 16:16:06 - Operating System: Microsoft Windows NT 10.0.14393.0
I 2016.11.20 16:16:06 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2016.11.20 16:16:06 - OpenVPN - Version: 2.3.13 - OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.11.20 16:16:06 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2016.11.20 16:16:06 - SSL - Version: stunnel 5.37 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.11.20 16:16:06 - Activation of Network Lock - Windows Filtering Platform
! 2016.11.20 16:16:07 - Ready
. 2016.11.20 16:16:07 - Updating systems & servers data ...
I 2016.11.20 16:16:17 - Session starting.
. 2016.11.20 16:16:17 - IPv6 disabled with packet filtering.
I 2016.11.20 16:16:17 - Checking authorization ...
. 2016.11.20 16:17:03 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (curl: (7) Failed to receive SOCKS4 connect request ack., with 'socks' proxy and 'none' auth)
W 2016.11.20 16:17:03 - Authorization check failed, continue anyway ({1])
I 2016.11.20 16:17:03 - Cancel requested.
. 2016.11.20 16:17:03 - IPv6 restored with packet filtering.
! 2016.11.20 16:17:03 - Session terminated.
! 2016.11.20 16:17:07 - Deactivation of Network Lock
I 2016.11.20 16:17:42 - Session starting.
. 2016.11.20 16:17:42 - IPv6 disabled with packet filtering.
I 2016.11.20 16:17:42 - Checking authorization ...
! 2016.11.20 16:17:43 - Connecting to Hamal (Switzerland, Zurich)
. 2016.11.20 16:17:43 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016
. 2016.11.20 16:17:43 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2016.11.20 16:17:43 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2016.11.20 16:17:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.20 16:17:43 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.20 16:17:43 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:17:43 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:17:43 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2016.11.20 16:17:43 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:9150 [nonblock]
. 2016.11.20 16:17:43 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:9150
. 2016.11.20 16:17:45 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.11.20 16:17:45 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9150
. 2016.11.20 16:17:45 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:9150, sid=a30f1ab4 4d335e9d
. 2016.11.20 16:17:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.20 16:17:46 - OpenVPN > Validating certificate key usage
. 2016.11.20 16:17:46 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.20 16:17:46 - OpenVPN > VERIFY KU OK
. 2016.11.20 16:17:46 - OpenVPN > Validating certificate extended key usage
. 2016.11.20 16:17:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.20 16:17:46 - OpenVPN > VERIFY EKU OK
. 2016.11.20 16:17:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.20 16:17:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.20 16:17:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:17:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.20 16:17:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:17:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.20 16:17:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9150
. 2016.11.20 16:17:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.20 16:17:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.0.8 255.255.0.0'
. 2016.11.20 16:17:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.20 16:17:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.20 16:17:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.20 16:17:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.20 16:17:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.20 16:17:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.20 16:17:50 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=17 HWADDR=d0:17:c2:86:0d:25
. 2016.11.20 16:17:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.20 16:17:50 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.20 16:17:50 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5A56F43F-C323-4E15-ACAB-2724F9D83812}.tap
. 2016.11.20 16:17:50 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.20 16:17:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.0.8/255.255.0.0 [sUCCEEDED]
. 2016.11.20 16:17:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.0.8/255.255.0.0 on interface {5A56F43F-C323-4E15-ACAB-2724F9D83812} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2016.11.20 16:17:50 - OpenVPN > Successful ARP Flush on interface [6] {5A56F43F-C323-4E15-ACAB-2724F9D83812}
. 2016.11.20 16:17:55 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.11.20 16:17:55 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.11.20 16:17:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.20 16:17:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.20 16:17:55 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.11.20 16:17:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.20 16:17:55 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.11.20 16:17:55 - Starting Management Interface
. 2016.11.20 16:17:55 - OpenVPN > Initialization Sequence Completed
. 2016.11.20 16:17:55 - DNS leak protection with packet filtering enabled.
. 2016.11.20 16:17:55 - DNS of a network adapter forced (Intel® I211 Gigabit Network Connection, from manual (75.114.81.1,75.114.81.2) to 10.50.0.1)
I 2016.11.20 16:17:55 - Flushing DNS
! 2016.11.20 16:17:55 - Connected.
. 2016.11.20 16:17:55 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.11.20 16:17:55 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.20 16:18:14 - OpenVPN > Connection reset, restarting [0]
. 2016.11.20 16:18:14 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2016.11.20 16:18:14 - OpenVPN > Restart pause, 5 second(s)
! 2016.11.20 16:18:15 - Disconnecting
. 2016.11.20 16:18:15 - Management - Send 'signal SIGTERM'
. 2016.11.20 16:18:15 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.20 16:18:15 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.11.20 16:18:15 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.11.20 16:18:15 - OpenVPN > Assertion failed at misc.c:785 (es)
. 2016.11.20 16:18:15 - OpenVPN > Exiting due to fatal error
. 2016.11.20 16:18:15 - Connection terminated.
. 2016.11.20 16:18:15 - DNS of a network adapter restored to original settings (Intel® I211 Gigabit Network Connection, to 75.114.81.1,75.114.81.2)
. 2016.11.20 16:18:15 - DNS leak protection with packet filtering disabled.
