Not connected, Your IP: 18.118.137.243
Pingviinit
OpenVPN question/No connection
Hello guys,
I have a quick question which hopefully results with a quick fix.
This is my first time trying to get VPN running on Arch.
What I have done is download the congfig file, extracted into /etc/openvpn
then through terminal typed in
sudo openvpn --config /etc/openvpn/AirVPN/name_of_the_file_.ovpn
The problem comes after the command executes and terminal outputs 'Sequence Authenticated'. I have no longer a connection nor can run a ping command.
I am pretty sure I a missing a step. Any ideas?
Please pardon my English and thank you much in advance.
Could try w/o the --config line:
sudo openvpn /etc/openvpn/AirVPN/name_of_the_file_.ovpn
Or just log in as root and run it.
The config files can be anywhere. There's no need to put them in the /etc/openvpn directory when starting it from terminal.
Enabling logging via iptables might also help.
I am still having the same problem no matter what I do. It is quite frusterating.
I have tried several methods from terminal to congfiguring NetworkManager manaully. Still no luck.
Through the openvpn command,  I get this message in the end.
Tue Jul 7
2015 Initialization Sequence Completed
With absolutely no errors or anything.
There is gotta be something else I am missing.  I have not yet touched iptables yet.
At this point, any ideas are welcomed.
Nothing in that video is required for airvpn.  - err other than extracting the files lol.
-Download the files.
-Run openvpn /path/to/your/file.ovpn
-surf on
Post the log file if its still failing.
