Not connected, Your IP: 3.17.186.218
overlord87
Can't connect - Route/DNS Checking issues
New to AirVPN and VPN's in general. Firstly I couldn't get past the 'checking route' stage and after unchecking the 'check if tunnel effectively works' box, I can't get passed the 'Checking DNS' stage... Any help would be much appreciated!
Here is the log:
I 2016.06.24 18:36:50 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2016.06.24 18:36:50 - Reading options from C:\Users\Tom\AppData\Local\AirVPN\AirVPN.xml
. 2016.06.24 18:36:50 - Data Path: C:\Users\Tom\AppData\Local\AirVPN
. 2016.06.24 18:36:50 - App Path: C:\Program Files\AirVPN
. 2016.06.24 18:36:50 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.06.24 18:36:50 - Command line arguments (1): path="home"
. 2016.06.24 18:36:50 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2016.06.24 18:36:50 - Updating systems & servers data ...
I 2016.06.24 18:36:50 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.06.24 18:36:50 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.06.24 18:36:50 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.06.24 18:36:50 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
I 2016.06.24 18:36:50 - Session starting.
I 2016.06.24 18:36:50 - IPv6 disabled.
. 2016.06.24 18:36:50 - Systems & servers data update completed
I 2016.06.24 18:36:57 - Checking authorization ...
! 2016.06.24 18:36:57 - Connecting to Skat (Netherlands, Alblasserdam)
. 2016.06.24 18:36:57 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.06.24 18:36:57 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.06.24 18:36:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.06.24 18:36:58 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.06.24 18:36:58 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.24 18:36:58 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.24 18:36:58 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.06.24 18:36:58 - OpenVPN > UDPv4 link local: [undef]
. 2016.06.24 18:36:58 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.73:443
. 2016.06.24 18:36:58 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.73:443, sid=a4195d94 0471e6e8
. 2016.06.24 18:36:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.06.24 18:36:58 - OpenVPN > Validating certificate key usage
. 2016.06.24 18:36:58 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.06.24 18:36:58 - OpenVPN > VERIFY KU OK
. 2016.06.24 18:36:58 - OpenVPN > Validating certificate extended key usage
. 2016.06.24 18:36:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.06.24 18:36:58 - OpenVPN > VERIFY EKU OK
. 2016.06.24 18:36:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.06.24 18:36:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.24 18:36:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.24 18:36:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.24 18:36:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.24 18:36:58 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.06.24 18:36:58 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.73:443
. 2016.06.24 18:37:00 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.06.24 18:37:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.72.30 255.255.0.0'
. 2016.06.24 18:37:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.06.24 18:37:00 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.06.24 18:37:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.06.24 18:37:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.06.24 18:37:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.06.24 18:37:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.06.24 18:37:00 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.06.24 18:37:00 - OpenVPN > open_tun, tt->ipv6=0
. 2016.06.24 18:37:00 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{D1881364-ECDB-44CC-B7CA-886F6EFF57E5}.tap
. 2016.06.24 18:37:00 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.06.24 18:37:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.72.30/255.255.0.0 [sUCCEEDED]
. 2016.06.24 18:37:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.72.30/255.255.0.0 on interface {D1881364-ECDB-44CC-B7CA-886F6EFF57E5} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.06.24 18:37:00 - OpenVPN > Successful ARP Flush on interface [16] {D1881364-ECDB-44CC-B7CA-886F6EFF57E5}
. 2016.06.24 18:37:05 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.06.24 18:37:05 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.73 MASK 255.255.255.255 192.168.0.1
. 2016.06.24 18:37:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.06.24 18:37:05 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.06.24 18:37:05 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 11
. 2016.06.24 18:37:05 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.24 18:37:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.06.24 18:37:05 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.24 18:37:05 - Starting Management Interface
. 2016.06.24 18:37:05 - OpenVPN > Initialization Sequence Completed
I 2016.06.24 18:37:05 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.06.24 18:37:05 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.06.24 18:37:05 - Flushing DNS
I 2016.06.24 18:37:05 - Checking DNS
W 2016.06.24 18:37:55 - The operation has timed out
! 2016.06.24 18:37:55 - Disconnecting
. 2016.06.24 18:37:55 - Management - Send 'signal SIGTERM'
. 2016.06.24 18:37:55 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.06.24 18:37:55 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.06.24 18:37:55 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.06.24 18:38:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.73 MASK 255.255.255.255 192.168.0.1
. 2016.06.24 18:38:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.06.24 18:38:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.06.24 18:38:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.24 18:38:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.24 18:38:00 - OpenVPN > Closing TUN/TAP interface
. 2016.06.24 18:38:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.06.24 18:38:00 - Connection terminated.
