temperdu 4 Posted ... Hi, I gave AirVPN a try with a 1 euro trial. I actually try to switch from PIA (provateinternetaccess.com) for some reason. I'm using a Raspberry Pi (SSH access, no GUI). Downloading an openvpn conf file was flawless and wget http://ipinfo.io/ip -qO - gives me a suited IP. Fine. My probem is : Deluge does no more start a boot, while the same config used to work fine with PIA. I set up Deluge as in the official Deluge systemd documentation : http://dev.deluge-torrent.org/wiki/UserGuide/Service/systemd . So as to bind Deluge to the VPN connection, in your openvpn file, I added route-up /etc/openvpn/route-up.sh down /etc/openvpn/down.sh with route-up.sh beeing #!/bin/sh iptables -t nat -I POSTROUTING -o tun0 -j MASQUERADE systemctl start deluged and down.sh beeing #!/bin/sh iptables -t nat -D POSTROUTING -o tun0 -j MASQUERADE systemctl stop deluged What's wrong with that ? (it was fine with PIA) 1 OpenSourcerer reacted to this Quote Share this post Link to post
zhang888 1065 Posted ... Not enough info - you should configure logging as explained in the wiki page you posted and see what prevents it from starting. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
temperdu 4 Posted ... I made the necessary to add logging. It is supposed to produce /var/log/deluge/daemon.log. Unfortunately, at statrup, no daemon.log file is produced. When I start the deamon manualy with sudo systemctl start deluged the deamon starts normally and I can connect to it through the regular Deluge web interface. There is also a brand new /var/log/deluge/daemon.log file but it is empty. Actually, the deamon is able to start when it is asked for. I guess that my problem comes from my openvpn config file. # -------------------------------------------------------- # Air VPN | https://airvpn.org | Thursday 27th of October 2016 09:29:22 AM # OpenVPN Client Configuration. # AirVPN_Netherlands_UDP-443 # -------------------------------------------------------- client dev tun proto udp remote nl.vpn.airdns.org 443 resolv-retry infinite nobind persist-key persist-tun remote-cert-tls server cipher AES-256-CBC comp-lzo no route-delay 5 verb 3 explicit-exit-notify 5 route-up /etc/openvpn/route-up.sh down /etc/openvpn/down.sh ... with the security ca, cert and key sections following, but I d'ont reproduce them. Anyway they seem to work because the Pi connects to the VPN. Is something missing ? My route-up.sh and down.sh files are above. I also tried by removing the iptables lines. Quote Share this post Link to post
temperdu 4 Posted ... I found the solution. Yoyu've been very helpfull by pointing the need of log files.Then I enables custom log files for openvpn and found the solution quickly. My open config file should have contained script-security 2 so as to enable user scripts to be launched. So to sum up, my modified config file is client dev tun proto udp remote nl.vpn.airdns.org 443 resolv-retry infinite nobind persist-key persist-tun remote-cert-tls server cipher AES-256-CBC comp-lzo no route-delay 5 verb 3 explicit-exit-notify 5 # DEB Ajouts maison script-security 2 log-append /var/log/openvpn.log route-up /etc/openvpn/route-up.sh down /etc/openvpn/down.sh # FIN Ajouts maison ... and authentification stuff following and it works fine. So I'll buy a longer AirVPN plan. 3 RidersoftheStorm, LZ1 and OpenSourcerer reacted to this Quote Share this post Link to post
