AirVPN with DD-WRT Connection Failing
openvpn airvpn ddwrt router linksys
  • Please log in to reply
1 reply to this topic
#1 MohamedSaleh
MohamedSaleh
  • New Members
  • Pip
  • 1 posts
Posted 12 November 2016 - 05:33 PM
Dears,
I've followed the tutorial on how to connect to AirVPN through DD-WRT but it seems that I can't do it on my own
So I would appreciate your help
The error I'm getting is:
Clientlog:
20161112 18:22:31 N TLS Error: TLS handshake failed
20161112 18:22:31 I SIGUSR1[soft tls-error] received process restarting
20161112 18:22:31 Restart pause 2 second(s)
20161112 18:22:33 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161112 18:22:33 Socket Buffers: R=[180224->131072] S=[180224->131072]
20161112 18:22:33 I UDPv4 link local: [undef]
20161112 18:22:33 I UDPv4 link remote: [AF_INET]109.232.227.148:443
20161112 18:23:33 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20161112 18:23:33 N TLS Error: TLS handshake failed
20161112 18:23:33 I SIGUSR1[soft tls-error] received process restarting
20161112 18:23:33 Restart pause 2 second(s)
20161112 18:23:35 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161112 18:23:35 Socket Buffers: R=[180224->131072] S=[180224->131072]
20161112 18:23:35 I UDPv4 link local: [undef]
20161112 18:23:35 I UDPv4 link remote: [AF_INET]109.232.227.148:443
20161112 18:24:35 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20161112 18:24:35 N TLS Error: TLS handshake failed
20161112 18:24:35 I SIGUSR1[soft tls-error] received process restarting
20161112 18:24:35 Restart pause 2 second(s)
20161112 18:24:37 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161112 18:24:37 Socket Buffers: R=[180224->131072] S=[180224->131072]
20161112 18:24:39 I UDPv4 link local: [undef]
20161112 18:24:39 I UDPv4 link remote: [AF_INET]213.152.162.103:443
20161112 18:25:07 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20161112 18:25:07 D MANAGEMENT: CMD 'state'
20161112 18:25:07 MANAGEMENT: Client disconnected
20161112 18:25:07 D MANAGEMENT: CMD 'status 2'
20161112 18:25:07 D MANAGEMENT: CMD 'log 500'
20161112 18:25:39 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20161112 18:25:39 N TLS Error: TLS handshake failed
20161112 18:25:39 I SIGUSR1[soft tls-error] received process restarting
20161112 18:25:39 Restart pause 2 second(s)
20161112 18:25:41 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161112 18:25:41 Socket Buffers: R=[180224->131072] S=[180224->131072]
20161112 18:25:41 I UDPv4 link local: [undef]
20161112 18:25:41 I UDPv4 link remote: [AF_INET]213.152.162.103:443
20161112 18:26:41 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20161112 18:26:41 N TLS Error: TLS handshake failed
20161112 18:26:41 I SIGUSR1[soft tls-error] received process restarting
20161112 18:26:41 Restart pause 2 second(s)
20161112 18:26:43 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161112 18:26:43 Socket Buffers: R=[180224->131072] S=[180224->131072]
20161112 18:26:43 I UDPv4 link local: [undef]
20161112 18:26:43 I UDPv4 link remote: [AF_INET]213.152.162.103:443
20161112 18:27:43 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20161112 18:27:43 N TLS Error: TLS handshake failed
20161112 18:27:43 I SIGUSR1[soft tls-error] received process restarting
20161112 18:27:43 Restart pause 2 second(s)
20161112 18:27:45 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161112 18:27:45 Socket Buffers: R=[180224->131072] S=[180224->131072]
20161112 18:27:45 I UDPv4 link local: [undef]
20161112 18:27:45 I UDPv4 link remote: [AF_INET]213.152.162.103:443
20161112 18:28:46 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20161112 18:28:46 N TLS Error: TLS handshake failed
20161112 18:28:46 I SIGUSR1[soft tls-error] received process restarting
20161112 18:28:46 Restart pause 2 second(s)
20161112 18:28:48 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161112 18:28:48 Socket Buffers: R=[180224->131072] S=[180224->131072]
20161112 18:28:48 I UDPv4 link local: [undef]
20161112 18:28:48 I UDPv4 link remote: [AF_INET]213.152.162.103:443
20161112 18:29:48 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20161112 18:29:48 N TLS Error: TLS handshake failed
20161112 18:29:48 I SIGUSR1[soft tls-error] received process restarting
20161112 18:29:48 Restart pause 2 second(s)
20161112 18:29:50 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161112 18:29:50 Socket Buffers: R=[180224->131072] S=[180224->131072]
20161112 18:29:52 I UDPv4 link local: [undef]
20161112 18:29:52 I UDPv4 link remote: [AF_INET]213.152.161.132:443
20161112 18:30:52 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20161112 18:30:52 N TLS Error: TLS handshake failed
20161112 18:30:52 I SIGUSR1[soft tls-error] received process restarting
20161112 18:30:52 Restart pause 2 second(s)
20161112 18:30:54 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161112 18:30:54 Socket Buffers: R=[180224->131072] S=[180224->131072]
20161112 18:30:54 I UDPv4 link local: [undef]
20161112 18:30:54 I UDPv4 link remote: [AF_INET]213.152.161.132:443
20161112 18:30:55 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20161112 18:30:55 D MANAGEMENT: CMD 'state'
20161112 18:30:55 MANAGEMENT: Client disconnected
20161112 18:30:55 D MANAGEMENT: CMD 'status 2'
20161112 18:30:55 D MANAGEMENT: CMD 'log 500'
19700101 01:00:00
ca /tmp/openvpncl/ca.crt cert /tmp/openvpncl/client.crt key /tmp/openvpncl/client.key management 127.0.0.1 16 management-log-cache 100 verb 3 mute 3 syslog writepid /var/run/openvpncl.pid client resolv-retry infinite nobind persist-key persist-tun script-security 2 dev tun1 proto udp cipher aes-256-cbc auth sha1 remote nl.vpn.airdns.org 443 comp-lzo yes tls-client tun-mtu 1500 mtu-disc yes ns-cert-type server fast-io tun-ipv6 tls-cipher TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
Can someone please help me ?
I've attached my config in DD-WRT
Thanks.
#2 zhang888
zhang888
    Donald Trump of IT/Security
  • Moderators
  • 2205 posts
Posted 12 November 2016 - 07:43 PM
You forgot to add the TLS auth key, found in ta.key from the config generator.
Similar Topics Collapse
Also tagged with one or more of these keywords: openvpn, airvpn, ddwrt, router, linksys
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Servers online. Online Sessions: 14701 - BW: 52560 Mbit/sYour IP: 54.81.244.248Guest Access.