I 2016.06.24 18:38:00 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.06.24 18:38:00 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.06.24 18:38:03 - Checking authorization ...
! 2016.06.24 18:38:04 - Connecting to Skat (Netherlands, Alblasserdam)
. 2016.06.24 18:38:04 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.06.24 18:38:04 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.06.24 18:38:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.06.24 18:38:04 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.06.24 18:38:04 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.24 18:38:04 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.24 18:38:04 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.06.24 18:38:04 - OpenVPN > UDPv4 link local: [undef]
. 2016.06.24 18:38:04 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.73:443
. 2016.06.24 18:38:04 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.73:443, sid=aad8a870 37d27bb9
. 2016.06.24 18:38:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.06.24 18:38:04 - OpenVPN > Validating certificate key usage
. 2016.06.24 18:38:04 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.06.24 18:38:04 - OpenVPN > VERIFY KU OK
. 2016.06.24 18:38:04 - OpenVPN > Validating certificate extended key usage
. 2016.06.24 18:38:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.06.24 18:38:04 - OpenVPN > VERIFY EKU OK
. 2016.06.24 18:38:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.06.24 18:38:04 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.24 18:38:04 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.24 18:38:04 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.24 18:38:04 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.24 18:38:04 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.06.24 18:38:04 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.73:443
Hello !
Welcome to AirVPN. Please post your logs in spoiler tags. Check my signature.
You have TAP Driver 9.21. Please try downgrading: https://airvpn.org/topic/16573-tap-driver-9210-causing-a-myriad-of-issues/
Thanks for your response LZ1! However, after going through your recommendation it doesn't seem to have to solved the problem...
Here are the logs:
I 2016.06.25 13:19:23 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2016.06.25 13:19:23 - Reading options from C:\Users\Tom\AppData\Local\AirVPN\AirVPN.xml
. 2016.06.25 13:19:23 - Data Path: C:\Users\Tom\AppData\Local\AirVPN
. 2016.06.25 13:19:23 - App Path: C:\Program Files\AirVPN
. 2016.06.25 13:19:23 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.06.25 13:19:23 - Command line arguments (1): path="home"
. 2016.06.25 13:19:23 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2016.06.25 13:19:23 - Updating systems & servers data ...
I 2016.06.25 13:19:23 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.9.1
I 2016.06.25 13:19:23 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.06.25 13:19:23 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.06.25 13:19:23 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
I 2016.06.25 13:19:23 - Session starting.
I 2016.06.25 13:19:23 - IPv6 disabled.
. 2016.06.25 13:19:23 - Systems & servers data update completed
I 2016.06.25 13:19:31 - Checking authorization ...
