wilsonc91 0 Posted ... I have a 250 MBPS connection. Would the AC68U be fast enough so that I could use openVPN on it and max my connection? Quote Share this post Link to post
go558a83nk 343 Posted ... no, the AC68 can do about 50mbit/s. I have one, overclocked to 1200mhz, so I know. Quote Share this post Link to post
zhang888 1065 Posted ... If you want to max anything beyond 100Mbit, no consumer router will be able to deliver it.You will need a dedicated solution like a custom built PC which whole purpose is a router. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
Hades666 1 Posted ... Got an AC87U and it reaches around 50Mbit on standard clock speed so no you won't max your connection. Quote Share this post Link to post
Valerian 20 Posted ... If you want to max anything beyond 100Mbit, no consumer router will be able to deliver it.You will need a dedicated solution like a custom built PC which whole purpose is a router. That can't be right, otherwise ISPs wouldn't be selling people 1Gb lines. Quote Share this post Link to post
zhang888 1065 Posted ... If you want to max anything beyond 100Mbit, no consumer router will be able to deliver it.You will need a dedicated solution like a custom built PC which whole purpose is a router. That can't be right, otherwise ISPs wouldn't be selling people 1Gb lines. This is true in the context of running an OpenSSL and AES256 tunnel on an embedded CPU of the router. They are not designed for that.You can achieve a near 1Gbit speeds on the port itself, if you router has 1Gbit ports. But the CPU will be always the bottleneck. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
