Wamps 0 Posted ... I started the 3 day trial of AirVPN to test out its port forwarding, if it worked well I was willing to switch over from PIA but after looking around for the past few days I could not find a guide for port forwarding AirVPN on pfSense 2.3 that would work for me. I would like to address that first but I also need a solution to my chromecast no longer works even though everything else on the network seems to work fine. If there is any other information required from me I would be more than happy to provide it. Quote Share this post Link to post
LZ1 662 Posted ... Hello ! Welcome to AirVPN! https://airvpn.org/topic/17444-how-to-set-up-pfsense-23-for-airvpn/ Whenever you can, it's good to post logs in spoiler tags too, when relevant. There's a tab in the AirVPN client, Eddie, that provides logs. If you have other questions, you can also refer to the guide in my signature. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
go558a83nk 343 Posted ... I started the 3 day trial of AirVPN to test out its port forwarding, if it worked well I was willing to switch over from PIA but after looking around for the past few days I could not find a guide for port forwarding AirVPN on pfSense 2.3 that would work for me. I would like to address that first but I also need a solution to my chromecast no longer works even though everything else on the network seems to work fine. If there is any other information required from me I would be more than happy to provide it. did you have port forwarding working for PIA? If so you'll need to configure pfsense by the same method. Just head to https://airvpn.org/ports/ to have Air assign you a forwarded port. Usually you don't need to change any settings for the forwarded port. Just click the add button. Quote Share this post Link to post
Wamps 0 Posted ... I started the 3 day trial of AirVPN to test out its port forwarding, if it worked well I was willing to switch over from PIA but after looking around for the past few days I could not find a guide for port forwarding AirVPN on pfSense 2.3 that would work for me. I would like to address that first but I also need a solution to my chromecast no longer works even though everything else on the network seems to work fine. If there is any other information required from me I would be more than happy to provide it. did you have port forwarding working for PIA? If so you'll need to configure pfsense by the same method. Just head to https://airvpn.org/ports/ to have Air assign you a forwarded port. Usually you don't need to change any settings for the forwarded port. Just click the add button.I did not have port forwarding setup on PIA since they did not offer it within the VPN. I followed this guide https://nguvu.org/pfsense/pfsense-port-forward/ and this https://airvpn.org/topic/11245-how-to-set-up-pfsense-21-for-airvpn/page-6?do=findComment&comment=17580 . Neither of which worked for me, I followed the general setup guide for AirVPN on pfsense that worked fine except for the chromecast not being able to connect to the internet now. Hello ! Welcome to AirVPN! https://airvpn.org/topic/17444-how-to-set-up-pfsense-23-for-airvpn/ Whenever you can, it's good to post logs in spoiler tags too, when relevant. There's a tab in the AirVPN client, Eddie, that provides logs. If you have other questions, you can also refer to the guide in my signature.I'm not using the the AirVPN client I'm using the OpenVPN client on pfsense. Quote Share this post Link to post
go558a83nk 343 Posted ... I did not have port forwarding setup on PIA since they did not offer it within the VPN. I followed this guide https://nguvu.org/pfsense/pfsense-port-forward/ and this https://airvpn.org/topic/11245-how-to-set-up-pfsense-21-for-airvpn/page-6?do=findComment&comment=17580 . Neither of which worked for me, I followed the general setup guide for AirVPN on pfsense that worked fine except for the chromecast not being able to connect to the internet now. I started the 3 day trial of AirVPN to test out its port forwarding, if it worked well I was willing to switch over from PIA but after looking around for the past few days I could not find a guide for port forwarding AirVPN on pfSense 2.3 that would work for me. I would like to address that first but I also need a solution to my chromecast no longer works even though everything else on the network seems to work fine. If there is any other information required from me I would be more than happy to provide it. did you have port forwarding working for PIA? If so you'll need to configure pfsense by the same method. Just head to https://airvpn.org/ports/ to have Air assign you a forwarded port. Usually you don't need to change any settings for the forwarded port. Just click the add button. >Hello ! Welcome to AirVPN! https://airvpn.org/topic/17444-how-to-set-up-pfsense-23-for-airvpn/ Whenever you can, it's good to post logs in spoiler tags too, when relevant. There's a tab in the AirVPN client, Eddie, that provides logs. If you have other questions, you can also refer to the guide in my signature.I'm not using the the AirVPN client I'm using the OpenVPN client on pfsense. forwarding ports from an openvpn interface to LAN client is the same no matter what VPN service is used. therefore, I suggest you head to pfsense forums to ask for help. I think you're more likely to get the right help there. Relatively few people use pfsense in this forum. I do, but I've never tried port forwarding. Quote Share this post Link to post
