Hi guys,
​Just want to firstly say thank you for the services you provide. I just have a few questions that I would like some discussion on if possible. My setup for using Tor through Airvpn's client is a s follows, my OS is Ubuntu, Mate, Mint or Windows as the base OS which I use to connect the VPN. I then use VMware or virtual box, mostly virtual box due to it not being proprietary to launch a fully contained Tails instance from an .ISO file without persistence, which I then use to connect to Tor. In the Eddie client I have Network lock active at all times, I remove the default gateway and even block ping and the private network access. I have however noticed that if you use DHCP, the default route is reconfigured after a few minutes even though network lock has removed it. I switched to static addressing and this issue hasn’t come up since. I am not sure if you are aware of this. I use this setup because Tor and Eddie's network lock feature isn’t compatible as yet and I do not like the idea of using the VPN without it. I would just like to know any views on this setup and any suggestions on improving security even further.
​I also stumbled on this new feature in Firefox network.dns.blockdotonion, a new preference setting introduced in Firefox 45.0. Any thoughts on this? Why would they want to block .onion dns queries or dns results?
Hello !
​I believe it's known that NL doesn't work with Tor. However, a new experimental version of Eddie has been released, so this will likely get addressed at some point. You should check out the Off-topic forum, wherein you can get some feedback on more ways to secure yourself; or the various links in my own guide. You could for instance, check out the new Subgraph OS.
