j0pad0pa 5 Posted ... I'm running AirVPN v.2.10.3 on a Windows 7 laptop with NOD32 antivirus (just downgraded from NOD32 internet security so that I can install the Comodo Firewall). I am messing around with these settings because the old uTorrent (v. 1.8.2; there is a reason for this) stopped downloading for some reason, and I couldn't figure it out in the NOD32 firewall settings. I am writing this post because I am confused about how the AirVPN "Network Lock" feature works with the Windows Firewall (especially since I will be using the Comodo setup here). Is there a conflict of some sort or problem with using Comodo Firewall along with the "Network Lock" feature? Or do they not work together? Also, if there are specific instructions on how to get uTorrent working on AirVPN (still doesn't work), I'm still at a loss. Thanks.JP Quote Share this post Link to post
Guest Posted ... If you have comodo firewall installed you need to disable windows firewall so network lock will not work and just disable it from airvpn program. About utorrent not working i can't tell you cause i use qbittorrent without any other change. Quote Share this post Link to post
me.moo@posteo.me 80 Posted ... I've used Comodo Firewall in safe mode with network lock on without any problems for ages. I also use Bittorrent without modifications with no problems either. Latest versions of everything, Win 7. Quote Share this post Link to post
Staff 9748 Posted ... I've used Comodo Firewall in safe mode with network lock on without any problems for ages. I also use Bittorrent without modifications with no problems either. Latest versions of everything, Win 7. That's very risky. You have two programs with the same privileges competing to modify the kernel or OS packets filtering tables at the same time. In general you must never run two firewalls simultaneously (that's true for any system, not only Windows). Kind regards 1 encrypted reacted to this Quote Share this post Link to post
encrypted 13 Posted ... I've used Comodo Firewall in safe mode with network lock on without any problems for ages. I also use Bittorrent without modifications with no problems either. Latest versions of everything, Win 7. That's very risky. You have two programs with the same privileges competing to modify the kernel or OS packets filtering tables at the same time. In general you must never run two firewalls simultaneously (that's true for any system, not only Windows). Kind regards Thanks. Maybe this fact should be emphasized somewhere, maybe even in the GUI itself. Or Eddie could detect "competing" firewall and notify the user. Quote Share this post Link to post
me.moo@posteo.me 80 Posted ... I've used Comodo Firewall in safe mode with network lock on without any problems for ages. I also use Bittorrent without modifications with no problems either. Latest versions of everything, Win 7. That's very risky. You have two programs with the same privileges competing to modify the kernel or OS packets filtering tables at the same time. In general you must never run two firewalls simultaneously (that's true for any system, not only Windows). Kind regardsOK, thanks. I take it then that the firewall rules set up in Windows Firewall with network lock on are adequate and that the default rules are not required while connected through the vpn tunnel. Quote Share this post Link to post
j0pad0pa 5 Posted ... Wait a sec. 1) If I am running Comodo Firewall, I should not have "network lock" activated? And, 2) I should also disable the Windows Firewall? How would I disable the Windows Firewall in Win7? Quote Share this post Link to post
me.moo@posteo.me 80 Posted ... Wait a sec. 1) If I am running Comodo Firewall, I should not have "network lock" activated? And, 2) I should also disable the Windows Firewall? How would I disable the Windows Firewall in Win7?Network Lock uses Windows Firewall, therefore:1) Correct2) No Windows Firelwall is easily switch off from within its own GUI. Quote Share this post Link to post
bluesjunior 39 Posted ... Comodo Firewall normally switches the Windows firewall off during the installation but it can and has switched itself back on again during certain "second Tuesday" updates. To be sure just enter "services.msc" without the italics in the search window and scroll down to the Windows Firewall entry and disable it. Quote Share this post Link to post
j0pad0pa 5 Posted ... It has been almost two years since I started this thread. Still using Comodo Firewall with the settings here, no "Network Lock" (red circle), and Windows Firewall set to 'disabled' in the services.msc. Have we advanced anywhere with the firewall settings? Are people still using Comodo Firewall? Or has something newer / better / more advanced come out which AirVPN users are now using? Quote Share this post Link to post
LZ1 662 Posted ... It has been almost two years since I started this thread. Still using Comodo Firewall with the settings here, no "Network Lock" (red circle), and Windows Firewall set to 'disabled' in the services.msc. Have we advanced anywhere with the firewall settings? Are people still using Comodo Firewall? Or has something newer / better / more advanced come out which AirVPN users are now using?Hello! People are still using Comodo for sure. But Eddie recently introduced the usage of Windows Filtering Platform - WFP. As an alternative to just using Windows Firewall. Thus (hopefully) allowing for greater compatibility with 3rd party firewall/security software, exactly like Comodo. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
crazyjoe 0 Posted ... No problems with Windows Firewall Control. Got to buy pro for notifications though. Quote Share this post Link to post
DonaldDrumpf 3 Posted ... I had AirVPN a few years ago when Comodo was about the only free firewall you could configure to perform the functions of network lock. So, I re-installed it on this new computer before I came back to AirVPN and found out about network lock, which saved me the configuration hassle I went through last time and was prepared to go through again. Until this very moment, I wasn't even aware you weren't supposed to use Comodo and network lock at the same time. I've been using them both for a while now with no problems. For all I know, Windows firewall is running as well, but I haven't checked or messed with it as it's never been an issue, I hate screwing around with firewalls and Comodo seems to be working fine with or without network lock, picking up all the traffic just as it's supposed to. Small edit: Occasionally after a reboot, Eddie refuses to connect until I disable and re-enable network lock. Don't know whether that has anything to do with Comodo or not, but I rarely reboot so I haven't yet bothered to troubleshoot it. Utorrent works fine after doing the port forwarding thing too. Quote Share this post Link to post
WaNNaBEAnoNymoUs 10 Posted ... I have using in windows CFW10 no probs with or without NL, whatsoever. Of course i have Win firewall disabled. Long time, no issue. Comodo Firewall isn't a easier choise for newbie or even average user... Lot of configuration and settings u have to know what they do and not etc... I suggest do deep research for comodo forums etc.. And yes WFP on. Quote Hide WaNNaBEAnoNymoUs's signature Hide all signatures "You don't have to be a genius to sound like one." - BDS Share this post Link to post