I 2016.11.20 16:18:18 - Checking authorization ...
. 2016.11.20 16:18:39 - IPv6 restored with packet filtering.
! 2016.11.20 16:18:39 - Session terminated.
. 2016.11.20 16:18:43 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
. 2016.11.20 16:18:43 - Tor Test: Successful test. Tor Version: 0.2.8.7 (git-263088633a63982a)
I 2016.11.20 16:18:58 - Session starting.
. 2016.11.20 16:18:58 - IPv6 disabled with packet filtering.
I 2016.11.20 16:18:58 - Checking authorization ...
. 2016.11.20 16:18:59 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:18:59 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:02 - Checking authorization ...
. 2016.11.20 16:19:03 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:03 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:06 - Checking authorization ...
. 2016.11.20 16:19:06 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:06 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:09 - Checking authorization ...
. 2016.11.20 16:19:10 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:10 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:13 - Checking authorization ...
. 2016.11.20 16:19:13 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:13 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:16 - Checking authorization ...
. 2016.11.20 16:19:17 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:17 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:20 - Checking authorization ...
. 2016.11.20 16:19:20 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:20 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:23 - Checking authorization ...
. 2016.11.20 16:19:24 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:24 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:27 - Checking authorization ...
. 2016.11.20 16:19:27 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:27 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:30 - Checking authorization ...
. 2016.11.20 16:19:31 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:31 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:34 - Checking authorization ...
. 2016.11.20 16:19:34 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:34 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:37 - Checking authorization ...
. 2016.11.20 16:19:38 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:38 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:41 - Checking authorization ...
. 2016.11.20 16:19:41 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:41 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:44 - Checking authorization ...
. 2016.11.20 16:19:45 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:45 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:48 - Checking authorization ...
. 2016.11.20 16:19:48 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:48 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:51 - Checking authorization ...
. 2016.11.20 16:19:52 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:52 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:55 - Checking authorization ...
. 2016.11.20 16:19:55 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:55 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:19:58 - Checking authorization ...
. 2016.11.20 16:19:59 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:19:59 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:20:02 - Checking authorization ...
. 2016.11.20 16:20:02 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:20:02 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:20:03 - Cancel requested.
. 2016.11.20 16:20:03 - IPv6 restored with packet filtering.
! 2016.11.20 16:20:03 - Session terminated.
. 2016.11.20 16:20:28 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
. 2016.11.20 16:20:28 - Tor Test: Successful test. Tor Version: 0.2.8.7 (git-263088633a63982a)
I 2016.11.20 16:20:40 - Session starting.
. 2016.11.20 16:20:40 - IPv6 disabled with packet filtering.
I 2016.11.20 16:20:40 - Checking authorization ...
! 2016.11.20 16:20:40 - Connecting to Hamal (Switzerland, Zurich)
. 2016.11.20 16:20:40 - SSL > 2016.11.20 16:20:40 LOG5[ui]: stunnel 5.37 on x86-pc-mingw32-gnu platform
. 2016.11.20 16:20:40 - SSL > 2016.11.20 16:20:40 LOG5[ui]: Compiled/running with OpenSSL 1.0.2j  26 Sep 2016
. 2016.11.20 16:20:40 - SSL > 2016.11.20 16:20:40 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.11.20 16:20:40 - SSL > 2016.11.20 16:20:40 LOG5[ui]: Reading configuration from file C:\Users\M3CHWARRI0R935\AppData\Local\AirVPN\feeb3a551e3656516314ff5af4689220b56f5540714f87b565aef88dc503e290.tmp.ssl
. 2016.11.20 16:20:40 - SSL > 2016.11.20 16:20:40 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.11.20 16:20:40 - SSL > 2016.11.20 16:20:40 LOG6[ui]: Initializing service [openvpn]
. 2016.11.20 16:20:40 - SSL > 2016.11.20 16:20:40 LOG5[ui]: Configuration successful
. 2016.11.20 16:20:40 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016
. 2016.11.20 16:20:40 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2016.11.20 16:20:40 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2016.11.20 16:20:40 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.20 16:20:41 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.20 16:20:41 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:20:41 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:20:41 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2016.11.20 16:20:41 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:10223 [nonblock]
. 2016.11.20 16:20:41 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:10223
. 2016.11.20 16:20:41 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.11.20 16:20:41 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:10223
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:58110
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG6[0]: s_connect: connecting 185.156.175.44:443
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG5[0]: s_connect: connected 185.156.175.44:443
