Not connected, Your IP: 3.232.108.171
dougiepunk
Does ipleak.net test for IPv6 leaks?
Hmm... If I enable IPv6, I still don't get DNS leaks... I assumed AirVPN was properly routing IPv6 calls through the VPN to its DNS servers...
It's very important to know that:
1) ipleak.net does NOT work in IPv6
2) our service does NOT support IPv6, that's why our client Network Lock blocks outgoing IPv6 packets (also, the client can disable IPv6 in some systems, and re-enable it at shut down)
3) DNS leaks via IPv6 are possible, but will be blocked by Network Lock and/or disabling IPv6.
