Not connected, Your IP: 3.135.202.224
Google Chrome has an extension that fixes the webrtc problem. https://chrome.google.com/webstore/detail/webrtc-network-limiter/npeicpdbkakmehahjeeohfdhnlpdklia?hl=en
In Firefox webrtc can be turned off completely by following these simple steps.
  1. Enter "about:config" in the firefox address bar and press enter.
  2. Press the button "I'll be careful, I promise!"
  3. Search for "media.peerconnection.enabled"
  4. Double click the entry, the column "Value" should now be "false"
  5. Done. Do the WebRTC leak test again.
Hello !
If you scroll to the bottom of ipleak.net it will tell you how to plug the leak.
