Not connected, Your IP: 13.58.252.8
martinb244
Internet connected (Bittorrent works), but web browsers don't load after starting VPN client
A few minutes after I connect to AirVPN, my web browsers will stop connecting to the internet.
Firefox reads: "Server not found."
Chrome reads: "This site can’t be reached. ----.com’s server DNS address could not be found."
Internet Explorer reads: "This page can’t be displayed"
Bittorrent works stays connected and works, but the ipleak ip address check torrent reads: "The server name or address could not be resolved"
When I turn of the VPN client, my web browsers connect again. How do I fix the problem?
Logs below:
I 2016.09.28 12:28:11 - Session starting.
I 2016.09.28 12:28:11 - Installing tunnel driver
I 2016.09.28 12:28:11 - Network adapter DHCP switched to static (Intel® Centrino® Wireless-N 2200)
I 2016.09.28 12:28:15 - DNS of a network adapter forced (Intel® Centrino® Wireless-N 2200)
I 2016.09.28 12:28:15 - Checking authorization ...
! 2016.09.28 12:28:16 - Connecting to Spica (Canada, Toronto, Ontario)
. 2016.09.28 12:28:16 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2016.09.28 12:28:16 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2016.09.28 12:28:16 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.09.28 12:28:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.09.28 12:28:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.28 12:28:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.28 12:28:17 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2016.09.28 12:28:17 - OpenVPN > Attempting to establish TCP connection with [AF_INET]199.19.94.19:443 [nonblock]
. 2016.09.28 12:28:18 - OpenVPN > TCP connection established with [AF_INET]199.19.94.19:443
. 2016.09.28 12:28:18 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.09.28 12:28:18 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]199.19.94.19:443
. 2016.09.28 12:28:18 - OpenVPN > TLS: Initial packet from [AF_INET]199.19.94.19:443, sid=74a370d8 f073d096
. 2016.09.28 12:28:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.09.28 12:28:18 - OpenVPN > Validating certificate key usage
. 2016.09.28 12:28:18 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.09.28 12:28:18 - OpenVPN > VERIFY KU OK
. 2016.09.28 12:28:18 - OpenVPN > Validating certificate extended key usage
. 2016.09.28 12:28:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.09.28 12:28:18 - OpenVPN > VERIFY EKU OK
. 2016.09.28 12:28:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.09.28 12:28:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.09.28 12:28:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.28 12:28:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.09.28 12:28:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.28 12:28:19 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.09.28 12:28:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.19.94.19:443
. 2016.09.28 12:28:21 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.09.28 12:28:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.1.55 255.255.0.0'
. 2016.09.28 12:28:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.09.28 12:28:22 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.09.28 12:28:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.09.28 12:28:22 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.09.28 12:28:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.09.28 12:28:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.09.28 12:28:22 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.09.28 12:28:22 - OpenVPN > open_tun, tt->ipv6=0
. 2016.09.28 12:28:22 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{AB6F2DBB-AFD6-455B-BA1F-0ADB98063D07}.tap
. 2016.09.28 12:28:22 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.09.28 12:28:22 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.5.0.0/10.5.1.55/255.255.0.0 [sUCCEEDED]
. 2016.09.28 12:28:22 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.1.55/255.255.0.0 on interface {AB6F2DBB-AFD6-455B-BA1F-0ADB98063D07} [DHCP-serv: 10.5.255.254, lease-time: 31536000]
. 2016.09.28 12:28:22 - OpenVPN > Successful ARP Flush on interface [14] {AB6F2DBB-AFD6-455B-BA1F-0ADB98063D07}
. 2016.09.28 12:28:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.09.28 12:28:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.09.28 12:28:27 - AirVPN Windows Interface Hack executed (Ethernet)
. 2016.09.28 12:28:32 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.09.28 12:28:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 199.19.94.19 MASK 255.255.255.255 192.168.1.1
. 2016.09.28 12:28:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2016.09.28 12:28:32 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.09.28 12:28:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.09.28 12:28:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2016.09.28 12:28:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.09.28 12:28:32 - Starting Management Interface
. 2016.09.28 12:28:32 - OpenVPN > Initialization Sequence Completed
I 2016.09.28 12:28:32 - Flushing DNS
I 2016.09.28 12:28:32 - Checking DNS
! 2016.09.28 12:28:44 - Connected.
. 2016.09.28 12:28:44 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.09.28 12:28:45 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.09.28 12:29:14 - Updating systems & servers data ...
. 2016.09.28 12:29:16 - Systems & servers data update completed
. 2016.09.28 12:59:32 - Updating systems & servers data ...
. 2016.09.28 12:59:35 - Systems & servers data update completed
I've been getting the same problem, the way I get around it is to open network connections and change the dns server 10.5.0.2 (Airvpn alternate DNS server) in TCP/IPV4. There seems to be a problem with the Airvpn primary DNS, at least for us!
How do I do this?
https://www.youtube.com/watch?v=sZU6g38w1Qc
From 1 min to 1:45 shows you how.
