Not connected, Your IP: 216.73.216.113
OmniNegro
ANSWERED Is there a wishlist for ciphers and hashes to add?
I would love to one day see Threefish-256 as an option. I think 512 and 1024 bits would only congest the servers too much, but 256 bits should be easy enough. In addition, I think Serpent is a very good option at 256 bits.
Tiger is a great hash, but is currently only 160 bits plus the HMAC. So it is less desirable compared to SHA2-256
If there is a wishlist, I was unable to find it. I would appreciate a link to the thread if one exists.
And I most certainly welcome discussion. Thanks in advance.
Well, thanks anyway. I posted here because I figured there is no reason the Eddie Client cannot use different options than vanilla OpenVPN.
But I can certainly understand the reason that is not a goal.
Have a nice day everyone.
Unfortunately there are two good reasons... Eddie is an OpenVPN frontend. It has tons of additional commodities but the core security of the tunneling, connection and packets handling (and more) remains to OpenVPN/OpenSSL/PolarSSL. Forking OpenVPN to support something different would be a paramount task, not to mention the huge security risks related to the operation...
