securvark
[Solved with minor issue] OpenVPN on OpenWrt CC 15.05 and DD (trunk)
I upgraded my router to the latest nightly (see title), I'm coming from Chaos Chalmer. I upgraded because I was having some other (non-vpn) related issues with CC builds.
I've configured my router with OpenVPN. I generated a config for routers, separate certs, resolve ticked. Copied to my router and renamed the AirVPN...ovpn to airvpn.ovpn.
The problem is, it takes AAAGES for something to load. It does eventually load, though. DNS resolving is quick, I can use dig or nslookup and response is instant. When I telnet to a websites IP address on port 80 it just takes minutes and finally connects. Browser sometimes simply stops loading because it's taking too long.
Not sure what's going on, can anyone help?
Here's the output:
root@myrouter:/etc/openvpn# openvpn --cd /etc/openvpn --config /etc/openvpn/airvpn.ovpn
Mon Jan 18 22:11:47 2016 OpenVPN 2.3.7 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6]
Mon Jan 18 22:11:47 2016 library versions: OpenSSL 1.0.2e 3 Dec 2015, LZO 2.08
Mon Jan 18 22:11:47 2016 WARNING: file 'user.key' is group or others accessible
Mon Jan 18 22:11:47 2016 WARNING: file 'ta.key' is group or others accessible
Mon Jan 18 22:11:47 2016 Control Channel Authentication: using 'ta.key' as a OpenVPN static key file
Mon Jan 18 22:11:47 2016 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Jan 18 22:11:47 2016 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Jan 18 22:11:47 2016 Socket Buffers: R=[163840->131072] S=[163840->131072]
Mon Jan 18 22:11:47 2016 UDPv4 link local: [undef]
Mon Jan 18 22:11:47 2016 UDPv4 link remote: [AF_INET]213.152.162.148:443
Mon Jan 18 22:11:47 2016 TLS: Initial packet from [AF_INET]213.152.162.148:443, sid=a579b56c daba3750
Mon Jan 18 22:11:47 2016 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Mon Jan 18 22:11:47 2016 Validating certificate key usage
Mon Jan 18 22:11:47 2016 ++ Certificate has key usage  00a0, expects 00a0
Mon Jan 18 22:11:47 2016 VERIFY KU OK
Mon Jan 18 22:11:47 2016 Validating certificate extended key usage
Mon Jan 18 22:11:47 2016 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Mon Jan 18 22:11:47 2016 VERIFY EKU OK
Mon Jan 18 22:11:47 2016 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Mon Jan 18 22:11:54 2016 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Jan 18 22:11:54 2016 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Jan 18 22:11:54 2016 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Jan 18 22:11:54 2016 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Jan 18 22:11:54 2016 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Mon Jan 18 22:11:54 2016 [server] Peer Connection Initiated with [AF_INET]213.152.162.148:443
Mon Jan 18 22:11:56 2016 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Mon Jan 18 22:11:56 2016 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.21.34 255.255.0.0'
Mon Jan 18 22:11:56 2016 OPTIONS IMPORT: timers and/or timeouts modified
Mon Jan 18 22:11:56 2016 OPTIONS IMPORT: LZO parms modified
Mon Jan 18 22:11:56 2016 OPTIONS IMPORT: --ifconfig/up options modified
Mon Jan 18 22:11:56 2016 OPTIONS IMPORT: route options modified
Mon Jan 18 22:11:56 2016 OPTIONS IMPORT: route-related options modified
Mon Jan 18 22:11:56 2016 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mon Jan 18 22:11:56 2016 TUN/TAP device tun0 opened
Mon Jan 18 22:11:56 2016 TUN/TAP TX queue length set to 100
Mon Jan 18 22:11:56 2016 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mon Jan 18 22:11:56 2016 /sbin/ifconfig tun0 10.4.21.34 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
Mon Jan 18 22:12:01 2016 /sbin/route add -net 213.152.162.148 netmask 255.255.255.255 gw 83.84.6.1
Mon Jan 18 22:12:01 2016 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
Mon Jan 18 22:12:01 2016 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
Mon Jan 18 22:12:01 2016 Initialization Sequence Completed
^CMon Jan 18 22:14:42 2016 event_wait : Interrupted system call (code=4)
Mon Jan 18 22:14:42 2016 SIGTERM received, sending exit notification to peer
Mon Jan 18 22:14:47 2016 /sbin/route del -net 213.152.162.148 netmask 255.255.255.255
Mon Jan 18 22:14:47 2016 /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
Mon Jan 18 22:14:47 2016 /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
Mon Jan 18 22:14:47 2016 Closing TUN/TAP interface
Mon Jan 18 22:14:47 2016 /sbin/ifconfig tun0 0.0.0.0
Mon Jan 18 22:14:47 2016 SIGTERM[soft,exit-with-notification] received, process exiting
If you need anything else, let me know I'll post it.
Well, maybe it isn't even resolving, or maybe that changes after I disconnect/reconnect. Right now, it's not even resolving from an SSH session on the router itself.
I imported the profile on my PC (running Linux) and it works fine.
Should I downgrade to CC again?
I downgraded to the stable CC 15.05, and I'm seeing the same problem.
Funny thing is, it worked the first time around but I screwed up the config. After a factory reset I am basically following the same procedure but its not working anymore.
try to remove the "explicit-exit-notify" directive, it's not implemented in OpenWRTs OpenVPN.
What router is that? The general OpenVPN performance even on high end models is not very
solid, especially if you use high-bandwidth applications.
Thanks for the reply.
The router is a TP-Link TL-WDR4300 v1. When it did work a couple of days ago, the performance was around 7mbit. It was actually performing quite well. I could live with 7mbit, not with not working at all .
I do need to remove the explicit-exit-notify, it doesn't work without it. On DD however, with a newer version of OpenVPN that directive no longer throws an error message and I assume it works.
I'm back at DD trunk, it seems a solid build and I get no errors in my logs and everything works. I must be doing something wrong since I couldnt get airvpn to work after I downgraded to CC 15.05 but I have no idea what I'm doing wrong.
I'm following this guide and I get stuck on step 14.
Oke, now it works. Not sure what went wrong last time but oh well.
Just one problem. I would like to stop at step 14 from the guide I linked to. It allows me to start/stop the VPN on demand.
The problem is, I need to edit /etc/config/dhcp and add the dhcp_option and restart odhcpd:
config dhcp 'lan'
        list dhcp_option '6,10.26.13.23,10.4.0.1'
When I disconnect VPN, I need to remove it and do /etc/init.d/odhcpd restart again.
Is there any way around that, short of writing a custom script that takes care of that?
