FreeInThinAir 1 Posted ... I have been using airvpn for a while and only recently realized that I have been leaking my ipv6 address... So, I want here to resurrect an earlier thread related to ipv6 leaking (https://airvpn.org/topic/18108-ipv6-leak/.)I experience the exact same problem.Under linux (Mint 18) I disabled IPV6 on my machine (by adding the following in /etc/sysctl.conf# disable ipv6 altogethernet.ipv6.conf.all.disable_ipv6 = 1net.ipv6.conf.default.disable_ipv6 = 1net.ipv6.conf.lo.disable_ipv6 = 1) AND selected the advanced AirVPN client option to disable IPV6.Still, visiting https://ipleak.net shows that my ipv6 is leaked.Selecting the network lock is only way to avoid the leak.I consider this problem a real issue... Quote Share this post Link to post
LZ1 662 Posted ... Hello! Which client are you using? Maybe the experimental version would help you. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
FreeInThinAir 1 Posted ... I am running version 2.11.3 which is the experimental one...I do not exactly remember why I needed to go for it though... (web rtc leak maybe?) Quote Share this post Link to post
Staff 9691 Posted ... Hello,as Monsieur De La Palisse would say, if IPv6 is active in your system then it has not been disabled. Something is wrong in your procedure, please check.Eddie for GNU/Linux can not guarantee that IPv6 is disabled in every GNU/Linux distribution, as you probably already know from the disclaimer it prints the first time you the option. You can enable Network Lock, which will set ip6tables rules to prevent IPv6 leaks.Kind regards Quote Share this post Link to post