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.2:58111
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG6[0]: SNI: sending servername: 185.156.175.44
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG6[0]: Peer certificate required
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG6[0]: CERT: Locally installed certificate matched
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG6[0]: Client certificate not requested
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG6[0]: SSL connected: new session negotiated
. 2016.11.20 16:20:41 - SSL > 2016.11.20 16:20:41 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.11.20 16:20:41 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:10223, sid=68003b72 94079eda
. 2016.11.20 16:20:41 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.20 16:20:41 - OpenVPN > Validating certificate key usage
. 2016.11.20 16:20:41 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.20 16:20:41 - OpenVPN > VERIFY KU OK
. 2016.11.20 16:20:41 - OpenVPN > Validating certificate extended key usage
. 2016.11.20 16:20:41 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.20 16:20:41 - OpenVPN > VERIFY EKU OK
. 2016.11.20 16:20:41 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.20 16:20:42 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.20 16:20:42 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:20:42 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.20 16:20:42 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:20:42 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.20 16:20:42 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:10223
. 2016.11.20 16:20:44 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.20 16:20:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.0.8 255.255.0.0'
. 2016.11.20 16:20:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.20 16:20:45 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.20 16:20:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.20 16:20:45 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.20 16:20:45 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.20 16:20:45 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.20 16:20:45 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=17 HWADDR=d0:17:c2:86:0d:25
. 2016.11.20 16:20:45 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.20 16:20:45 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.20 16:20:45 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5A56F43F-C323-4E15-ACAB-2724F9D83812}.tap
. 2016.11.20 16:20:45 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.20 16:20:45 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.0.8/255.255.0.0 [sUCCEEDED]
. 2016.11.20 16:20:45 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.0.8/255.255.0.0 on interface {5A56F43F-C323-4E15-ACAB-2724F9D83812} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2016.11.20 16:20:45 - OpenVPN > Successful ARP Flush on interface [6] {5A56F43F-C323-4E15-ACAB-2724F9D83812}
. 2016.11.20 16:20:50 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2016.11.20 16:20:50 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.11.20 16:20:50 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=17]
. 2016.11.20 16:20:50 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.11.20 16:20:50 - OpenVPN > Route addition fallback to route.exe
. 2016.11.20 16:20:50 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2016.11.20 16:20:50 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.11.20 16:20:50 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=6]
. 2016.11.20 16:20:50 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.11.20 16:20:50 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.44 MASK 255.255.255.255 192.168.0.1
. 2016.11.20 16:20:50 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.20 16:20:50 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.20 16:20:50 - Starting Management Interface
. 2016.11.20 16:20:50 - OpenVPN > Initialization Sequence Completed
. 2016.11.20 16:20:50 - DNS leak protection with packet filtering enabled.
. 2016.11.20 16:20:50 - DNS of a network adapter forced (Intel® I211 Gigabit Network Connection, from manual (75.114.81.1,75.114.81.2) to 10.50.0.1)
I 2016.11.20 16:20:51 - Flushing DNS
I 2016.11.20 16:20:51 - Checking route
I 2016.11.20 16:20:52 - Checking DNS
! 2016.11.20 16:20:53 - Connected.
. 2016.11.20 16:20:53 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.11.20 16:20:53 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2016.11.20 16:21:02 - Disconnecting
. 2016.11.20 16:21:02 - Management - Send 'signal SIGTERM'
. 2016.11.20 16:21:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.20 16:21:02 - SSL > 2016.11.20 16:21:02 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2016.11.20 16:21:02 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.44 MASK 255.255.255.255 192.168.0.1
. 2016.11.20 16:21:02 - SSL > 2016.11.20 16:21:02 LOG5[0]: Connection reset: 14246 byte(s) sent to SSL, 31054 byte(s) sent to socket
. 2016.11.20 16:21:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.20 16:21:02 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.11.20 16:21:02 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.11.20 16:21:02 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.11.20 16:21:02 - OpenVPN > Closing TUN/TAP interface
. 2016.11.20 16:21:02 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.11.20 16:21:02 - Connection terminated.
. 2016.11.20 16:21:02 - DNS of a network adapter restored to original settings (Intel® I211 Gigabit Network Connection, to 75.114.81.1,75.114.81.2)
. 2016.11.20 16:21:02 - DNS leak protection with packet filtering disabled.
. 2016.11.20 16:21:02 - IPv6 restored with packet filtering.
! 2016.11.20 16:21:03 - Session terminated.
! 2016.11.20 16:21:05 - Activation of Network Lock - Windows Filtering Platform
I 2016.11.20 16:21:06 - Session starting.
. 2016.11.20 16:21:07 - IPv6 disabled with packet filtering.
I 2016.11.20 16:21:07 - Checking authorization ...
