Not connected, Your IP: 18.190.217.134
Whitener69
ANSWERED Successful OpenVPN connection on Synology, but no traffic
I exactly followed all steps for creating a VPN on Synology. I have established a successful VPN connection - which is visible on in my AirVPN client area > overview page. The thing is that I cannot access the internet (Download Manager) - even ping (using putty) is not responding after having made the VPN connection.
Btw - I deliberatly did not (yet) make any portforwarding changes, as I wanted to see if something as simple as this would work.
Because I thought it might be a firewall issue, I temporary disabled my router firewall - no luck.
Hope you could get me in the right direction...
Netstat before and after making VPN connection.
DiskStation> netstat -nr
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
0.0.0.0         192.168.0.1     0.0.0.0         UG        0 0          0 eth0
192.168.0.0     0.0.0.0         255.255.255.0   U         0 0          0 eth0
0.0.0.0         10.8.0.1        128.0.0.0       UG        0 0          0 tun0
10.8.0.0        0.0.0.0         255.255.0.0     U         0 0          0 tun0
128.0.0.0       10.8.0.1        128.0.0.0       UG        0 0          0 tun0
213.152.161.73  192.168.0.1     255.255.255.255 UGH       0 0          0 eth0
SOLVED
I later found out that a direct ping to an IP-address did work, therefore it had to be the DNS that was misconfigured.
What did work is: putting the DNS Server of AirVPN as the Alternative DNS Server of Synology diskstation.
Hereby the steps:
- Alternative DNS Server: you can find it in Control Panel > Network > General
- DNS of yourVPN provider (in our case AirVPN): 1) in Windows, start cmd 2) ipconfig /all 3) Look for the DNS Server under the TAP-Windows Adapter properties.
Good luck!
Marc
This post has not gotten enough love! I'm sure there are plenty of people searching out this exact fix for their Synology NAS systems!!!
Thank you, Marc! YOU THE MAN
