Not connected, Your IP: 18.119.213.235
Oxfordian
using AIR VPN with Zeusgard?
​I have a bastion computer which runs from a read-only USB stick made by Zeusgard. You cannot write to this USB stick, therefore, I cannot use the Eddie client and I cannot change anything on the OS.  What I would like to do is launch the computer with Zeusgard then go to AIRVPN, log in then use AIRVPN servers to surf through, just as I am doing now through Eddie. Is this at all possible? Thank you.
Some live-cds/dvds can save data (in fact it's only in Ram while they are working, when you shutdown all is lost). So, maybe this device could work the same way. If it's based in Linux (I don't know) then try to download ""Eddie portable" everytime you boot and try to use it.
