Not connected, Your IP: 3.141.8.247
afroturf
Remote Desktop Problems
I installed AirVPN on my home machine (Win 10) on the weekend and now I'm not able to connect to it via RDP, though I could before.
I have set up a forwarded port from [highnumber] to 3389 local (TCP and UDP) and a DDNS on the airvpn.org/ports page.
Trying to remote into my home machine at PublicIP:highnumber, ForwardedTo:highnumber, and [ddns].airvpn.org:highnumber all fail.  I have confirmed that the outbound port from my current machine does work.
Any suggestions on getting this fixed?  Thanks!
Figured this one out and I thought I'd post in case anyone had the same problem.
For some reason, after installing the VPN software, I had to go into Windows Firewall and allow the Remote Desktop for Public networks, instead of just Private.  After that it worked.