! 2016.06.25 13:19:31 - Connecting to Caph (Netherlands, Alblasserdam)
. 2016.06.25 13:19:31 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.06.25 13:19:31 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.06.25 13:19:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.06.25 13:19:31 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.06.25 13:19:31 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:19:31 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:19:31 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.06.25 13:19:31 - OpenVPN > UDPv4 link local: [undef]
. 2016.06.25 13:19:31 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.169:443
. 2016.06.25 13:19:31 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.169:443, sid=aad4aac1 628d7e60
. 2016.06.25 13:19:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.06.25 13:19:31 - OpenVPN > Validating certificate key usage
. 2016.06.25 13:19:31 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.06.25 13:19:31 - OpenVPN > VERIFY KU OK
. 2016.06.25 13:19:31 - OpenVPN > Validating certificate extended key usage
. 2016.06.25 13:19:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.06.25 13:19:31 - OpenVPN > VERIFY EKU OK
. 2016.06.25 13:19:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.06.25 13:19:32 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.25 13:19:32 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:19:32 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.25 13:19:32 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:19:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.06.25 13:19:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.169:443
. 2016.06.25 13:19:34 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.06.25 13:19:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.55.209 255.255.0.0'
. 2016.06.25 13:19:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.06.25 13:19:34 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.06.25 13:19:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.06.25 13:19:34 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.06.25 13:19:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.06.25 13:19:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.06.25 13:19:34 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.06.25 13:19:34 - OpenVPN > open_tun, tt->ipv6=0
. 2016.06.25 13:19:34 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}.tap
. 2016.06.25 13:19:34 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.06.25 13:19:34 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.55.209/255.255.0.0 [sUCCEEDED]
. 2016.06.25 13:19:34 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.55.209/255.255.0.0 on interface {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.06.25 13:19:34 - OpenVPN > Successful ARP Flush on interface [16] {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}
. 2016.06.25 13:19:39 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.06.25 13:19:39 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.169 MASK 255.255.255.255 192.168.0.1
. 2016.06.25 13:19:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.06.25 13:19:39 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.06.25 13:19:39 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 11
. 2016.06.25 13:19:39 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:19:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.06.25 13:19:39 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:19:39 - Starting Management Interface
. 2016.06.25 13:19:39 - OpenVPN > Initialization Sequence Completed
I 2016.06.25 13:19:39 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.06.25 13:19:39 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.06.25 13:19:39 - Flushing DNS
I 2016.06.25 13:19:39 - Checking DNS
W 2016.06.25 13:20:29 - The operation has timed out
! 2016.06.25 13:20:29 - Disconnecting
. 2016.06.25 13:20:29 - Management - Send 'signal SIGTERM'
. 2016.06.25 13:20:29 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.06.25 13:20:29 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.06.25 13:20:29 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.06.25 13:20:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.169 MASK 255.255.255.255 192.168.0.1
. 2016.06.25 13:20:34 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.06.25 13:20:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.06.25 13:20:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:20:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:20:34 - OpenVPN > Closing TUN/TAP interface
. 2016.06.25 13:20:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.06.25 13:20:34 - Connection terminated.
I 2016.06.25 13:20:34 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.06.25 13:20:34 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.06.25 13:20:37 - Checking authorization ...
! 2016.06.25 13:20:37 - Connecting to Caph (Netherlands, Alblasserdam)
. 2016.06.25 13:20:37 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.06.25 13:20:37 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.06.25 13:20:37 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.06.25 13:20:37 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.06.25 13:20:37 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:20:37 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:20:37 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.06.25 13:20:37 - OpenVPN > UDPv4 link local: [undef]
. 2016.06.25 13:20:37 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.169:443
. 2016.06.25 13:20:37 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.169:443, sid=4eaf0bef a343db40
. 2016.06.25 13:20:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.06.25 13:20:37 - OpenVPN > Validating certificate key usage
. 2016.06.25 13:20:37 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.06.25 13:20:37 - OpenVPN > VERIFY KU OK
. 2016.06.25 13:20:37 - OpenVPN > Validating certificate extended key usage
. 2016.06.25 13:20:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.06.25 13:20:37 - OpenVPN > VERIFY EKU OK
. 2016.06.25 13:20:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.06.25 13:20:37 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.25 13:20:37 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:20:37 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.25 13:20:37 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:20:37 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.06.25 13:20:37 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.169:443
