FrankU 0 Posted ... Hi all, The Eddie client shows servers based on speed by default. Would selecting latency not provide the best results? Obviously selecting latency rates servers in my home country more favourably (~3-10ms) but rating by speed shows the highest rated servers elsewhere in Europe (>10ms). Just looking for views on whether I should stick with the default of speed which selects a server outside my home country. Thanks for your feedback! Couldn't find anything on forums regarding whether it's best to stick with client default of speed. Quote Share this post Link to post
Staff 9691 Posted ... Hi all, The Eddie client shows servers based on speed by default. Would selecting latency not provide the best results? Hello, not really, round trip time weighs significantly, even more than available bandwidth (if you mean that for "speed"). Of course if you have a saturated server by bandwidth, the weight of the penalty for such saturation will make the server rating very low regardless of any other parameter, and it is almost impossible that it will be "best server" for any zone. If you want an empiric rule to quickly decide and that is in most cases effective, once you discard heavily populated servers, go for the one with the lowest round trip time from you. Kind regards Quote Share this post Link to post
serenacat 83 Posted ... Related and not worth raising a new thread and not really a fault and just for info ...Latency, and in the worst case packet loss, seems to better reflect actual performance. Even from the same geolocation, but with different datacenters or backbone routing.For about a week, there has been a large difference in latency from Australia to datacenters in HK. Using Hadar pacswitch.comTracing route to www.abc.net.au [150.101.195.201]over a maximum of 30 hops: 1 301 ms 151 ms 151 ms 10.50.0.1 2 383 ms 524 ms 388 ms 10.119.0.1 3 538 ms 415 ms 382 ms 125.63.60.254 4 385 ms 394 ms 409 ms ge1-11-242.cor3.syd7.cine.net.au [210.5.35.38] 5 389 ms 390 ms 392 ms 10ge2-3-55.br1.syd6.cine.net.au [210.5.37.181] 6 465 ms 410 ms 430 ms as4739.nsw.ix.asn.au [218.100.52.5] 7 419 ms 447 ms 388 ms ae0.br1.syd7.on.ii.net [150.101.33.15] 8 387 ms 379 ms 390 ms 150.101.195.201Trace complete. Using Alnilam or other hkserverworks.comTracing route to www.abc.net.au [150.101.195.201]over a maximum of 30 hops: 1 363 ms 356 ms 359 ms 10.50.0.1 2 687 ms 689 ms 689 ms 10.119.0.1 3 692 ms 686 ms 692 ms 125.63.60.254 4 692 ms 680 ms 691 ms ge1-11-242.cor3.syd7.cine.net.au [210.5.35.38] 5 690 ms 689 ms 689 ms 10ge2-3-55.br1.syd6.cine.net.au [210.5.37.181] 6 687 ms 689 ms 715 ms as4739.nsw.ix.asn.au [218.100.52.5] 7 745 ms 684 ms 689 ms ae0.br1.syd7.on.ii.net [150.101.33.15] 8 687 ms 689 ms 689 ms 150.101.195.201Trace complete. whois 125.63.60.254 -> networkpresence.com.au10.119.x.y would be local routing in the datacenters, but note the large delay in hkserverworks.I first thought this was different undersea cable routing.Testing with other URLs in Au such as my ISP has consistent results.Eddie says Anilam latency=334ms load=15% users=10; Hadar latency=146ms load=9% users=26As usual, Antares Sg is best "score" with latency=124ms load=27% users=133 FYI Quote Share this post Link to post
