mehāniskākaravīrs935 24 Posted ... Will it ever be possible for us to hide our connections to AirVPN on our mobile devices using OpenVPN over SSL and SSH in the future via Eddie or some other mobile solution? Quote Share this post Link to post
mehāniskākaravīrs935 24 Posted ... Note: Using a Windows based PC as a wifi hotspot to share the already existing tunnel is in fact a solution, but i would hope iOS SSL/SSH tunneling would be possible without any other devices on hand. Quote Share this post Link to post
Staff 9751 Posted ... Hello!About Android: https://airvpn.org/topic/15249-how-to-using-airvpn-through-stunnel-on-android/ Kind regards 1 OpenSourcerer reacted to this Quote Share this post Link to post
mehāniskākaravīrs935 24 Posted ... Hello!About Android: https://airvpn.org/topic/15249-how-to-using-airvpn-through-stunnel-on-android/ Kind regardsLooks like a solution, albeit not a very practical one with all the 3rd party applications and command line usage. I personally use iOS and it would be nice to have a wholesome solution in one client. I'm not trying to complain, i just think coding a mobile OpenVPN over SSL/SSH solution whether it be OpenVPN Connect or a mobile Eddie would make mobile VPN usage under restricted networks much easier. Luckily i have not encountered a network that absolutely needs a SSH/SSL solution because in the US TCP 443 or 80 98% of the time does the trick but someday i fear it wont perhaps with the introduction of DPI on public wifis nationwide. Quote Share this post Link to post
zhang888 1065 Posted ... You cannot do that in stock iOS.The only way to have VPN there is using the documented API. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