. 2016.06.25 13:20:39 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.06.25 13:20:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.55.209 255.255.0.0'
. 2016.06.25 13:20:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.06.25 13:20:39 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.06.25 13:20:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.06.25 13:20:39 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.06.25 13:20:39 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.06.25 13:20:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.06.25 13:20:39 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.06.25 13:20:39 - OpenVPN > open_tun, tt->ipv6=0
. 2016.06.25 13:20:39 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}.tap
. 2016.06.25 13:20:39 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.06.25 13:20:39 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.55.209/255.255.0.0 [sUCCEEDED]
. 2016.06.25 13:20:39 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.55.209/255.255.0.0 on interface {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.06.25 13:20:39 - OpenVPN > Successful ARP Flush on interface [16] {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}
. 2016.06.25 13:20:44 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.06.25 13:20:44 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.169 MASK 255.255.255.255 192.168.0.1
. 2016.06.25 13:20:44 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.06.25 13:20:44 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.06.25 13:20:44 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 11
. 2016.06.25 13:20:44 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:20:44 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.06.25 13:20:44 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:20:44 - Starting Management Interface
. 2016.06.25 13:20:44 - OpenVPN > Initialization Sequence Completed
I 2016.06.25 13:20:44 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.06.25 13:20:44 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.06.25 13:20:44 - Flushing DNS
I 2016.06.25 13:20:44 - Checking DNS
W 2016.06.25 13:21:34 - The operation has timed out
! 2016.06.25 13:21:34 - Disconnecting
. 2016.06.25 13:21:34 - Management - Send 'signal SIGTERM'
. 2016.06.25 13:21:34 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.06.25 13:21:34 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.06.25 13:21:34 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.06.25 13:21:39 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.169 MASK 255.255.255.255 192.168.0.1
. 2016.06.25 13:21:39 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.06.25 13:21:39 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.06.25 13:21:39 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:21:39 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:21:39 - OpenVPN > Closing TUN/TAP interface
. 2016.06.25 13:21:39 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.06.25 13:21:39 - Connection terminated.
I 2016.06.25 13:21:39 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.06.25 13:21:39 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.06.25 13:21:39 - Cancel requested.
I 2016.06.25 13:21:39 - IPv6 restored.
! 2016.06.25 13:21:39 - Session terminated.
I 2016.06.25 13:23:20 - Session starting.
I 2016.06.25 13:23:20 - IPv6 disabled.
I 2016.06.25 13:23:20 - Checking authorization ...
! 2016.06.25 13:23:20 - Connecting to Caph (Netherlands, Alblasserdam)
. 2016.06.25 13:23:20 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.06.25 13:23:20 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.06.25 13:23:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.06.25 13:23:20 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.06.25 13:23:20 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:23:20 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:23:20 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.06.25 13:23:20 - OpenVPN > UDPv4 link local: [undef]
. 2016.06.25 13:23:20 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.169:443
. 2016.06.25 13:23:20 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.169:443, sid=94e610cb f4c2237d
. 2016.06.25 13:23:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.06.25 13:23:20 - OpenVPN > Validating certificate key usage
. 2016.06.25 13:23:20 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.06.25 13:23:20 - OpenVPN > VERIFY KU OK
. 2016.06.25 13:23:20 - OpenVPN > Validating certificate extended key usage
. 2016.06.25 13:23:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.06.25 13:23:20 - OpenVPN > VERIFY EKU OK
. 2016.06.25 13:23:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.06.25 13:23:20 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.25 13:23:20 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:23:20 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.06.25 13:23:20 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.06.25 13:23:20 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.06.25 13:23:20 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.169:443
. 2016.06.25 13:23:22 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.06.25 13:23:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.55.209 255.255.0.0'
. 2016.06.25 13:23:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.06.25 13:23:22 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.06.25 13:23:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.06.25 13:23:22 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.06.25 13:23:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.06.25 13:23:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.06.25 13:23:22 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.06.25 13:23:22 - OpenVPN > open_tun, tt->ipv6=0
. 2016.06.25 13:23:22 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}.tap
. 2016.06.25 13:23:22 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.06.25 13:23:22 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.55.209/255.255.0.0 [sUCCEEDED]
