acacia 0 Posted ... I was using AirVPN Client 2.9 without any problem, I upgraded to version 2.10.3 and now no server will connect. I am using debian jessie. This is the log for one try, but it can go on for ever, repeating the conection-disconection: ! 2015.09.03 11:35:27 - Activation of Network Lock - Linux IPTables I 2015.09.03 11:35:35 - Session starting. I 2015.09.03 11:35:36 - Checking authorization ... ! 2015.09.03 11:35:36 - Connecting to Gorgonea (Canada, Toronto, Ontario) . 2015.09.03 11:35:36 - OpenVPN > OpenVPN 2.3.4 i586-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Dec 1 2014 . 2015.09.03 11:35:36 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08 . 2015.09.03 11:35:36 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2015.09.03 11:35:36 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2015.09.03 11:35:36 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2015.09.03 11:35:36 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2015.09.03 11:35:36 - OpenVPN > Socket Buffers: R=[163840->262144] S=[163840->262144] . 2015.09.03 11:35:36 - OpenVPN > UDPv4 link local: [undef] . 2015.09.03 11:35:36 - OpenVPN > UDPv4 link remote: [AF_INET]104.254.90.250:443 . 2015.09.03 11:35:39 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.250:443, sid=29f0600c f7f4edf9 . 2015.09.03 11:35:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2015.09.03 11:35:45 - OpenVPN > Validating certificate key usage . 2015.09.03 11:35:45 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2015.09.03 11:35:45 - OpenVPN > VERIFY KU OK . 2015.09.03 11:35:45 - OpenVPN > Validating certificate extended key usage . 2015.09.03 11:35:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2015.09.03 11:35:45 - OpenVPN > VERIFY EKU OK . 2015.09.03 11:35:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2015.09.03 11:35:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2015.09.03 11:35:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2015.09.03 11:35:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2015.09.03 11:35:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2015.09.03 11:35:48 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA . 2015.09.03 11:35:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.250:443 . 2015.09.03 11:35:50 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2015.09.03 11:35:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.19.120 255.255.0.0' . 2015.09.03 11:35:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2015.09.03 11:35:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2015.09.03 11:35:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2015.09.03 11:35:50 - OpenVPN > OPTIONS IMPORT: route options modified . 2015.09.03 11:35:50 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2015.09.03 11:35:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2015.09.03 11:35:50 - OpenVPN > ROUTE_GATEWAY 192.168.2.1/255.255.255.0 IFACE=wlan0 HWADDR=00:1b:9e:fb:b9:a7 . 2015.09.03 11:35:50 - OpenVPN > TUN/TAP device tun0 opened . 2015.09.03 11:35:50 - OpenVPN > TUN/TAP TX queue length set to 100 . 2015.09.03 11:35:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2015.09.03 11:35:50 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500 . 2015.09.03 11:35:50 - OpenVPN > /sbin/ip addr add dev tun0 10.4.19.120/16 broadcast 10.4.255.255 . 2015.09.03 11:35:55 - OpenVPN > /sbin/ip route add 104.254.90.250/32 via 192.168.2.1 . 2015.09.03 11:35:55 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.4.0.1 . 2015.09.03 11:35:55 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.4.0.1 . 2015.09.03 11:35:55 - Starting Management Interface . 2015.09.03 11:35:55 - OpenVPN > Initialization Sequence Completed I 2015.09.03 11:35:55 - /etc/resolv.conf renamed to /etc/resolv.conf.airvpn as backup I 2015.09.03 11:35:55 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated) I 2015.09.03 11:35:55 - Flushing DNS I 2015.09.03 11:35:55 - Checking route W 2015.09.03 11:35:55 - Object reference not set to an instance of an object ! 2015.09.03 11:35:55 - Disconnecting . 2015.09.03 11:35:55 - Management - Send 'signal SIGTERM' . 2015.09.03 11:35:56 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info . 2015.09.03 11:35:56 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2015.09.03 11:35:56 - OpenVPN > SIGTERM received, sending exit notification to peer . 2015.09.03 11:36:00 - OpenVPN > /sbin/ip route del 104.254.90.250/32 . 2015.09.03 11:36:00 - OpenVPN > /sbin/ip route del 0.0.0.0/1 . 2015.09.03 11:36:00 - OpenVPN > /sbin/ip route del 128.0.0.0/1 . 2015.09.03 11:36:00 - OpenVPN > Closing TUN/TAP interface . 2015.09.03 11:36:00 - OpenVPN > /sbin/ip addr del dev tun0 10.4.19.120/16 . 2015.09.03 11:36:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2015.09.03 11:36:00 - Connection terminated. I 2015.09.03 11:36:00 - DNS of the system restored to original settings (Rename method) I 2015.09.03 11:36:02 - Cancel requested. ! 2015.09.03 11:36:02 - Session terminated. ! 2015.09.03 11:38:29 - Deactivation of Network Lock any help apreciated acacia Quote Share this post Link to post
iwih2gk 92 Posted ... Has to be on your end. Eddie 2.10.3 is running slick on my Deb Jessie (Cinnamon)! I know that doesn't really help you except to be clear that the client is working on Jessie for most. Did you do an upgrade, or did you delete 2.9 and then install a fresh Eddie 2.10? Just an idea. Quote Share this post Link to post
Staff 9750 Posted ... @acacia We confirm that Eddie 2.10.3 runs just fine in our Debian jessie testing boxes. Just an idea related to Mono, did you install some newer Mono package not coming from the jessie repositories? Could you please post the output of the commands: mono --version dpkg -l | grep mono issued from any terminal in your system? Kind regards Quote Share this post Link to post
acacia 0 Posted ... Here is the mono version: Mono JIT compiler version 3.2.8 (Debian 3.2.8+dfsg-10) TLS: __thread SIGSEGV: altstack Notifications: epoll Architecture: x86 Disabled: none Misc: softdebug LLVM: supported, not enabled. GC: sgen eems strange though, eddie 2.9 works fine. thank you Quote Share this post Link to post
acacia 0 Posted ... Ok, removed Eddie 2.9 with apt-get remove --purge then i deleted .airvpn from home folder; and installed Eddie 2.10 AirVPN Client Eddie 2.10 working as it should. Thank you for support! Quote Share this post Link to post
iwih2gk 92 Posted ... Has to be on your end. Eddie 2.10.3 is running slick on my Deb Jessie (Cinnamon)! I know that doesn't really help you except to be clear that the client is working on Jessie for most. Did you do an upgrade, or did you delete 2.9 and then install a fresh Eddie 2.10? Just an idea. That is what I suspected when I read this thread. Glad you got it going! Quote Share this post Link to post