! 2016.11.20 16:21:07 - Connecting to Hamal (Switzerland, Zurich)
. 2016.11.20 16:21:07 - SSL > 2016.11.20 16:21:07 LOG5[ui]: stunnel 5.37 on x86-pc-mingw32-gnu platform
. 2016.11.20 16:21:07 - SSL > 2016.11.20 16:21:07 LOG5[ui]: Compiled/running with OpenSSL 1.0.2j  26 Sep 2016
. 2016.11.20 16:21:07 - SSL > 2016.11.20 16:21:07 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.11.20 16:21:07 - SSL > 2016.11.20 16:21:07 LOG5[ui]: Reading configuration from file C:\Users\M3CHWARRI0R935\AppData\Local\AirVPN\22d74ef001e6d4cdf488445fd0769db55489cc4aa318894a4790d18cf7b03661.tmp.ssl
. 2016.11.20 16:21:07 - SSL > 2016.11.20 16:21:07 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.11.20 16:21:07 - SSL > 2016.11.20 16:21:07 LOG6[ui]: Initializing service [openvpn]
. 2016.11.20 16:21:07 - SSL > 2016.11.20 16:21:07 LOG5[ui]: Configuration successful
. 2016.11.20 16:21:07 - OpenVPN > OpenVPN 2.3.13 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Nov 10 2016
. 2016.11.20 16:21:07 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2016.11.20 16:21:07 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2016.11.20 16:21:07 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.20 16:21:07 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.20 16:21:07 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:21:07 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:21:07 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2016.11.20 16:21:07 - SSL > 2016.11.20 16:21:07 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:58156
. 2016.11.20 16:21:07 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:58247 [nonblock]
. 2016.11.20 16:21:07 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:58247
. 2016.11.20 16:21:07 - SSL > 2016.11.20 16:21:07 LOG6[0]: s_connect: connecting 185.156.175.44:443
. 2016.11.20 16:21:07 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.11.20 16:21:07 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:58247
. 2016.11.20 16:21:08 - SSL > 2016.11.20 16:21:08 LOG5[0]: s_connect: connected 185.156.175.44:443
. 2016.11.20 16:21:08 - SSL > 2016.11.20 16:21:08 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.2:58157
. 2016.11.20 16:21:08 - SSL > 2016.11.20 16:21:08 LOG6[0]: SNI: sending servername: 185.156.175.44
. 2016.11.20 16:21:08 - SSL > 2016.11.20 16:21:08 LOG6[0]: Peer certificate required
. 2016.11.20 16:21:08 - SSL > 2016.11.20 16:21:08 LOG6[0]: CERT: Locally installed certificate matched
. 2016.11.20 16:21:08 - SSL > 2016.11.20 16:21:08 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.11.20 16:21:08 - SSL > 2016.11.20 16:21:08 LOG6[0]: Client certificate not requested
. 2016.11.20 16:21:08 - SSL > 2016.11.20 16:21:08 LOG6[0]: SSL connected: new session negotiated
. 2016.11.20 16:21:08 - SSL > 2016.11.20 16:21:08 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.11.20 16:21:08 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:58247, sid=640a5d20 072a4038
. 2016.11.20 16:21:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.20 16:21:08 - OpenVPN > Validating certificate key usage
. 2016.11.20 16:21:08 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.20 16:21:08 - OpenVPN > VERIFY KU OK
. 2016.11.20 16:21:08 - OpenVPN > Validating certificate extended key usage
. 2016.11.20 16:21:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.20 16:21:08 - OpenVPN > VERIFY EKU OK
. 2016.11.20 16:21:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.20 16:21:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.20 16:21:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:21:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.20 16:21:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.20 16:21:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.20 16:21:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:58247
. 2016.11.20 16:21:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.20 16:21:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.0.8 255.255.0.0'
. 2016.11.20 16:21:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.20 16:21:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.20 16:21:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.20 16:21:11 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.20 16:21:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.20 16:21:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.20 16:21:11 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=17 HWADDR=d0:17:c2:86:0d:25
. 2016.11.20 16:21:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.20 16:21:11 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.20 16:21:11 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5A56F43F-C323-4E15-ACAB-2724F9D83812}.tap
. 2016.11.20 16:21:11 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.20 16:21:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.0.8/255.255.0.0 [sUCCEEDED]
. 2016.11.20 16:21:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.0.8/255.255.0.0 on interface {5A56F43F-C323-4E15-ACAB-2724F9D83812} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2016.11.20 16:21:11 - OpenVPN > Successful ARP Flush on interface [6] {5A56F43F-C323-4E15-ACAB-2724F9D83812}
. 2016.11.20 16:21:16 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2016.11.20 16:21:16 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.11.20 16:21:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.20 16:21:16 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.20 16:21:16 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.11.20 16:21:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.20 16:21:16 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.11.20 16:21:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.20 16:21:17 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.20 16:21:17 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.44 MASK 255.255.255.255 192.168.0.1
. 2016.11.20 16:21:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.20 16:21:17 - Starting Management Interface
. 2016.11.20 16:21:17 - OpenVPN > Initialization Sequence Completed
. 2016.11.20 16:21:17 - DNS leak protection with packet filtering enabled.
. 2016.11.20 16:21:17 - DNS of a network adapter forced (Intel® I211 Gigabit Network Connection, from manual (75.114.81.1,75.114.81.2) to 10.50.0.1)
I 2016.11.20 16:21:17 - Flushing DNS
I 2016.11.20 16:21:17 - Checking route
I 2016.11.20 16:21:18 - Checking DNS
! 2016.11.20 16:21:18 - Connected.