. 2016.06.25 13:23:22 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.55.209/255.255.0.0 on interface {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.06.25 13:23:22 - OpenVPN > Successful ARP Flush on interface [16] {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}
. 2016.06.25 13:23:27 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.06.25 13:23:27 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.169 MASK 255.255.255.255 192.168.0.1
. 2016.06.25 13:23:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.06.25 13:23:27 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.06.25 13:23:27 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 11
. 2016.06.25 13:23:27 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:23:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.06.25 13:23:27 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:23:27 - Starting Management Interface
. 2016.06.25 13:23:27 - OpenVPN > Initialization Sequence Completed
I 2016.06.25 13:23:27 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.06.25 13:23:27 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.06.25 13:23:27 - Flushing DNS
I 2016.06.25 13:23:27 - Checking DNS
W 2016.06.25 13:24:17 - The operation has timed out
! 2016.06.25 13:24:17 - Disconnecting
. 2016.06.25 13:24:17 - Management - Send 'signal SIGTERM'
. 2016.06.25 13:24:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.06.25 13:24:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.06.25 13:24:17 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.06.25 13:24:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.169 MASK 255.255.255.255 192.168.0.1
. 2016.06.25 13:24:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.06.25 13:24:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.06.25 13:24:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:24:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.06.25 13:24:22 - OpenVPN > Closing TUN/TAP interface
. 2016.06.25 13:24:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.06.25 13:24:22 - Connection terminated.
I 2016.06.25 13:24:22 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.06.25 13:24:22 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
Still can't get get it to work after trying any of the above... Almost ready to cancel the whole thing!
Here are the logs:
I 2016.07.03 12:39:26 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2016.07.03 12:39:27 - Reading options from C:\Users\Tom\AppData\Local\AirVPN\AirVPN.xml
. 2016.07.03 12:39:28 - Data Path: C:\Users\Tom\AppData\Local\AirVPN
. 2016.07.03 12:39:28 - App Path: C:\Program Files\AirVPN
. 2016.07.03 12:39:28 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.07.03 12:39:28 - Command line arguments (1): path="home"
. 2016.07.03 12:39:28 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2016.07.03 12:39:28 - Updating systems & servers data ...
I 2016.07.03 12:39:32 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.9.1
I 2016.07.03 12:39:32 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.07.03 12:39:32 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.07.03 12:39:32 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
I 2016.07.03 12:39:32 - Session starting.
I 2016.07.03 12:39:32 - IPv6 disabled.
. 2016.07.03 12:39:32 - Systems & servers data update completed
I 2016.07.03 12:39:39 - Checking authorization ...
! 2016.07.03 12:39:39 - Connecting to Asellus (Netherlands, Alblasserdam)
. 2016.07.03 12:39:39 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.03 12:39:39 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.03 12:39:39 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.03 12:39:39 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.03 12:39:39 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:39:39 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:39:39 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.07.03 12:39:39 - OpenVPN > UDPv4 link local: [undef]
. 2016.07.03 12:39:39 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.19:443
. 2016.07.03 12:39:39 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.19:443, sid=de50c4bd 886af50e
. 2016.07.03 12:39:39 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.03 12:39:39 - OpenVPN > Validating certificate key usage
. 2016.07.03 12:39:39 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.03 12:39:39 - OpenVPN > VERIFY KU OK
. 2016.07.03 12:39:39 - OpenVPN > Validating certificate extended key usage
. 2016.07.03 12:39:39 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.03 12:39:39 - OpenVPN > VERIFY EKU OK
. 2016.07.03 12:39:39 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.03 12:39:40 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.03 12:39:40 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:39:40 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.03 12:39:40 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:39:40 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.03 12:39:40 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.19:443
. 2016.07.03 12:39:42 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.03 12:39:42 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.23.89 255.255.0.0'
. 2016.07.03 12:39:42 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.03 12:39:42 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.03 12:39:42 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.03 12:39:42 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.03 12:39:42 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.03 12:39:42 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.03 12:39:42 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.03 12:39:42 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.03 12:39:42 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}.tap
. 2016.07.03 12:39:42 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.07.03 12:39:42 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.23.89/255.255.0.0 [sUCCEEDED]
. 2016.07.03 12:39:42 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.23.89/255.255.0.0 on interface {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.07.03 12:39:42 - OpenVPN > Successful ARP Flush on interface [16] {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}
. 2016.07.03 12:39:47 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.07.03 12:39:47 - OpenVPN > C:\Windows\system32\route.exe ADD 109.202.107.19 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:39:47 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.07.03 12:39:47 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.07.03 12:39:47 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 11
