Not connected, Your IP: 52.90.235.91
I'm having problems connecting tor -> vpn I'm quite flummoxed as to why considering when I first set it up it worked perfectly fine. I have barely touched the settings in the vpn and and problems connecting through tor started occurring after I switched to automatic protocol (which also worked fine and still does) and then back to using the tor protocol.
When I test the tor protocol it tells me the test is successful however when I attempt to connect it gets stuck on checking authorization while flashing to connecting the the vpn server every few seconds and then back to checking authorization. I have left it running like this for probably over 15 minutes it just keeps flashing back and forth without connecting.
I'm pretty stumped on how to solve this considering the test for the protocol comes back successful.
Thanks I solved the problem I forgot I had tor configured to connect through an obs4 bridge when I took it off and connected normally it worked fine. I guess you connecting through bridges messes with the vpn somehow. If anyone knows a way to use a tor bridge with eddie that'd be interesting knowledge to have but other than that problem solved thanks.