. 2016.11.20 16:21:18 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.11.20 16:21:18 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.20 16:22:07 - SSL > 2016.11.20 16:22:07 LOG6[cron]: Executing cron jobs
. 2016.11.20 16:22:07 - SSL > 2016.11.20 16:22:07 LOG6[cron]: Cron jobs completed in 0 seconds
! 2016.11.20 16:22:39 - Disconnecting
. 2016.11.20 16:22:39 - Management - Send 'signal SIGTERM'
. 2016.11.20 16:22:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.20 16:22:39 - SSL > 2016.11.20 16:22:39 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2016.11.20 16:22:39 - SSL > 2016.11.20 16:22:39 LOG5[0]: Connection reset: 118849 byte(s) sent to SSL, 691040 byte(s) sent to socket
. 2016.11.20 16:22:39 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.44 MASK 255.255.255.255 192.168.0.1
. 2016.11.20 16:22:39 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.20 16:22:39 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.11.20 16:22:39 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.11.20 16:22:39 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2016.11.20 16:22:39 - OpenVPN > Closing TUN/TAP interface
. 2016.11.20 16:22:39 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.11.20 16:22:39 - Connection terminated.
. 2016.11.20 16:22:40 - DNS of a network adapter restored to original settings (Intel® I211 Gigabit Network Connection, to 75.114.81.1,75.114.81.2)
. 2016.11.20 16:22:40 - DNS leak protection with packet filtering disabled.
. 2016.11.20 16:22:40 - IPv6 restored with packet filtering.
! 2016.11.20 16:22:40 - Session terminated.
! 2016.11.20 16:22:41 - Deactivation of Network Lock
. 2016.11.20 16:23:02 - Tor Test: Unable to communicate with Tor (Unable to find your Tor path.). Is Tor up and running?
I 2016.11.20 16:23:29 - Session starting.
. 2016.11.20 16:23:29 - IPv6 disabled with packet filtering.
I 2016.11.20 16:23:29 - Checking authorization ...
. 2016.11.20 16:23:29 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:23:29 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:23:32 - Checking authorization ...
. 2016.11.20 16:23:33 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:23:33 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:23:36 - Checking authorization ...
. 2016.11.20 16:23:37 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:23:37 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:23:40 - Checking authorization ...
. 2016.11.20 16:23:40 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 16:23:40 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 16:23:42 - Cancel requested.
. 2016.11.20 16:23:42 - IPv6 restored with packet filtering.
! 2016.11.20 16:23:42 - Session terminated.
Are you trying to do obfs > Tor > SSL > OpenVPN?
This is not a good idea, the latency will be too high for the tunnel to work.
Connect via regular TCP 443.
No, my protocol is standard TCP 80. Tor is configured with control port 9151 and the proxy port for it is 9150.
Something times out on your side. The tunnel is successfully established and you get the 10.50.x.x IP
but then there is a timeout.
Post your Tor logs as well, and see if it works both with obfs3/obfs4.
I changed settings several times throughout that logfile. So ill show you the exact excerpt once i had the settings nailed down.
Here is the OpenVPN log first
I 2016.11.20 17:21:21 - Eddie client version: 2.11.7 / windows_x64, System: Windows, Name: Microsoft Windows NT 10.0.14393.0
. 2016.11.20 17:21:21 - Reading options from C:\Users\M3CHWARRI0R935\AppData\Local\AirVPN\AirVPN.xml
. 2016.11.20 17:21:21 - Data Path: C:\Users\M3CHWARRI0R935\AppData\Local\AirVPN
. 2016.11.20 17:21:21 - App Path: C:\Program Files\AirVPN
. 2016.11.20 17:21:21 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.11.20 17:21:21 - Command line arguments (1): path="home"
. 2016.11.20 17:21:21 - Operating System: Microsoft Windows NT 10.0.14393.0
I 2016.11.20 17:21:22 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2016.11.20 17:21:22 - OpenVPN - Version: 2.3.13 - OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.11.20 17:21:22 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2016.11.20 17:21:22 - SSL - Version: stunnel 5.37 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.11.20 17:21:22 - Activation of Network Lock - Windows Filtering Platform
! 2016.11.20 17:21:22 - Ready
. 2016.11.20 17:21:22 - Updating systems & servers data ...
. 2016.11.20 17:21:23 - Systems & servers data update completed
I 2016.11.20 17:21:24 - Session starting.
. 2016.11.20 17:21:24 - IPv6 disabled with packet filtering.
I 2016.11.20 17:21:24 - Checking authorization ...
. 2016.11.20 17:21:25 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 17:21:25 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 17:21:28 - Checking authorization ...
. 2016.11.20 17:21:28 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 17:21:28 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 17:21:31 - Checking authorization ...
. 2016.11.20 17:21:32 - Tor Control authentication method: Cookie, from E:\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie
E 2016.11.20 17:21:32 - Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?
I 2016.11.20 17:21:33 - Cancel requested.
. 2016.11.20 17:21:33 - IPv6 restored with packet filtering.
! 2016.11.20 17:21:33 - Session terminated.
