Not connected, Your IP: 216.73.216.169
wiznet
AirVPN portable Archlinux x64 not running
Archlinux x64 Plasma5 will not run portable.
[root@lemmy airvpn_linux_x64_portable]# ./airvpn
Unhandled Exception: System.TypeInitializationException: An exception was thrown by the type initializer for Mono.Unix.Na
tive.Syscall ---> System.DllNotFoundException: $mono_libdir/libMonoPosixHelper.so
 at (wrapper managed-to-native) Mono.Unix.Native.Syscall:_L_ctermid ()
 at Mono.Unix.Native.Syscall..cctor () [0x00000] in <filename unknown>:0
 --- End of inner exception stack trace ---
 at AirVPN.Platforms.Linux.GetExecutablePath () [0x00000] in <filename unknown>:0
 at AirVPN.Core.Platform.GetProgramFolder () [0x00000] in <filename unknown>:0
 at AirVPN.Core.Engine.Initialization () [0x00000] in <filename unknown>:0
 at AirVPN.UI.Linux.Program.Main () [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: An exception was thrown by the type initializer fo
r Mono.Unix.Native.Syscall ---> System.DllNotFoundException: $mono_libdir/libMonoPosixHelper.so
Any ideas why this isnt working? It seems that AirVPN client isnt getting the greatest of reviews recently?
Linux lemmy 4.6.2-1-ARCH #1 SMP PREEMPT Wed Jun 8 08:40:59 CEST 2016 x86_64 GNU/Linux
Yes, I already reported the issue there: https://airvpn.org/topic/17190-eddie-2103-broken-with-mono-44040-under-linux/ This is caused by the mono update.
As far as I remember, the non portable version is working using mono airvpn command.
Alternatively, you may configure network-manager (under gnome or kde) to use AirVPN according to the instructions on this site, they do work.
We definitely need a new release of the AirVPN client anyway.
all I did was get the appropriate mono version via the ALA ( Arch Rollback Machine)  and built airvpn client with yaourt, always worked for me
For me, no need: install package airvpn-git from the AUR. Then run sudo mono /usr/lib/AirVPN/AirVPN.exe
