Not connected, Your IP: 3.128.199.162
PIA might use auth-user-pass, AirVPN does not.You don't even have to edit anything, just skip steps 4, 5 and 6.
I am facing issue setting VPN for raspberry pi'.
OS  - Ubuntu Mate 16.04
Steps -
1) Generate config file.
1a) With Advance >  Separate Keys checked
1b) With Advance > Separate Keys unchecked
2) Import ovpn file into Network-Connection-Manager via option Import OpenVPN file
3) Save > Reboot
4) Connecting VPN does not pops up message "VPN Connected"
5) Browser cannot resolve host
6) /etc/resolv.conf does not have any DNS entry
7) System Log shows "nm-openvpn[9865]: write to TUN/TAP : Invalid argument (code=22)"
Mr. m2110k, I want to understand the reason you post it here when you already opened a similar topic. You could just go on and post it there (since it's your topic). A better way is to open an entirely new topic. Consider that in the future.
That is strange. I thought that post never got published, after it went for approval. I remember checking it again but did not find it.
Anyways, this is a different issue. Since Feb, I was able to use AirVPN via OpenVPN in Ubuntu armhf. I followed the instructions in this post. https://airvpn.org/topic/11432-using-airvpn-with-ubuntu-network-manager/
However 2 weeks ago, ubuntu has been updated to 16.04 LTS. Strangely now VPN connects but there is no DNS. I have mentioned details in above post. It is a fresh Ubuntu install on raspberry pi 3.
Could you help me find what may be the issue.