And now the Tor log
11/20/2016 22:20:28 PM.900 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
11/20/2016 22:20:35 PM.400 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
11/20/2016 22:20:35 PM.400 [NOTICE] Opening Socks listener on 127.0.0.1:9150
11/20/2016 22:20:41 PM.100 [NOTICE] Bootstrapped 5%: Connecting to directory server
11/20/2016 22:20:41 PM.100 [NOTICE] Bootstrapped 10%: Finishing handshake with directory server
11/20/2016 22:20:41 PM.600 [NOTICE] Bootstrapped 15%: Establishing an encrypted directory connection
11/20/2016 22:20:41 PM.700 [NOTICE] Bootstrapped 20%: Asking for networkstatus consensus
11/20/2016 22:20:41 PM.800 [NOTICE] Bootstrapped 25%: Loading networkstatus consensus
11/20/2016 22:20:43 PM.000 [NOTICE] new bridge descriptor 'MaBishomarim' (fresh): $A832D176ECD5C7C6B58825AE22FC4C90FA249637~MaBishomarim at 154.35.22.11
11/20/2016 22:20:43 PM.000 [NOTICE] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
11/20/2016 22:20:43 PM.000 [NOTICE] new bridge descriptor 'Azadi' (fresh): $FE7840FE1E21FE0A0639ED176EDA00A3ECA1E34D~Azadi at 154.35.22.13
11/20/2016 22:20:43 PM.100 [NOTICE] new bridge descriptor 'GreenBelt' (fresh): $C73ADBAC8ADFDBF0FC0F3F4E8091C0107D093716~GreenBelt at 154.35.22.9
11/20/2016 22:20:43 PM.100 [NOTICE] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
11/20/2016 22:20:43 PM.100 [NOTICE] new bridge descriptor 'Mosaddegh' (fresh): $8FB9F4319E89E5C6223052AA525A192AFBC85D55~Mosaddegh at 154.35.22.10
11/20/2016 22:20:43 PM.100 [NOTICE] new bridge descriptor 'JonbesheSabz' (fresh): $00DC6C4FA49A65BD1472993CF6730D54F11E0DBB~JonbesheSabz at 154.35.22.12
11/20/2016 22:20:43 PM.300 [NOTICE] Bootstrapped 80%: Connecting to the Tor network
11/20/2016 22:20:44 PM.100 [NOTICE] Bootstrapped 90%: Establishing a Tor circuit
11/20/2016 22:20:44 PM.800 [NOTICE] Tor has successfully opened a circuit. Looks like client functionality is working.
11/20/2016 22:20:44 PM.800 [NOTICE] Bootstrapped 100%: Done
11/20/2016 22:20:45 PM.800 [NOTICE] New control connection opened from 127.0.0.1.
11/20/2016 22:20:45 PM.900 [NOTICE] New control connection opened from 127.0.0.1.
11/20/2016 22:20:53 PM.300 [NOTICE] New control connection opened from 127.0.0.1.
11/20/2016 22:20:56 PM.800 [NOTICE] New control connection opened from 127.0.0.1.
11/20/2016 22:21:00 PM.400 [NOTICE] New control connection opened from 127.0.0.1.
11/20/2016 22:21:04 PM.000 [NOTICE] New control connection opened from 127.0.0.1.
11/20/2016 22:21:07 PM.500 [NOTICE] New control connection opened from 127.0.0.1.
11/20/2016 22:21:11 PM.100 [NOTICE] New control connection opened from 127.0.0.1.
11/20/2016 22:21:25 PM.000 [NOTICE] New control connection opened from 127.0.0.1.
11/20/2016 22:21:28 PM.800 [NOTICE] New control connection opened from 127.0.0.1.
11/20/2016 22:21:32 PM.400 [NOTICE] New control connection opened from 127.0.0.1.
Also here is a photo of my tor config in Eddie
My network lock status
And my protocol
Why the logs between Tor and OpenVPN have a 3 hours difference? We need chronologic reconstructive picture,
not just random snippets. There are multiple things you need to look for:
"Unable to communicate with Tor (Unable to find IP address of Tor first node of an established circuit.). Is Tor up and running?"
This means you circuit failed and your Tor connection is not ready. You should look into this part first.
My Tor connection is fine. I can browse webpages in the tor browser without issue. Obviously the tor circuit is working fine. AirVPN is failing to communicate with it. It also works fine if i connect Tor with standard settings. AirVPN only fails to connect if i configure Tor with a obfs3, obfs4 or any other obfuscation option in the Tor browser. As for the time difference i have no idea because where i am its not even 22:04 yet, if i had to guess Tor used UTC instead of my system time.
Your issue starts from the part where Eddie cannot correctly locate the Tor control auth cookie, which it
tries to find based on the location of the process name directory and then the default /Data/Tor/control_auth_cookie path:
/src/Core/TorControl.cs: string path1 = Platform.Instance.NormalizePath(new FileInfo(processes[0].MainModule.FileName).Directory.Parent.FullName + "/Data/Tor/control_auth_cookie");
When this part fails, Eddie will not be able to communicate with the Tor daemon anymore.
What you need to make sure is that you can get this part working again, it worked at an earlier stage:
After that you have to retry connecting to TCP 80 and 443. Some nodes restrict exits to various ports, in that case you will need to change the circuit.
Eddie can do it for you, but only if the auth cookie is found.
There is no reason why it should not be able to find the auth cookie. The directory it has on record is correct and it is there
Remember, this only stopped working when i turned on obfs4. My theory is that since the bridge replaces the first node in the circuit that AirVPN does not recognize the first hop as a node because it isn't and therefore closes the connection, making all forms of Tor obfuscation useless. But if you have any other ideas i am all ears.
