Not connected, Your IP: 3.129.13.201
metalbew
tv wireless recievers, ddwrt router, and motorola hub,need advice
so i know i can get put the hun in passthrough mode to the ddwrt router but we have wireless tv recievers
should i leave the recievers inside my hub or should i only plug in the router to the hub and put everything into the switch since im disabling packet filtering on the hub?
im leaving wifi connectivity on my hub but would wifi protected setup still work if i plug them into the router and reboot or since they are staying inside my home network would it be fine leaving it in my hub