. 2016.07.03 12:39:47 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:39:47 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.07.03 12:39:47 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:39:47 - Starting Management Interface
. 2016.07.03 12:39:47 - OpenVPN > Initialization Sequence Completed
I 2016.07.03 12:39:48 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.07.03 12:39:48 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.03 12:39:48 - Flushing DNS
I 2016.07.03 12:39:48 - Checking DNS
W 2016.07.03 12:40:38 - The operation has timed out
! 2016.07.03 12:40:39 - Disconnecting
. 2016.07.03 12:40:39 - Management - Send 'signal SIGTERM'
. 2016.07.03 12:40:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.03 12:40:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.07.03 12:40:39 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.07.03 12:40:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.202.107.19 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:40:44 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.07.03 12:40:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:40:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:40:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:40:44 - OpenVPN > Closing TUN/TAP interface
. 2016.07.03 12:40:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.07.03 12:40:44 - Connection terminated.
I 2016.07.03 12:40:44 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.07.03 12:40:44 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.03 12:40:47 - Checking authorization ...
! 2016.07.03 12:40:47 - Connecting to Asellus (Netherlands, Alblasserdam)
. 2016.07.03 12:40:47 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.03 12:40:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.03 12:40:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.03 12:40:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.03 12:40:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:40:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:40:47 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.07.03 12:40:47 - OpenVPN > UDPv4 link local: [undef]
. 2016.07.03 12:40:47 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.19:443
. 2016.07.03 12:40:47 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.19:443, sid=6e6ea48c 848fb8c5
. 2016.07.03 12:40:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.03 12:40:48 - OpenVPN > Validating certificate key usage
. 2016.07.03 12:40:48 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.03 12:40:48 - OpenVPN > VERIFY KU OK
. 2016.07.03 12:40:48 - OpenVPN > Validating certificate extended key usage
. 2016.07.03 12:40:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.03 12:40:48 - OpenVPN > VERIFY EKU OK
. 2016.07.03 12:40:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.03 12:40:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.03 12:40:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:40:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.03 12:40:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:40:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.03 12:40:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.19:443
. 2016.07.03 12:40:50 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.03 12:40:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.23.89 255.255.0.0'
. 2016.07.03 12:40:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.03 12:40:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.03 12:40:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.03 12:40:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.03 12:40:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.03 12:40:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.03 12:40:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.03 12:40:50 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.03 12:40:50 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}.tap
. 2016.07.03 12:40:50 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.07.03 12:40:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.23.89/255.255.0.0 [sUCCEEDED]
. 2016.07.03 12:40:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.23.89/255.255.0.0 on interface {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.07.03 12:40:50 - OpenVPN > Successful ARP Flush on interface [16] {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}
. 2016.07.03 12:40:55 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.07.03 12:40:55 - OpenVPN > C:\Windows\system32\route.exe ADD 109.202.107.19 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:40:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.07.03 12:40:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.07.03 12:40:55 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 11
. 2016.07.03 12:40:55 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:40:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.07.03 12:40:55 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:40:55 - Starting Management Interface
. 2016.07.03 12:40:55 - OpenVPN > Initialization Sequence Completed
I 2016.07.03 12:40:55 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.07.03 12:40:55 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.03 12:40:55 - Flushing DNS
I 2016.07.03 12:40:55 - Checking DNS
W 2016.07.03 12:41:46 - The operation has timed out
! 2016.07.03 12:41:46 - Disconnecting
. 2016.07.03 12:41:46 - Management - Send 'signal SIGTERM'
. 2016.07.03 12:41:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.07.03 12:41:46 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.03 12:41:46 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.07.03 12:41:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.202.107.19 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:41:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.07.03 12:41:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:41:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:41:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:41:52 - OpenVPN > Closing TUN/TAP interface
. 2016.07.03 12:41:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.07.03 12:41:52 - Connection terminated.