Thu Dec 22 13:33:49 GMT 2016
I am also running into this problem.
Eddie:  v 2.11.8
OS info:
ProductName: Mac OS X
ProductVersion: 10.11.6
BuildVersion: 15G1212
Fails at "Checking Route"
Some additional info:
getinfo config-text
250+config-text=
Bridge obfs4 83.212.101.3:50002 A09D536DD1752D542E1FBB3C9CE4449D51298239 cert=lPRQ/MXdD1t5SRZ9MquYQNT9m5DV757jtdXdlePmRCudUU9CFUOX1Tm7/meFSyPOsud7Cw iat-mode=0
Bridge obfs4 192.95.36.142:443 CDF2E852BF539B82BD10E27E9115A31734E378C2 cert=qUVQ0srL1JI/vO6V6m/24anYXiJD3QP2HgzUKQtQ7GRqqUvs7P+tG43RtAqdhLOALP7DJQ iat-mode=1
Bridge obfs4 154.35.22.9:443 C73ADBAC8ADFDBF0FC0F3F4E8091C0107D093716 cert=gEGKc5WN/bSjFa6UkG9hOcft1tuK+cV8hbZ0H6cqXiMPLqSbCh2Q3PHe5OOr6oMVORhoJA iat-mode=0
Bridge obfs4 154.35.22.11:16488 A832D176ECD5C7C6B58825AE22FC4C90FA249637 cert=YPbQqXPiqTUBfjGFLpm9JYEFTBvnzEJDKJxXG5Sxzrr/v2qrhGU4Jls9lHjLAhqpXaEfZw iat-mode=0
Bridge obfs4 154.35.22.9:12166 C73ADBAC8ADFDBF0FC0F3F4E8091C0107D093716 cert=gEGKc5WN/bSjFa6UkG9hOcft1tuK+cV8hbZ0H6cqXiMPLqSbCh2Q3PHe5OOr6oMVORhoJA iat-mode=0
Bridge obfs4 154.35.22.10:443 8FB9F4319E89E5C6223052AA525A192AFBC85D55 cert=GGGS1TX4R81m3r0HBl79wKy1OtPPNR2CZUIrHjkRg65Vc2VR8fOyo64f9kmT1UAFG7j0HQ iat-mode=0
Bridge obfs4 109.105.109.165:10527 8DFCD8FB3285E855F5A55EDDA35696C743ABFC4E cert=Bvg/itxeL4TWKLP6N1MaQzSOC6tcRIBv6q57DYAZc3b2AzuM+/TfB7mqTFEfXILCjEwzVA iat-mode=1
Bridge obfs4 192.99.11.54:443 7B126FAB960E5AC6A629C729434FF84FB5074EC2 cert=VW5f8+IBUWpPFxF+rsiVy2wXkyTQG7vEd+rHeN2jV5LIDNu8wMNEOqZXPwHdwMVEBdqXEw iat-mode=0
Bridge obfs4 154.35.22.12:80 00DC6C4FA49A65BD1472993CF6730D54F11E0DBB cert=N86E9hKXXXVz6G7w2z8wFfhIDztDAzZ/3poxVePHEYjbKDWzjkRDccFMAnhK75fc65pYSg iat-mode=0
Bridge obfs4 154.35.22.13:443 FE7840FE1E21FE0A0639ED176EDA00A3ECA1E34D cert=fKnzxr+m+jWXXQGCaXe4f2gGoPXMzbL+bTBbXMYXuK0tMotd+nXyS33y2mONZWU29l81CA iat-mode=0
Bridge obfs4 154.35.22.10:80 8FB9F4319E89E5C6223052AA525A192AFBC85D55 cert=GGGS1TX4R81m3r0HBl79wKy1OtPPNR2CZUIrHjkRg65Vc2VR8fOyo64f9kmT1UAFG7j0HQ iat-mode=0
Bridge obfs4 109.105.109.147:13764 BBB28DF0F201E706BE564EFE690FE9577DD8386D cert=KfMQN/tNMFdda61hMgpiMI7pbwU1T+wxjTulYnfw+4sgvG0zSH7N7fwT10BI8MUdAD7iJA iat-mode=2
Bridge obfs4 154.35.22.12:4304 00DC6C4FA49A65BD1472993CF6730D54F11E0DBB cert=N86E9hKXXXVz6G7w2z8wFfhIDztDAzZ/3poxVePHEYjbKDWzjkRDccFMAnhK75fc65pYSg iat-mode=0
Bridge obfs4 154.35.22.13:16815 FE7840FE1E21FE0A0639ED176EDA00A3ECA1E34D cert=fKnzxr+m+jWXXQGCaXe4f2gGoPXMzbL+bTBbXMYXuK0tMotd+nXyS33y2mONZWU29l81CA iat-mode=0
Bridge obfs4 198.245.60.50:443 752CF7825B3B9EA6A98C83AC41F7099D67007EA5 cert=xpmQtKUqQ/6v5X7ijgYE/f03+l2/EuQ1dexjyUhh16wQlu/cpXUGalmhDIlhuiQPNEKmKw iat-mode=0
Bridge obfs4 85.17.30.79:443 FC259A04A328A07FED1413E9FC6526530D9FD87A cert=RutxZlu8BtyP+y0NX7bAVD41+J/qXNhHUrKjFkRSdiBAhIHIQLhKQ2HxESAKZprn/lR3KA iat-mode=0
