Not connected, Your IP: 216.73.216.233
mblue
openvpn script to modify dns entries
I found this thread and setup accordingly so openvpn can add the airvpn DNS servers to /etc/resolv.conf
1) Created /etc/openvpn/update-resolv-conf.sh
2) Edited it to contain the two DNS servers mentioned above in the 'foreign_option_1' and 'foreign_option_2' variables.
3) modified /etc/openvpn/airvnp.conf to contain these three lines
script-security 2
up /etc/openvpn/update-resolv-conf.sh
down /etc/openvpn/update-resolv-conf.sh
It works as expected except, the original nameserver (192.168.0.1) is at the bottom of the file.  Is that expected?
# Generated by resolvconf
nameserver 10.4.0.1
nameserver 10.5.0.1
nameserver 192.168.0.1
I would remove nameserver 192.168.0.1
Its most likely attempting to get the nameservers from your router or another device in front of the pc. If that other device is using/sending your isp's dns server its less than ideal.
If the pc is always connected to the vpn such a script isn't needed. Just modify the resolv.conf so the air dns servers are the only nameservers in there.
If you need dns connectivity w/o a vpn try and figure out where that 192.168.0.1 is coming from. Its probably in the default resolv.conf. I haven't looked at that script but ideally you only want the air dns servers in the resolv.conf while connected.
Dns tests here:
http://ipleak.net/
https://www.dnsleaktest.com/
http://entropy.dns-oarc.net/test/
Agreed.  Problem is that when the machine boots, resolv.conf is generated from systemd-resolved.service so Ireally need the script to comment out the default one or remove/readd it.  I'm thinking that others would experience this as well and have a solution that working within the script method.
You could probably just disable that service at boot or in general.
If there's a network manager installed on that system setting the dns to manual and tossing in dns servers might also do the trick.
The only other option I can think of is writing a different type of script and 2 resolv.conf files. Then have the script cp 'copy' the vpn dns resolv.conf over the default one while the vpn is up. Then when the vpn is down - copy a standard dns server resolv.conf back in place.
