Not connected, Your IP: 3.135.213.214
On the routes option of the VPN program for Windows 2.8.8, there is an option for "Not specified routes go:" and the only way I can get my WD live media players to see the computer that has the VPN running on it is to set this option to "Outside the VPN"
My Question is, does this compromise the point of the vpn for p2p (I have Vuze binded to the VPN connection, and the port forwarded) or to anything I look at via Firefox on the computer?
Or better still do you know of how I would need to have this set up to run the above option as "Inside the VPN Tunnel" and allow the WD live players to see my FTFS network shares on the PC that has the VPN running.
Many thanks for your help...
On the routes option of the VPN program, there is an option for "Not specified routes go:" and the only way I can get my WD live media players to see the computer that has the VPN running on it is to set this option to "Outside the VPN"