Bridge obfs4 154.35.22.11:80 A832D176ECD5C7C6B58825AE22FC4C90FA249637 cert=YPbQqXPiqTUBfjGFLpm9JYEFTBvnzEJDKJxXG5Sxzrr/v2qrhGU4Jls9lHjLAhqpXaEfZw iat-mode=0
Bridge obfs4 154.35.22.11:443 A832D176ECD5C7C6B58825AE22FC4C90FA249637 cert=YPbQqXPiqTUBfjGFLpm9JYEFTBvnzEJDKJxXG5Sxzrr/v2qrhGU4Jls9lHjLAhqpXaEfZw iat-mode=0
Bridge obfs4 154.35.22.9:80 C73ADBAC8ADFDBF0FC0F3F4E8091C0107D093716 cert=gEGKc5WN/bSjFa6UkG9hOcft1tuK+cV8hbZ0H6cqXiMPLqSbCh2Q3PHe5OOr6oMVORhoJA iat-mode=0
Bridge obfs4 154.35.22.10:15937 8FB9F4319E89E5C6223052AA525A192AFBC85D55 cert=GGGS1TX4R81m3r0HBl79wKy1OtPPNR2CZUIrHjkRg65Vc2VR8fOyo64f9kmT1UAFG7j0HQ iat-mode=0
DataDirectory /Users/rprimus/Library/Application Support/TorBrowser-Data/Tor
GeoIPFile /Applications/TorBrowser.app/Contents/Resources/TorBrowser/Tor/geoip
GeoIPv6File /Applications/TorBrowser.app/Contents/Resources/TorBrowser/Tor/geoip6
HiddenServiceStatistics 0
UseBridges 1
250 OK
getinfo circuit-status
250+circuit-status=
228 BUILT $FC259A04A328A07FED1413E9FC6526530D9FD87A~NX01,$590F9B111AA2991BB1ECE9A9DF4AC05FA47AE106~OdinaFR,$75484D6D48B4614F88164802B58BAB4FE75EBD9B~Unnamed BUILD_FLAGS=NEED_CAPACITY PURPOSE=GENERAL TIME_CREATED=2016-12-22T13:23:06.039374
217 BUILT $FC259A04A328A07FED1413E9FC6526530D9FD87A~NX01,$FF986A4573185A6912A0FF28335210CC05CE00DE~Evey,$DED677D7A1603762DE314C474361B25FCD37C9ED~ktorrc BUILD_FLAGS=NEED_CAPACITY PURPOSE=GENERAL TIME_CREATED=2016-12-22T13:09:00.844284
227 BUILT $FC259A04A328A07FED1413E9FC6526530D9FD87A~NX01,$375631A2E30DA5053404877BEAA99BE73C036229~keepusalive,$76EECC7375B171C4D84C475C37C0C5B223FBD5E5~tornodepulse BUILD_FLAGS=NEED_CAPACITY PURPOSE=GENERAL TIME_CREATED=2016-12-22T13:23:05.042575
212 BUILT $FC259A04A328A07FED1413E9FC6526530D9FD87A~NX01 BUILD_FLAGS=ONEHOP_TUNNEL,IS_INTERNAL,NEED_CAPACITY PURPOSE=GENERAL TIME_CREATED=2016-12-22T13:08:39.056573
222 BUILT $8FB9F4319E89E5C6223052AA525A192AFBC85D55~Mosaddegh BUILD_FLAGS=ONEHOP_TUNNEL,IS_INTERNAL,NEED_CAPACITY PURPOSE=GENERAL TIME_CREATED=2016-12-22T13:22:23.034797
226 BUILT $00DC6C4FA49A65BD1472993CF6730D54F11E0DBB~JonbesheSabz BUILD_FLAGS=ONEHOP_TUNNEL,IS_INTERNAL,NEED_CAPACITY PURPOSE=GENERAL TIME_CREATED=2016-12-22T13:22:23.043168
224 BUILT $A832D176ECD5C7C6B58825AE22FC4C90FA249637~MaBishomarim BUILD_FLAGS=ONEHOP_TUNNEL,IS_INTERNAL,NEED_CAPACITY PURPOSE=GENERAL TIME_CREATED=2016-12-22T13:22:23.037638
250 OK
getinfo ns/id/$FC259A04A328A07FED1413E9FC6526530D9FD87A
552 Unrecognized key "ns/id/$FC259A04A328A07FED1413E9FC6526530D9FD87A"
rprimus
You're not running the latest Beta though .
This is something that really should be fixed in the near future.
People who actually need Tor over OpenVPN to bypass network restrictions are unable to use it, simply because Tor without obfs and other obfuscation methods is commonly blocked by most adversaries.
