Not connected, Your IP: 18.224.149.242
tangoxp
Nooooob help setting up air vpn with mac
Right guys need a full tutorial on how to configure this so i can switch ips and become annomouse on the internet !!
Please help
There are tons of guides in the how-to section of the forum. For Mac though just download the latest version of the Eddie (AirVPN) software. I prefer to get the pkg installer but it doesn't matter what you choose. Install it, open it and after popping in your user and pass you can connect and choose a server. It's very straightforward. If you have any actual specific questions after that just shout, there's plenty of helpful folks on here and staff patrol regularly also.
You will need to have Mavericks to use Eddie. If you're on an earlier OS, you can either use Viscosity, which is not free and is closed source, or use Tunnelblick, which is free and open source. As rainmakerraw notes, there are tons of guides available.
Best to upgrade to Mavericks if you can... and not just to run Eddie (which is great btw).
If this is not possible, Tunnelblick works fairly well. :-)