I 2016.07.03 12:41:52 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.07.03 12:41:52 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.03 12:41:55 - Checking authorization ...
! 2016.07.03 12:41:55 - Connecting to Asellus (Netherlands, Alblasserdam)
. 2016.07.03 12:41:55 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.03 12:41:55 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.03 12:41:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.03 12:41:55 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.03 12:41:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:41:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:41:55 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.07.03 12:41:55 - OpenVPN > UDPv4 link local: [undef]
. 2016.07.03 12:41:55 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.19:443
. 2016.07.03 12:41:55 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.19:443, sid=b07c8183 c86a1d76
. 2016.07.03 12:41:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.03 12:41:55 - OpenVPN > Validating certificate key usage
. 2016.07.03 12:41:55 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.03 12:41:55 - OpenVPN > VERIFY KU OK
. 2016.07.03 12:41:55 - OpenVPN > Validating certificate extended key usage
. 2016.07.03 12:41:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.03 12:41:55 - OpenVPN > VERIFY EKU OK
. 2016.07.03 12:41:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.03 12:41:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.03 12:41:55 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:41:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.03 12:41:55 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:41:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.03 12:41:55 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.19:443
. 2016.07.03 12:41:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.03 12:41:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.23.89 255.255.0.0'
. 2016.07.03 12:41:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.03 12:41:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.03 12:41:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.03 12:41:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.03 12:41:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.03 12:41:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.03 12:41:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.03 12:41:58 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.03 12:41:58 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}.tap
. 2016.07.03 12:41:58 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.07.03 12:41:58 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.23.89/255.255.0.0 [sUCCEEDED]
. 2016.07.03 12:41:58 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.23.89/255.255.0.0 on interface {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.07.03 12:41:58 - OpenVPN > Successful ARP Flush on interface [16] {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}
. 2016.07.03 12:42:03 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.07.03 12:42:03 - OpenVPN > C:\Windows\system32\route.exe ADD 109.202.107.19 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:42:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.07.03 12:42:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.07.03 12:42:03 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 11
. 2016.07.03 12:42:03 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:42:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.07.03 12:42:03 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:42:03 - Starting Management Interface
. 2016.07.03 12:42:03 - OpenVPN > Initialization Sequence Completed
I 2016.07.03 12:42:03 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.07.03 12:42:03 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.03 12:42:03 - Flushing DNS
I 2016.07.03 12:42:03 - Checking DNS
W 2016.07.03 12:42:53 - The operation has timed out
! 2016.07.03 12:42:53 - Disconnecting
. 2016.07.03 12:42:53 - Management - Send 'signal SIGTERM'
. 2016.07.03 12:42:53 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.07.03 12:42:53 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.03 12:42:53 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.07.03 12:42:58 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.202.107.19 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:42:58 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.07.03 12:42:58 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:42:58 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:42:58 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:42:58 - OpenVPN > Closing TUN/TAP interface
. 2016.07.03 12:42:58 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.07.03 12:42:58 - Connection terminated.
I 2016.07.03 12:42:58 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.07.03 12:42:58 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.03 12:42:58 - Cancel requested.
I 2016.07.03 12:42:58 - IPv6 restored.
! 2016.07.03 12:42:58 - Session terminated.
I 2016.07.03 12:47:45 - Session starting.
I 2016.07.03 12:47:45 - IPv6 disabled.
I 2016.07.03 12:47:45 - Checking authorization ...
