jeweethet 0 Posted ... i have a problem i use multidesk a software program to save and manage rdps. i have network lock enabled but if i loose vpn cinnection. the rdps keep connected. or in other words i think it never uses the vpn connection at all. because after the vpn disconnects, the rdps dont even have to reconnect. anyone know what this could be? Quote Share this post Link to post
OpenSourcerer 1359 Posted ... Windows?Do you connect to local resources?Are there more than two network interfaces, maybe? (1. Your primary physical; 2. TAP) Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
PANDABOY 1 Posted ... Maybe disable ipv6?Maybe it reconnects after the VPN drops?or as @giganerd says, you could be connecting to a local LAN server then making the RDP connection. All of which will be before the VPN tunnel. So is your PC connected to a domain? Quote Share this post Link to post
jeweethet 0 Posted ... Windows?Do you connect to local resources?Are there more than two network interfaces, maybe? (1. Your primary physical; 2. TAP)Wifi and Tap but that is how i should be connected not? Quote Share this post Link to post
