Not connected, Your IP: 3.135.183.187
amen1337
Airvpn proxy problem + tor + question about openvpn
Good day,
First of all I am running Ubuntu 14.04 on my laptop. What I want to achiev is to connect to tor via Airvpn. (That's the safest setup way, am I right?).
Problems that I occure:
To connect to Tor, I need to setup proxy in Airvpn client. Ant then use data in Tor configuration and achieve connection.
Airvpn client without proxy setting works flawless. After I turn on proxy (socks5), I cant connect to server, I get reconnect loop, log:
I 2015.03.09 11:03:54 - AirVPN client version: 2.8.8, System: Linux, Name: Ubuntu 14.10 \n \l, Architecture: x86
. 2015.03.09 11:03:54 - Reading options from /home/vibe/.airvpn/AirVPN.xml
. 2015.03.09 11:03:56 - Data Path: /home/vibe/.airvpn
. 2015.03.09 11:03:56 - App Path: /usr/lib/AirVPN
. 2015.03.09 11:03:56 - Executable Path: /usr/lib/AirVPN/AirVPN.exe
. 2015.03.09 11:03:56 - Command line arguments (1): path="/home/vibe/.airvpn"
. 2015.03.09 11:03:57 - Operating System: Unix 3.16.0.23 - Linux Q 3.16.0-23-generic #31-Ubuntu SMP Tue Oct 21 18:00:35 UTC 2014 i686 i686 i686 GNU/Linux
. 2015.03.09 11:03:57 - Updating systems & servers data ...
I 2015.03.09 11:03:57 - OpenVPN Driver - Found
I 2015.03.09 11:03:57 - OpenVPN - Version: OpenVPN 2.3.2 (/usr/sbin/openvpn)
I 2015.03.09 11:03:57 - SSH - Version: OpenSSH_6.6.1p1 Ubuntu-8, OpenSSL 1.0.1f 6 Jan 2014 (/usr/bin/ssh)
I 2015.03.09 11:03:57 - SSL - Version: stunnel 5.02 (/usr/bin/stunnel4)
I 2015.03.09 11:03:57 - IPV6: Available
! 2015.03.09 11:03:57 - Ready
. 2015.03.09 11:03:57 - Updating systems & servers data ..., 1° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:03:57 - Updating systems & servers data ..., 2° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:03:57 - Updating systems & servers data ..., 3° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:03:57 - Updating systems & servers data ..., 4° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:03:57 - Updating systems & servers data ..., 5° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:03:58 - Updating systems & servers data ..., 6° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:03:58 - Updating systems & servers data ..., 7° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:03:58 - Updating systems & servers data ..., 8° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
W 2015.03.09 11:03:58 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (CUrl is not installed on this system, and it's required for SOCKS proxy.)
I 2015.03.09 11:04:49 - Session starting.
I 2015.03.09 11:04:49 - Installing tunnel driver
F 2015.03.09 11:04:50 - Only TCP protocol is allowed with a proxy.
. 2015.03.09 11:04:58 - Updating systems & servers data ...
. 2015.03.09 11:04:58 - Updating systems & servers data ..., 1° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:04:58 - Updating systems & servers data ..., 2° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:04:58 - Updating systems & servers data ..., 3° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:04:58 - Updating systems & servers data ..., 4° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:04:58 - Updating systems & servers data ..., 5° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:04:58 - Updating systems & servers data ..., 6° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:04:58 - Updating systems & servers data ..., 7° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:04:58 - Updating systems & servers data ..., 8° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
W 2015.03.09 11:04:58 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (CUrl is not installed on this system, and it's required for SOCKS proxy.)
I 2015.03.09 11:05:12 - Session starting.
I 2015.03.09 11:05:12 - Installing tunnel driver
I 2015.03.09 11:05:12 - Retrieving manifest
W 2015.03.09 11:05:12 - Unable to retrieve systems & servers data. Continue anyway with the old data.
. 2015.03.09 11:05:12 - Updating systems & servers data ...
I 2015.03.09 11:05:12 - Checking authorization ...
. 2015.03.09 11:05:12 - Updating systems & servers data ..., 1° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:12 - Updating systems & servers data ..., 2° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:12 - Checking authorization ..., 1° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:12 - Updating systems & servers data ..., 3° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:12 - Checking authorization ..., 2° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:12 - Updating systems & servers data ..., 4° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:13 - Checking authorization ..., 3° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:13 - Updating systems & servers data ..., 5° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:13 - Checking authorization ..., 4° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:13 - Updating systems & servers data ..., 6° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:13 - Checking authorization ..., 5° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:13 - Updating systems & servers data ..., 7° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:13 - Checking authorization ..., 6° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:13 - Updating systems & servers data ..., 8° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
W 2015.03.09 11:05:13 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (CUrl is not installed on this system, and it's required for SOCKS proxy.)
. 2015.03.09 11:05:13 - Checking authorization ..., 7° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:13 - Checking authorization ..., 8° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
W 2015.03.09 11:05:13 - Authorization check failed, continue anyway ({1])
! 2015.03.09 11:05:13 - Connecting to Grafias (Netherlands, Amsterdam)
I 2015.03.09 11:05:13 - DNS of the system will be updated to VPN DNS (ResolvConf method)
. 2015.03.09 11:05:13 - OpenVPN > OpenVPN 2.3.2 i686-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Dec  1 2014
. 2015.03.09 11:05:13 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.09 11:05:13 - OpenVPN > NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
. 2015.03.09 11:05:13 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.09 11:05:13 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.09 11:05:13 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.09 11:05:13 - OpenVPN > Socket Buffers: R=[87380->131072] S=[16384->131072]
. 2015.03.09 11:05:13 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:9150 [nonblock]
. 2015.03.09 11:05:13 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:9150
. 2015.03.09 11:05:13 - OpenVPN > socks_handshake: server asked for username/login auth but we were not provided any credentials
. 2015.03.09 11:05:13 - OpenVPN > SIGTERM[soft,init_instance] received, process exiting
! 2015.03.09 11:05:13 - Disconnecting
. 2015.03.09 11:05:13 - Connection terminated.
I 2015.03.09 11:05:16 - Checking authorization ...
. 2015.03.09 11:05:16 - Checking authorization ..., 1° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:16 - Checking authorization ..., 2° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:16 - Checking authorization ..., 3° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:16 - Checking authorization ..., 4° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:16 - Checking authorization ..., 5° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:16 - Checking authorization ..., 6° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:16 - Checking authorization ..., 7° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
. 2015.03.09 11:05:16 - Checking authorization ..., 8° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)
W 2015.03.09 11:05:16 - Authorization check failed, continue anyway ({1])
I 2015.03.09 11:05:16 - Cancel requested.
! 2015.03.09 11:05:16 - Session terminated.
By the way how to access Tor line in Airvpn->Preferences->Protocols?
Off problem topic question - would openvpn increase security or solve problem? (Sorry newbie)
Have a nice day,
amen1337
P.S.: Sorry for poor English
Did you install CUrl yet or not?
"Checking authorization ..., 5° try failed (CUrl is not installed on this system, and it's required for SOCKS proxy., with 'socks' proxy and 'none' auth)"
