EsgTBBp8efavvO58el419IgAdr 0 Posted ... Thank you in advance for assistance.Try as we may we are unable to access our local network with 'Network Lock' activated. We have tried countless suggestions gleaned from forum posts and elsewhere that simply have not worked.Our network a very simple home system and our goal to be able to access a Ready NAS attached to the network.We are running Eddie 2.10.3 with network lock set to OS X - PF on Mavericks 10.9.5.ifconfig posted below for reference in case the 'Addresses Allowed' protocol we are using is incorrect although we have tried every conceivable permutation to no avail. Currently set to 1.10.0.1.25 Regards, Seth Last login: Wed Jul 20 22:46:50 on consoleMacBook:~ ourmac$ ifconfiglo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384 options=3<RXCSUM,TXCSUM> inet6 ::1 prefixlen 128 inet 127.0.0.1 netmask 0xff000000 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 nd6 options=1<PERFORMNUD>gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280stf0: flags=0<> mtu 1280en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=10b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV> ether 3c:07:54:43:71:38 media: autoselect (none) status: inactiveen1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 ether b8: :12:37:17:8a inet 10.0.1.12 netmask 0xffffff00 broadcast 10.0.1.255 nd6 options=1<PERFORMNUD> media: autoselect status: activefw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 4078 lladdr a4:b1:97:ff:fe:a8:fb:de media: autoselect <full-duplex> status: inactiveen2: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500 options=60<TSO4,TSO6> ether d2:00:1a:8f:bd:e0 media: autoselect <full-duplex> status: inactivebridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=63<RXCSUM,TXCSUM,TSO4,TSO6> ether 3e:07:54:34:2f:00 Configuration: id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0 maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200 root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0 ipfilter disabled flags 0x2 nd6 options=1<PERFORMNUD> media: <unknown type> status: inactivep2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304 ether 0a: :12:37:17:8a media: autoselect status: inactiveutun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500 inet 10.5.3.127 --> 10.5.3.127 netmask 0xffff0000MacBook:~ ourmac Quote Share this post Link to post
EsgTBBp8efavvO58el419IgAdr 0 Posted ... Staff,Given the inordinate amount of man hours we have dedicated in an attempt to resolve this issue we would appreciate a response from you.With our a functioning lock the value of this service diminishes substantially.At the very least please review the ifconfig file and advise weather our ‘address allowed’ entry is the correct format.Also inadvertently we entered the following IP address into this field by mistake and it has broken the lock. In other words with this string of numbers entered into the ‘addresses allowed’ not only makes the LAN network available but when AirVPN is DISCONNECTED the entire operating system has open unfettered access to the internet. Please explain what is transiting here.Thank you.Seth Quote Share this post Link to post
Staff 9755 Posted ... Staff,Given the inordinate amount of man hours we have dedicated in an attempt to resolve this issue we would appreciate a response from you.With our a functioning lock the value of this service diminishes substantially.At the very least please review the ifconfig file and advise weather our ‘address allowed’ entry is the correct format. Hello! You all forgot to include the "ifconfig file" you cite. In any case, we would recommend that one, some or all of you open a ticket (please open just one ticket in total) to receive proper support from the Air support team. Here, anyway, you will receive support from the community, which is usually excellent. Kind regards Quote Share this post Link to post
EsgTBBp8efavvO58el419IgAdr 0 Posted ... Much obliged thank you. Ticket opened.FYI the "ifconfig file" is contained in the first post. Regards, Seth Quote Share this post Link to post