! 2016.07.03 12:47:45 - Connecting to Alterf (Netherlands, Alblasserdam)
. 2016.07.03 12:47:45 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.03 12:47:45 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.03 12:47:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.03 12:47:46 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.03 12:47:46 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:47:46 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:47:46 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.07.03 12:47:46 - OpenVPN > UDPv4 link local: [undef]
. 2016.07.03 12:47:46 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.169:443
. 2016.07.03 12:47:46 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.169:443, sid=e1142c32 9291e243
. 2016.07.03 12:47:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.03 12:47:46 - OpenVPN > Validating certificate key usage
. 2016.07.03 12:47:46 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.03 12:47:46 - OpenVPN > VERIFY KU OK
. 2016.07.03 12:47:46 - OpenVPN > Validating certificate extended key usage
. 2016.07.03 12:47:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.03 12:47:46 - OpenVPN > VERIFY EKU OK
. 2016.07.03 12:47:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.03 12:47:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.03 12:47:46 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:47:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.03 12:47:46 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:47:46 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.03 12:47:46 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.169:443
. 2016.07.03 12:47:48 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.03 12:47:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.67.214 255.255.0.0'
. 2016.07.03 12:47:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.03 12:47:48 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.03 12:47:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.03 12:47:48 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.03 12:47:48 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.03 12:47:48 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.03 12:47:48 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.03 12:47:48 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.03 12:47:48 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}.tap
. 2016.07.03 12:47:48 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.07.03 12:47:48 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.67.214/255.255.0.0 [sUCCEEDED]
. 2016.07.03 12:47:48 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.67.214/255.255.0.0 on interface {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.07.03 12:47:48 - OpenVPN > Successful ARP Flush on interface [16] {B5B09C13-2F23-434F-91E7-75BE8C7AB0BC}
. 2016.07.03 12:47:53 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.07.03 12:47:53 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.169 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:47:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.07.03 12:47:53 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.07.03 12:47:53 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 11
. 2016.07.03 12:47:53 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:47:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.07.03 12:47:53 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:47:53 - Starting Management Interface
. 2016.07.03 12:47:53 - OpenVPN > Initialization Sequence Completed
I 2016.07.03 12:47:53 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.07.03 12:47:53 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.03 12:47:53 - Flushing DNS
I 2016.07.03 12:47:53 - Checking DNS
W 2016.07.03 12:48:43 - The operation has timed out
! 2016.07.03 12:48:43 - Disconnecting
. 2016.07.03 12:48:43 - Management - Send 'signal SIGTERM'
. 2016.07.03 12:48:43 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.07.03 12:48:43 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.03 12:48:43 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.07.03 12:48:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.169 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:48:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.07.03 12:48:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.07.03 12:48:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:48:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.07.03 12:48:48 - OpenVPN > Closing TUN/TAP interface
. 2016.07.03 12:48:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.07.03 12:48:48 - Connection terminated.
I 2016.07.03 12:48:48 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.07.03 12:48:48 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.03 12:48:51 - Checking authorization ...
! 2016.07.03 12:48:51 - Connecting to Alterf (Netherlands, Alblasserdam)
. 2016.07.03 12:48:51 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.07.03 12:48:51 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.07.03 12:48:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.03 12:48:51 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.03 12:48:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:48:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:48:51 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.07.03 12:48:51 - OpenVPN > UDPv4 link local: [undef]
. 2016.07.03 12:48:51 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.169:443
. 2016.07.03 12:48:51 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.169:443, sid=a87d9849 ac84aff2
. 2016.07.03 12:48:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.03 12:48:52 - OpenVPN > Validating certificate key usage
. 2016.07.03 12:48:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.03 12:48:52 - OpenVPN > VERIFY KU OK
. 2016.07.03 12:48:52 - OpenVPN > Validating certificate extended key usage
. 2016.07.03 12:48:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.03 12:48:52 - OpenVPN > VERIFY EKU OK
. 2016.07.03 12:48:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.03 12:48:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.03 12:48:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:48:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.03 12:48:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.03 12:48:52 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.07.03 12:48:52 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.169:443
