Not connected, Your IP: 3.16.47.14
shiro21
[SOLVED] Tunnelblick Unable To Create Connection
EDIT: Nevermind! I figured it out. I had a competing VPN client still running. *idiot*
Hello -
Running Mac OS X 10.6.8. Tunnelblick 3.2.3. OpenVPN 2.2.1. Using standard ipfw firewall configured to allow Tunnelblick. Using Little Snitch 2.4.4 configured to allow Tunnelblick.
When trying to connect to either US servers using UDP 440 No proxy, I get this in log:
2012-03-16 20:52:39 *Tunnelblick: OS X 10.6.8; Tunnelblick 3.2.3 (build 2891.2932)
2012-03-16 20:52:39 *Tunnelblick: Attempting connection with air; Set nameserver = 1; monitoring connection
2012-03-16 20:52:39 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start air.ovpn 1337 1 0 0 0 49 -atDASNGWrdasngw
2012-03-16 20:52:44 *Tunnelblick: openvpnstart status #247: Loading tun.kext
/Applications/Tunnelblick.app/Contents/Resources/tun.kext failed to load - (libkern/kext) kext (kmod) start/stop routine failed; check the system/kernel logs for errors or try kextutil(8).
Error: Unable to load net.tunnelblick.tun and/or net.tunnelblick.tap kexts in 5 tries. Status = 71
I have tried using different config files as well as reinstalling Tunnelblick.
