Download speed close to zero, amateur user
download low speed help new user amateur download speed
  • Please log in to reply
9 replies to this topic
#1 jd890123
jd890123
    Member
  • Members2
  • PipPip
  • 14 posts
Posted 28 July 2016 - 02:58 PM
Hey,
for a couple of weeks now I'm sharing an AirVPN account with a friend of mine (3 devices total, so not exceeding the allowed number). I personally want to use it mostly in conjunction with a torrent client and for web-browsing.
However both the down- and upload speed I am getting is incredibly low, often even below 1 kb/sec. For him everything seems to be perfectly fine, and according to an independent and the AirVPN speedtest I should be getting over 1mb/sec download. My settings are the default ones with a few adjustments, connecting to the best out of a couple of servers in close proximity & network lock is on (there are very few disconnects tho, so I don't think its related to that).
Now I am at best decent with tech stuff thought I have absolutely no idea of VPNs and networks in general. Read a bit around the forums and went through LZ1's Guide. While I think they are extremely helpful I wasn't able to help myself.
Not sure which information you need, I'll just post what I think is relevant.
OS: Windows 7 64-bit
Connection 16.000 DSL, Telekom (usually around 1,4mb/sec down)
Country: Germany
Router: Fritzbox FON 7360 (works without error)
#2 dj77
dj77
    Advanced Member
  • Members
  • PipPipPip
  • 117 posts
Posted 28 July 2016 - 03:32 PM
Sharing with Friends not Allowed 3devices Are for you only
About your Speed Problem which vpn Location you Tested? ( dont use netherland with Telekom)
Do you use Eddie or openvpn Client?
#3 giganerd
giganerd
    I shall have no title
  • Members2
  • PipPipPip
  • 2687 posts
  • LocationGermany
Posted 28 July 2016 - 06:42 PM
Logs. Don't forget the spoiler tags. Read more in my signature.
And your provider name. I'm with DTAG, there seems to be a slight problem with udp/443 and torrenting, udp/53 works very good.
Always remember:
There's a guide to AirVPN,
Amazon IPs are not dangerous here,
running TOR exits is discouraged,
using spoilers for your logs helps us read your thread.
~ Furthermore, I propose that your paranoia is to be destroyed. ~
Instead of writing me a personal mail, consider contacting me via XMPP at gigan3rd@xmpp.airvpn.org or join the lounge@conference.xmpp.airvpn.org. I might read the mail too late whereas I'm always available on XMPP ;)
#4 jd890123
jd890123
    Member
  • Members2
  • PipPip
  • 14 posts
Posted 29 July 2016 - 06:25 PM
Uh, I thought its like Netflix, as long as its below 3 devices it's fine. Well since I can't really use it anyways...
I used Netherlands a lot, however Switzerland and France had similar problems. Thought I'll strike out our orange neighbors from the server list.
Using Eddie btw.
Usig DTAG, I'll try udp/53. Updating with logs soon.
#5 dj77
dj77
    Advanced Member
  • Members
  • PipPipPip
  • 117 posts
Posted 30 July 2016 - 07:26 AM
Try this https://airvpn.org/topic/15791-extremely-low-speeds/#entry33443
#6 jd890123
jd890123
    Member
  • Members2
  • PipPip
  • 14 posts
Posted 30 July 2016 - 09:14 AM
Done the stuff mentioned above (assuming using udp/53 means preferences -> protocols -> alternative ports -> protocol UDP, port 53), here are some logs
Spoiler
Running speed test at the moment.
#7 giganerd
giganerd
  • Members2
  • PipPipPip
  • 2687 posts
  • LocationGermany
Posted 30 July 2016 - 03:17 PM
. 2016.07.30 11:06:56 - OpenVPN > Socket Buffers: R=[8192->524288] S=[8192->262144]
While there's generally no real disadvantage using big buffers, they can lower your latency and/or speed in certain circumstances. With my 50/10 Mbit connection, 65536 bytes are enough. Full speeds, dreamy latency :)
Always remember:
#8 jd890123
jd890123
    Member
  • Members2
  • PipPip
  • 14 posts
Posted 30 July 2016 - 04:16 PM
I don't quite understand what you mean by that..
Done everything mentioned above, still downloading with less than 200 kb/sec (little better than before) while the same torrent goes up to 1,5 mb/sec without the use of AirVPN. Tried Czech, Switzerland, Germany and France.
#9 giganerd
giganerd
  • Members2
  • PipPipPip
  • 2687 posts
  • LocationGermany
Posted 30 July 2016 - 08:46 PM
Buffers can be changed in Settings > Advanced > Send/Receive Buffer Size.
Since you are a Telekom user, I personally recommend you to try Kitalpha and Phoenicis.
Always remember:
#10 jd890123
jd890123
    Member
  • Members2
  • PipPip
  • 14 posts
Posted 09 August 2016 - 08:53 PM
Sorry for necro'ing this thread & not replying for so long.
I managed to greatly increase the down & up speed after playing around with ports in preferences/protocols and my router settings. Getting a decent connection now using UDP/53 as an alternative while opening that port @Kitalpha. Download still drops down to 1kb/s but I feel like I'm on the right path.
Thanks for your help!
Similar Topics Collapse
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Servers online. Online Sessions: 15652 - BW: 60016 Mbit/sYour IP: 54.146.227.92Guest Access.
