buginot 0 Posted ... I can not it will be connected to servers. Example below. Wed Mar 28 07:52:30 2012 OpenVPN 2.2.1 Win32-MSVC++ [sSL] [LZO2] built on Jul 1 2011 Wed Mar 28 07:52:30 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Wed Mar 28 07:52:30 2012 LZO compression initialized Wed Mar 28 07:52:30 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Wed Mar 28 07:52:30 2012 Socket Buffers: R=[8192->8192] S=[8192->8192] Wed Mar 28 07:52:30 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Wed Mar 28 07:52:30 2012 Local Options hash (VER=V4): '22188c5b' Wed Mar 28 07:52:30 2012 Expected Remote Options hash (VER=V4): 'a8f55717' Wed Mar 28 07:52:30 2012 UDPv4 link local: [undef] Wed Mar 28 07:52:30 2012 UDPv4 link remote: 178.248.29.132:443 Wed Mar 28 07:52:30 2012 TLS: Initial packet from 178.248.29.132:443, sid=4c8f245d c970e88f Wed Mar 28 07:52:31 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Wed Mar 28 07:52:31 2012 VERIFY OK: nsCertType=SERVER Wed Mar 28 07:52:31 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Wed Mar 28 07:52:31 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Wed Mar 28 07:52:31 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Wed Mar 28 07:52:31 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Wed Mar 28 07:52:31 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Wed Mar 28 07:52:31 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Wed Mar 28 07:52:31 2012 [server] Peer Connection Initiated with 178.248.29.132:443 Wed Mar 28 07:52:33 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Wed Mar 28 07:52:39 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Wed Mar 28 07:52:44 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Wed Mar 28 07:52:50 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Wed Mar 28 07:52:55 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Wed Mar 28 07:53:00 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Wed Mar 28 07:53:03 2012 AUTH: Received AUTH_FAILED control message Wed Mar 28 07:53:03 2012 SIGTERM received, sending exit notification to peer Wed Mar 28 07:53:03 2012 AUTH: Received AUTH_FAILED control message Wed Mar 28 07:53:03 2012 TCP/UDP: Closing socket Wed Mar 28 07:53:03 2012 SIGTERM[soft,auth-failure] received, process exiting Quote Share this post Link to post
jmann9000 0 Posted ... The client freezes at login. Then it stops responding entirely. I was able to access it WITHOUT the client. I used the open vpn for access, but it took about 8 attempts.. The AirVPN web page was inaccessible about an hour ago. I think these guys ran into some major complications. Hopefully, they will get this solved. Before the login problems that started yesterday, this VPN service had been reliable and pretty fast for over a month. Quote Share this post Link to post
Staff 9691 Posted ... The client freezes at login. Then it stops responding entirely. I was able to access it WITHOUT the client. I used the open vpn for access, but it took about 8 attempts.. The AirVPN web page was inaccessible about an hour ago. I think these guys ran into some major complications. Hopefully, they will get this solved. Before the login problems that started yesterday, this VPN service had been reliable and pretty fast for over a month.Hello!The VPN servers have been up and running without any problem (except Omicron for a problem in a Frankfurt datacenter). The frontend experienced severe problems due to another datacenter problem (unstable switches). Please see our messages in the forum.All the problems look resolved now, please do not hesitate to contact us for any further issue.Kind regards Quote Share this post Link to post
jmann9000 0 Posted ... I knew it was a front end problem. I've tested the login client on several of the VPN servers and everything is back to normal. Thank You and keep up the good work! Quote Share this post Link to post
