Seanpatrick 1 Posted ... Hey All! So I've been enjoying Air for a couple of weeks now. Great speeds in general! I finally got around to trying it out with Deluge (by downloading the suggested torrent of Ipleak.net) but nothing downloads through Deluge - it doesn't see any incoming connections. I scanned through the forums and found the sticky about using AirVPN for torrenting only, however I keep the VPN on all the time. Do I have to open a specific port on eddie (I'm using the beta client) for Deluge to recognize incoming connections? Thanks! Quote Share this post Link to post
LZ1 662 Posted ... Hello! You need to forward the port your torrent client is using, in the Air client Area . As well as making sure your firewall isn't blocking anything. Sent to you from me with datalove Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Seanpatrick 1 Posted ... Hi! Thanks for your reply. So I set up a port in the client area and forwarded it under the incoming connections in Deluge. I tested the port in the client, and it shows as forwarded properly (or a little green icon that I assume means it's all good). Unfortunately I've still no incoming connections, which I take to assume means my firewall is blocking them - (funny though it didn't do that with Private Internet Access?)Here's the info I can manipulate with Bitdefender - sorry for the newb question, but what do you suggest I use as IP address here? Thanks! http://imgur.com/8sOv4PG Quote Share this post Link to post
go558a83nk 352 Posted ... Hi! Thanks for your reply. So I set up a port in the client area and forwarded it under the incoming connections in Deluge. I tested the port in the client, and it shows as forwarded properly (or a little green icon that I assume means it's all good). Unfortunately I've still no incoming connections, which I take to assume means my firewall is blocking them - (funny though it didn't do that with Private Internet Access?) Here's the info I can manipulate with Bitdefender - sorry for the newb question, but what do you suggest I use as IP address here? Thanks! http://imgur.com/8sOv4PG if Air gives you the green light you're all good. if you have no incoming connections maybe there is nobody trying to connect. I read above you're using the test torrent from ipleak.net. there will be no connections with that torrent. it's meant only to confirm the IP address your torrent client (deluge) is announcing to peers. Quote Share this post Link to post
LZ1 662 Posted ... Bitdefender should have an exclusion list that you can simply add airvpn.exe, deluge.exe & openvpn.exe to - have you checked? It's not always necessary though.You can also check the port on Airs site - the TCP test. Sometimes it'll work. Try and see if you can download some torrent - such as a Linux distro like Ubuntu.No worries about newb questions or whatever. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
